What is the correct tyre size?
Backdrifts Nov 18, 2007
  1. Backdrifts
    Backdrifts Member
    91
    What is the correct tyre size for the RSTT, S-line (what ever that are called) wheels that you get on an s3? I need three new tyres before winter.
    I'd look at my own car, but i'm about 150 miles away from it.
    thanks
  2. Backdrifts
    Backdrifts Member
    91
    Also where is a cheap place on the net to buy tyres from?
  3. mattyboy199
    mattyboy199 Well-Known Member
    1,889
    29
    I dont own a set but i would have thought 18 225 35 W/X/Y/Z
  4. jcs356
    jcs356 Brum brum
    2,734
    70
    Depends what size rims they are. I'm guessing they are most likely to be 18 inch, in which case 225/40/18
    If they are replicas and 19 inch then they will be 225/35/19
  5. Slick S3
    Slick S3 Member
    131
    225/40 zr on 18's most likely
  6. mattyboy199
    1,889
    29
    17 = diameter in inches
    225 = width in mm
    45 = % above (101.25)
    so technically to keep the same wheel if switching to the 18's you would have:
    18 = diameter
    225 = width
    35 % (78.75+25=103.75)
    25 being an inch in mm.
    Correct me if i m wrong ?
  7. Ess_Three
    Ess_Three Active Member
    5,383
    225/40/18 was the tyre size fitted by Audi to the S3/TT fitted with the optional 18" wheels.
  8. steebo888
    steebo888 Member
    218
    225/35/18 and 225/40/18 are both correct.
    The 35 is more expensive and a harsher ride, but because of the lower profile has a smaller turing radius (not much though)
    As per essthree's comment above audi supplied them with the 40
  9. Backdrifts
    Backdrifts Member
    91
    thanks guys, yeah its the 225 40 18 I'm pretty sure of it.
    Does anyone knoe the cheapest place to buy tyres on the net?
  10. jcs356
    jcs356 Brum brum
    2,734
    70
