What is this on the rear of my headlight?
CO11K9 Aug 22, 2013
  1. CO11K9
    CO11K9 Member
    51
    image.jpg Sorry for being dull, what is the silver bit with the blue wires? What does it do? As there is not one on my replacement headlight, so slightly worried!!!! It's off a Audi A6 Jan 2001, Thankyou :)
  2. hades-
    9,482
    646
    is it the adjustment motor ?
  3. B5NUT
    B5NUT Well-Known Member VCDS Map User quattro Audi A6 Audi Avant Owner Group s tronic S-line owners group
    4,038
    785
    Looking at the part number it is the range control adjustment motor, you will need to take this off your old headlight and fit to your new one.
  4. CO11K9
    CO11K9 Member
    51
    Thankyou for the replies, I think I have a problem then, the replacement headlights who the supplier confirmed by phone were the correct replacements for my car/model have a different wire loom and I have no way of re attaching the angle control unit!!! Would it be worth getting an auto electrician around to have a look???
  5. B5NUT
    4,038
    785
    You should just be able to remove the motors off the old units and fit to the new units, I would say you have the wrong lights.
  6. TYphoon GB
    TYphoon GB Active Member
    386
    26
    Excuse the poor image but should look like a bit this but mine are xenon.
    The range adjustment motor connections are direct and not on the main lamp loom.
    Its the far blue connector...
