What modifications next?
chrisa4quat Jan 24, 2012
  1. chrisa4quat
    chrisa4quat Active Member
    970
    After the decat, exhaust, filter, hpfp and remap. What are the next steps for more power? Car is a 2.0T Quattro DTM.
  2. razza1
    razza1 Well-Known Member
    3,055
    806
    Bigger Turbo I think
  3. slepy
    slepy Extremely smart and handsome person. VCDS Map User
    2,088
    323
    K04,fmic,injectors
  4. chrisa4quat
    970
    So expensive lol
  5. razza1
    3,055
    806
    Yep :)
  6. chrisa4quat
    970
    Does any ko4 fit? There is one in classifieds with s3 injectors?
  7. hades-
    9,481
    646
    as above k04 but before you bolt it up get it hybred
  8. chrisa4quat
    970
    This is the tt turbo right? How does it make such a difference?
  9. hades-
    9,481
    646
    TTRS S3
  10. chrisa4quat
    970
    Ok well it'll have to wait but atleast I know I've gotta start saving or rob a bank :-/
  11. hades-
    9,481
    646
    TTRS S3 some golfs judt a bigger turbo thats the difference and with a hybrid even better
    plus s3 injectors fmic relocated dv better off with the forge new downpipe as the flange on the kk04 is diffrent from your a4
    new turbo pipe and you will be looking at quite a bit of hp
  12. slepy
    2,088
    323
    bez - ttrs doesn't have K04 but K16
  13. hades-
    9,481
    646
    must be the TTS then i know its in 1 of them
  14. spider74
    spider74 Member
    106
    10
    K04 from a TTS or 8P S3 is the one you are looking for. Im researching it now for my car based on SOLARIS's thread where he has done this. You can get them used plus you need S3 injectors, a S3 High pressure fuel pump (the one in the engine not the tank) and some work to relocate the diverter valve and a custom flange on your downpipe/cat/decat or whatever exhaust system you have. My goal is to have tuned S3 power in a B7. I know you can go mad and get bigger turbos or even upgrade internals and get 400ps from the K04 but your into mega bucks by then. I think £2k is probably a realistic budget for all the parts and a good map from someone like MRC tuning.
  15. hades-
    9,481
    646
    the HPFP from the S3 wont do the job you need the upgraded HPFP
  16. Rob W8
    Rob W8 Member
    953
    The hpfp's are all the same. As above it's the internals that need changing to flow more fuel. I might know someone who sells them....
  17. hades-
    9,481
    646
    how much built ?
  18. Rob W8
    Rob W8 Member
    953
    I only supply the internals. You are looking at 1.5hrs labour at a garage tops.
  19. chrisa4quat
    970
    Not too bad to change. Me and lad did it at work. But fiddly but managed it. Noticed one of the thrust sensors were broken when I did mine so had to replace that at about 40 quid lol
  20. hades-
    9,481
    646
    yeah iv done a couple not to hard
    how much for the internals and what make ?
  21. Rob W8
    Rob W8 Member
    953
    Autotech and they are £270 delivered.
