What on earth is this (and how do i remove it?)[pics]
maxp Jun 6, 2010
  1. maxp
    maxp Member
    70
    The item pictured was already installed when I got the car.
    It looks like a bracket to hold something, bit it is *seriously* strong. Its made of steel and its bolted on really deeply (see pic#3). Does anyone know what it is?
    My next question is, does anyone know how i am going to remove it? I cant even see the fixing bolts after removing the trim panel, does this mean the carpet has to come out?
    Cheers.
    [​IMG][​IMG][​IMG]
  2. evilbow
    evilbow Member
    188
    Look kinda the same as something i had fitted to an old BMW 325i years ago, its an anti theft device were if you put car into gear(usually reverse) another part would hold it there locked. removing is gonna be hell on earth cos the bolts wont have heads to remove, you'd need get underneath it and grind the round head away to get it out, if its what I think it is:blush:
  3. sportstractor
    sportstractor Chugger
    2,709
    what a random peice of metal?? no clues as to what it could of been used for. Carpet will have to come up for sure though.
  4. Sandip
    2,440
    91
    I was going to say it looks like a bracket to hold a phone cradle or something but that piece of metal could tow a car lol
  5. ALPINE
    3,093
    its a anti theft device. as evil stated its to hold the car in gear and you lock it into place. My import scoob had one and it was a mare to remove. good idea but what an eye sore to the car!
  6. maxp
    maxp Member
    70
    An eye sore it is! Can you remember how you removed it? Was it a carpet out jobbie? Please tell me its not bolted to the underside of the car.
  7. evilbow
    evilbow Member
    188
    My BMW one was bolted to underneath the car mate, and wasn't bolts that a spanner could be used on, we had to use an angle grinder to cut it out:banghead:
  8. ALPINE
    3,093
    i got a grinder to it mate. there will be bolts underneath the car. i could not get to them as there was no room to get a Grinder in. Interior out and i grinded it off that way. Long . com!
  9. sportstractor
    2,709
    haha, that did cross my mind but sounded such a stupid device and never seen one. What a peice of turd
  10. Sandip
    2,440
    91
    The things people do to keep their Audi's safe:kissmyrings:
  11. A3Tom
    A3Tom Smell my finger.
    3,504
    14
    Bloody hell.....overkill for an anti theft device.
    What a horrid thing!.
  12. elbored
    elbored Member
    34
    The device is called a multilock they were fitted to a lot of cars around mid to late nineties there was another part which was a big strong padlock and it locked the car in gear,there should be two shear bolts bolted through the transmission tunnel http://www.afs-securitysystems.com/Mul-T-lock-Gear-Lock.php
  13. maxp
    maxp Member
    70
    Thanks mate, that link is very helpful indeed.
    In order to remove the bolts from the transmission tunnel, is that gonna be a stripping the carpet job or actually getting underneath the car?
    Not sure if this may be one for a professional garage or not.
  14. lowriders3
    lowriders3 New Member
    Could you not just cut it off so it sits below the centre console??? seems this would be the easiest option...
  15. elbored
    elbored Member
    34
    i think grinding the bolt from underneath is the easiest option,dont think you would be able to cut the thick bracket this will be hardend steel(wouldnt be much of a deterrrent if you could easily remove it ),you may want to remove the carpet as the bolts will get hot when you grind off the shear bolts from underneath
