What is this part called on audi A4 1.9 tdi 130, B6?
Johnjones Dec 29, 2012
  1. Johnjones
    Johnjones Member
    51
    I've noticed a pair of wires that go to some kind of sensor on the fuel line. The sensor looks a bit like a coolant temp sensor, but it's not as it's on the fuel line and only has 2 wires.....Any ideas? It looks like someone has tried to pull it off and has ripped the wires out instead and then stuck them back in with duck tape!!!! It's located on the top of the engine, just next to the fuel filter. Any help is much appreciated, thanks!
  2. 19scotty81
    19scotty81 Push down and across !!!!!!!!!
    107
    Photo ????????
  3. chrisa4quat
    chrisa4quat Active Member
    970
    29
    Fuel temp or pressure I guess
  4. dpbayly
    dpbayly Member
    391
    Its the fuel temp sensor and it's held in the fuel pipe with a little plastic horse shoe shaped clip
  5. Ian-83
    Ian-83 Member
    202
    Sounds like the fuel temp sensor there should be a part number on the plug which if you go to your local dealer should be able to get you a replacement and you'll need a repair wire too which comes with a connector each end so just snip it in half and attach one end to each damaged wire to fix.
  6. Johnjones
    Johnjones Member
    51
    Thanks for the help. That's exactly what I needed to know! Could this temp sensor cause the mpg to be poor???
  7. SL11CKK
    SL11CKK Active Member
    704
    37
    Yeah, it could
  8. Johnjones
    Johnjones Member
    51
    Ok, I'll get on and sort that as only getting 44 mpg and normally would be at 50 mpg....I've changed the coolant temp sensor and thermostat recently and that got the temp guage working again, but the mpg is still poor. Could it be anything else? Brakes and tyres are fine, recently serviced, etc.
