What mods have you made?
necroeire Sep 27, 2006
  1. necroeire
    necroeire Active Member
    1,008
    As above please, just with regard to the engine, not alloys etc...
  2. Jason
    Jason Member
    188
    Cleaned and disabled EGR valve.
    Audi remap from 150 to 180bhp (By previous owner) Mad git cost over £800!!!!!
  3. fjtwelve
    fjtwelve Moderator Moderator
    770
    10
    Turbochip, allegedly 210hp and 420Nm but no dyno charts, £470 (£800 did they see him coming?)
    Big red scrape all down offside doors (thankyou nurse in Seat Arosa)
    Ding in rear bumper (twat in BMW)
    As funds come available
    Replace shocks
    Better brake pads
    K&N (well someone needs to, theres lots of chat and not much actual experience)
  4. james0808
    james0808 Active Member
    3,548
    Did you notice any difference???
  5. The Slug
    The Slug Active Member
    1,869
    just a pipercross panel filter, remap by Superchips and shes driving strong, like a steam train on steroids!
  6. fjtwelve
    770
    10
  7. MikeA3
    MikeA3 Active Member VCDS Map User
    1,178
    Superchips remap & i'm fitting the pipercross panel filter this weekend :)
  8. I used some dielectric grease in the MAF sensor Mutiplug... seems to have helped..... and I reset the Throttle pot so it actually read 100% on full throttle....lol best mod ever... ;)
  9. kris_tdi
    kris_tdi Member
    164
    I have one, its off at the mo but am putting back on for rolling roadday on sat.
    TBH doesnt really make much difference other than noise, bit more responsive maybe.
    Took it off for summer though as soaks loads of heat and made the car really smokey and low on power after sitting in traffic.
    Sounds awesome though.
  10. fjtwelve
    770
    10
    Emailed K&N and said would the induction kit for the 150hp engine fit but they just said sorry there is no kit for your car. Cannot find one anywhere else yet, still looking. There are plenty of replacement panel filters around.
  11. K7ERG
    K7ERG Member
    372
    All you need to know is the diameter of the Air flow meter and get a universal cone filter. Vectra V6 Cone filter is only £45 delivered from Demon tweeks it fits my AFM on my Astra. Diameter is 80mm.
    Hope this helps.
    Craig
  12. Jason
    Jason Member
    188
    Did I ever!!!
    Dammed thing was that sooted up it was sticking open and smoking like a bitch!!
  13. Rev-head
    Rev-head Active Member
    2,987
    Was thinking about doing that on my 1.9tdi but what other things do you need to do regarding vacuum pipe........I take it you just put blanking plate on
  14. Jason
    Jason Member
    188
    You don't have to plate it as if you remove the vacuum hose to it (making sure that you block hole in rubber vacuum pipe with a bolt or screw) this disables the EGR valve in the closed position!!
    But if you have done a few miles over 100k for example chances are that it's already sooted up and not closing properly which means it will have to come off to be cleaned making sure it's closing 100% creating an air tight seal and not re-circulating all those nasty sooty gases that knacker the MAF sensor and block your inlet manifold!!!!!!
  15. Drizz
    Drizz Project Plush
    681
    Any 'How 2' on this?
  16. grabber
    grabber New Member
    I have a forge DV fitted and forge remap looking to get hose`s replaced next.
