what power can be had from 2000 1.8tqs?
ian52 Jan 1, 2009
  1. ian52
    ian52 2000 a4 1.8tqs-yellow
    1,199
    basicaly just interested in what sort of power you can get from the 180bhp 1.8t quattro sport with the k03s?i see a lot of ibiza cupras with a k03s and some other bits and a remap with 230/240 bhp.i would like an exhaust and a remap but exhausts dont seem to be that cheap so will prob wait till the standard one rots.
  2. Broken Byzan
    13,237
    465
    I would recon a reasonable figure would be 210-220 ish on a remap and exhaust. The k03s on the longitudinal engine doesnt seem to get the same figures that the transverse ones do for some reason.I assume the turbos are different specs
  3. Siena
    Siena Active Member
    2,626
    K03-S on transverse-engined Audi / VW is indeed different, for starters, it's larger.
    Ian, if you're going to wait till your OEM exhaust rots before you replace with an aftermarket stainless / sport system, be prepared not to replace it.
    They're double skinned, (the silencers) and the pipework is quite heavy gauge steel.
    My '96 car's covered 215,000 miles, and still has the original system.
  4. ian52
    1,199
    is it worth getting an aftermarket exhaust or is the standard one not that restrictive?
  5. Siena
    Siena Active Member
    2,626
    Not sure how restrictive the OEM exhaust is, but a quality stainless item wouldn't hurt performance.
  6. aragorn
    18,438
    845
    the exhausts are pretty decent, and ye our '96 on 175k was on the original system, i changed the front pipe and cat for the last mot, but it hadnt rotted thru, the flexi had burst due to the engine mounts being a bit soft, and the cat had been gutted by some previous owner. The metal itself was all still solid.
  7. griswold
    griswold Member
    350
    Got just over 211bhp from mine with new custom stainless system, torque was higher than before though.
    Was too loud without cat so that had to go back on, sounds better now just a bit louder than original. cost me about £248 fitted to cat. not bad compared to other systems.
    Probably no need to change exhaust as standard one is fine.
  8. mac1403
    mac1403 Member
    972
    Mine with a few mods was 229 bhp. I would say definately change the exhaust. The oem exhaust is quite restrictive. Mine was remapped at AMD with a Miltek and high flow cat plus Forge Dv. Agree with Sienna.....if you are gonna change the exhaust you will have a long wait till the oem one rots.
  9. ian52
    1,199
    its just gone 175k now and its on the original exhaust.most other cars your lucky if you get maybe 4 years without replacing part of the exhaust at least.i never thought it would last that long.
  10. Siena
    Siena Active Member
    2,626
    Audi OEM exhausts last 12 years or more.
  11. jcb
    jcb Active Member VCDS Map User
    4,132
    13
    Miltek turbo back swapped out on a bone stock car does very little if anything.
    Its the first thing I changed as I picked one up very cheap. wasn't expecting much difference but some would have been nice.
    however when you crank it up with a remap or turbo swap it will allow more gains than the stock exhaust
  12. docurley
    4,071
    86
    I just remove the stock unit from my old 2000 car and there is cery little signs of any corrosion on it and would guess it would last another 8 year without any issue bar the flexy pipe going.
  13. PaulJC84
    PaulJC84 Owner It's my birthday
    2,912
    17
    I had to replace the flexi on mine but that was due to it hitting things.
    Also one of the rear brackets came off but I got it welded back on. Last pretty well.
  14. docurley
    4,071
    86
    The only way to get near thouse figures is to get a K04-15 turbo and if you have a look someone is selling a Jetex Exhaust which I'm sure he would sell for a nice price.
  15. voteforpedro
    voteforpedro Member
    632
    How restrictive are the OEM exhausts? I'm looking at a nice stainless backbox but can't afford to swap the whole exhaust. I want to get a remap soon but will the stock system suffice with a less restrictive backbox?
    Sorry to threadjack. :)
  16. docurley
    4,071
    86
    Once you start cranking up the power you will want to reap the benifits of your well spent money and a full system will only aid the remap.
  17. voteforpedro
    voteforpedro Member
    632
    I was thinking hold of some of this:
    http://cgi.ebay.co.uk/3-76-2mm-T304-Stainless-Steel-Exhaust-tube-PIPE-1m_W0QQitemZ220243524157QQcmdZViewItemQQptZUK_CarsParts_Vehicles_CarParts_SM?hash=item220243524157&_trksid=p3286.c0.m14&_trkparms=72%3A1301|66%3A2|65%3A12|39%3A1|240%3A1318
    but longer, removing the centre box and mating it to a new backbox. I am a cheapskate. Will this work? :cool:
  18. docurley
    4,071
    86
    Well if your keeping the K03 turbo then you dont want anything bigger than 2.5"-2.75" plus I hope you know what your doing plus removing the resonator will make the car drone so that may not be a good idea.
