what lowering springs for sline on 19" rims
hollows wife Mar 28, 2013
  1. hollows wife
    hollows wife Well-Known Member
    1,404
    164
    what lowering springs are you guys running . even swapping from 18" to 19" theres still at least a 30mm gap between the rims and arches . been looking at springs but most only offer a 30mm drop . im guessing that it needs 40mm at least to look better as these are estimated heights for non sline models which i believe are 20-30mm lower .
    so what springs are rated well on here. dont want teeth smashing suspension either ,knocking on a bit now .
  2. shady-ninja
    shady-ninja Active Member
    999
    53
    that should depent on the offset and stretch of the rims.
    if you get this wrong you will hate your self.
  3. Brodster
    Brodster Well-Known Member TeamMisano Team V8 Audi RS4 Audi Avant Owner Group s tronic
    3,553
    896
    H&R are very good quality and very popular amongst VAG owners.
    Part No.: 981440281 lowers it by 40mm.
  4. Mcdubber1
    Mcdubber1 Member
    255
    I've got Eibach sportlines on mine and they performs very well. The ride is only slightly stiffer than standard and they e dropped my s line around 20mm or so.
  5. johnnythepie
    johnnythepie Well-Known Member
    2,242
    76
    Has it improved body roll, im having mine fitted wednesday!
  6. davsa4
    davsa4 Member
    257
    19
    i have eibach sportsline on my se ,body roll is vastly improved suspension is slightly stiffer than se set up not sure on s line , when i fitted the eibach sportsline to my b7 s line it made the ride less harsh but better cornering ,not sure on the b8 as told s line ride is not as harsh as the b7 .
    regards dav
  7. Mcdubber1
    Mcdubber1 Member
    255
    Yes I'd say it has but I've not really been for a good blast. Make sure you get some pics up once they're fitted!
  8. johnnythepie
    2,242
    76
    Yup will do.Looking forward to it, Ive already got front and rear eibach arb's, so hopefully itll be nice and tight
    Mcdubber1 likes this.
  9. johnnythepie
    2,242
    76
    Well theyre on!! Apparantly the fronts were a right cnut to do but the end result is well worth it.Smooth ride, and very tight round bends.No roll.Really pleased.Only prob was with the front bump stops as they didnt fit properly...the shock was thinner than the stop but they are on.Surprised at how low it is, but it doesnt rub or suffer from speed humps.Happy boy.Just need to clean it (pressure washer bust) and ill stick some pics on.
  10. Mcdubber1
    Mcdubber1 Member
    255
    Get some pics up or have i not spotted them? I just used the original bump stops on mine because the new one's didn't fit. Never had any probelms with it bottoming out on the bump stops though so all good.
  11. hollows wife
    1,404
    164
    fitted eibach on mine, something not right , terrible ride car is bouncing all over place . it only feels right when the car is fully loaded
    buying new shocks may correct it but there again it may not .
