What mpg do the 140 guys get?
N8 Jan 8, 2008
  1. Power_Junkie
    Power_Junkie Member
    66
    The Quattro uses more, i was lucky to get 42mpg on a run, mostly for commuting we saw about 38mpg (stuck in traffic for bits) so the S3 givin about 32mpg isnt too bad.
  2. N8
    17,163
    718
    Thanks....
  3. emzino
    emzino Active Member
    1,231
    Good info there Bowfer but that 0-100 time is DISGUSTING :wtf:
    I hope that's for DSG only and not manual too =/
  4. centurion
    centurion 3rd gear's my favourite...
    According to the DIS I've averaged 50.5MPG since I last reset it if that's to be believed.
    Not 100% sure how much I get out of a tank I but it's in the order of about 500 miles before the light comes on.
    The highest I've seen was 57 on a run from Plymouth to Brum.
    On the other topic of the the TDi not liking it under 1500rpm, my 140 will happy sit below 1500 without complaining and is perfectly drivable from just under the 1000 mark. OK it doesn't pull like it can but for around town it's fine.
  5. h5djr
    9,447
    1,762
    Good info, but slightly misleading.
    The 140 takes 26 seconds to get to 100, but the BMW 320d does it in 5 to 6 secs less.
    But the 320d produces 130kw/177ps/350Nm.
    Comapre that to the 2.0TDI 170 - 125kw.170ps/350Nm.
    I think the 170 is closer to the 320d that the 140 and the 170 does 0-100 in 21 seconds based on my testing which is also 5 to 6 secs better than the 140.