    If you are looking to make your own system I have a universal back box I bought for my old car that never got fitted which you could have for £30 + P&P
  19. griswold
    griswold Member
    350
    As your in Cardiff pop down to custom exhausts in city rd just behind the plumb centre they are quite reasonable. I bought my own ss back box which they fitted and did the rest of the system including flexi.
    I'm sure they will fit a back box no problem, have it done properly.
    Docs back box looks good but would check about the hangers if you can have them welded on or use the straps that come with it.
  20. ian52
    1,199
    i think i will just get a chip when i have cash.im used to more than the 180bhp so could do with it being a bit more livley.its still on the standard clutch at 175k so dont know how much longer it will keep going.
  21. billybravo
    billybravo Active Member
    1,045
    or even try Longlife there head office is in cardiff
  22. voteforpedro
    voteforpedro Member
    632
    How much did they charge to supply and fit the exhaust? You bought your own backbox so they supplied a centre box and pipes from cat back?
  23. griswold
    griswold Member
    350
    £200 i paid £48 for my back box del. 6.75" x 3" i think.
    As for longlife had one in the past but after they crushed the whole outer rim of two alloys of mine putting on two tyres I wouldn't use them again they tried to hide what they did even though took over 4hrs to change two tyres and told me they had problems with the machine they wanted me to sighn for the work before checking the car over. So they have lost a customer.
    Custom would be cheaper than longlife give them a ring for a quote or pop down there.
  24. griswold
    griswold Member
    350
    Get it chipped lots of choice but chipped uk have rr days quite often with before and afters £250.
    If yours is the same as mine your chip will need to soldered in so who ever does it make sure they are reputable and have done it before.
  25. naefeart
    naefeart Bonkers
    168
    39
    I fitted a Milltek resonated cat back last year, had it dyno'd at Star Performance and got around 190Bhp and 190 lbs/ft. Was quite surprised. When Jim took it for a test drive, he returned and asked if I was sure the car hadn't been mapped in the past :)
    It drives much, much better now since having it mapped by JBS. No idea what it's putting out, 215Bhp and 230-40 lbs/ft perhaps?
    I should get it dyno'd again, but tbh I'm not really concerned - feels quick enough for what is only a wee 1.8.
    n
  26. jcb
    4,132
    13
    you got 10bhp from just the cat back?
    I have a turbo back miltek with free-er flowing cat and mine is bang on 180bhp on the same dyno..........
    how much was your JBS map?
  27. PaulJC84
    2,912
    17
    Mine got 196bhp on stars map with a decat and straight through 2.5" system from the down pipe to the backbox.
    I got it rr'd there before my map.
    Jim did say that was very good for an exhaust on a standard car. He only took my car for a drive after the map.
    Oh and I had a tank of Optimax in too!!
  28. aragorn
    18,438
    845
    i could imagine removing the cat could gain 10hp, but lets be honest, any changes after the cat is going to do very little as the cat is so damn restrictive in the first place...
    As has been said, i dont think you will see any difference in fitting an exhaust alone, and the stock system is not restrictive at all at standard power (restrictive exhaust = less efficiency so most cars built in the last 10 years actually have pretty good stock systems, barring the cat)
    Even if your chipping the car, i really cant see any point of changing the exhaust if you keep the stock cat.
  29. voteforpedro
    voteforpedro Member
    632
    But high flow cats cost $$$. I could get a faster car for the cost of a full exhaust, downpipe and high flow cat. :3sadwalk:
  30. naefeart
    naefeart Bonkers
    168
    39
    Indeed, obviously assuming I had 180bhp to begin with. I have a printout somewhere with the figures.
    Can't remember what I paid exactly, they had a 30% discount on at the time and fitted a forge diverter valve too. Think it was 380 quid all in.
    They had to solder the chip in, took ages but the fitting was still free.
    Regarding the car's output after fitting the exhaust, I am as cautious as the next fellow reg. rr readouts - that's why I took it to Star. Jim didn't get a good reputation by not knowing what he's doing.
    I used to have an E36 M3 Evo, they had a terrible reputation for not making the claimed 321bhp. Most were around 290-300, but some would make the right figures and some would even make more. :think:
    n
  31. JBS Sales
    JBS Sales Member
    395
    Hi guys,
    I know its not on this forum as of yet (will soon be)
    But we are offering some 2009 Package deals - for example:
    Custom-Code Phase 1 remap
    Milltek Cat-Back
    Green Filter
    From the RR prices I think we have saved around £130-170 for this type of set up so it is something to think about!
    We will be posting the deals on here very soon but in the mean time please feel free to give us a quick call on 01246 455005 and ask for Nino.
    Kind Regards
    Mike
  32. PaulJC84
    2,912
    17
    A deal on those items or only when bought as a package?
  33. JBS Sales
    JBS Sales Member
    395
    Only when as a package - but if you already have one of the items if you give Nino a quick call on 01246 455005 I am sure he will be able to sort a little something for you.
    Mike
