What is realistic achievable power from a 1.8t??
s3cya Dec 27, 2013
  1. s3cya
    s3cya 1st Gear
    103
    Hi right guys going to be getting my 2nd s3 Ina few months I really want to go biggish power really hoping around 400whp, is this achievable from a ko4 hybrid I will be able to do all internals etc just really want to know what I can achieve or would a bigger turbo be better? All help greatly appreciated.
  2. slowcoach3
    slowcoach3 Active Member
    879
    106
    43
    Alright mate! Long time no see lol
    best bet is give us your budget and go from there...so many options dude
  3. s3cya
    s3cya 1st Gear
    103
    Hello Russ how are you pal?
    Yes been a while :( cannot wait to get back into another, but going to buy a low mileage beaut this time how is yours going? Budget is negotiable (with missus) but roughly 6k a year:) so mods will be monthly quarterly.
    slowcoach3 likes this.
  4. slowcoach3
    879
    106
    43
    All good thanks pal, my old dear is flying :) if I was starting from scratch again I'd be doing a tfsi conversion with a hybrid k04, all the benefits of stock components and power delivery and I should think a wee bit more cost effective than a brand new garret blower. I'll drop you a pm when I finish work as I ****** hate using my phone lol
  5. <tuffty/>
    21,879
    4,202
    You won't get 400whp from a hybrid K04 normally fitted to S3's....
    You will need a GT30 or GT35 to get into that region of whp...
    Realistically, a 1.8t will do 600+ hp with the right turbo strapped to it but obviously the rest of the engine needs to be built to take that level of hp...
    If you are doing this a bit at a time then I would suggest getting the engine sorted first...
    As mentioned though... the TFSI K04 shows promise... 370hp (at the flywheel, we aren't american) can be had with the right mods and its yet to be seen what a hybrid is capable of but could be in the 400hp region...
    Any engine going for this level of power should be sound, have rods and arguably if heading towards 400hp on a larger framed turbo valve train too...
    Biggest issue I have seen lately is worn engines... anything over 100k miles seems to vary massively... have seen sound high mileage engines like Gops make decent power but others are just too tired requiring a full rebuild..
    You won't get power by bolting a GT35 onto a tired engine...
  6. JimS3
    JimS3 Active Member
    736
    72
    When you say tired, anything in particular crop up regularly? Rings? Vale guides etc?
  7. slowcoach3
    879
    106
    43
    Jimmy are you being paranoid?
  8. JimS3
    JimS3 Active Member
    736
    72
    Good to know what's worth replacing while doing an engine build!
  9. <tuffty/>
    21,879
    4,202
    All the above... stem seals too... just had an S3 in with 130 ish k on the clock... stem seals were leaking that much oil that the engine misfired on idle... bores were so worn that not even new rings would seal...
  10. JimS3
    JimS3 Active Member
    736
    72
    Will do exhaust guides and all stem seals anyway, don't fancy boring the block though.
    Strange how you hear some still have factory honing marks at that mileage and some are totally clapped.
  11. superkarl
    superkarl MAN OF STEEL
    9,610
    2,481
    1000hp
    What we do here in the UK, and on this forum, and other UK forums, is absolutely nothing, its the tip of the iceberg compared to whats done, and has been done for years in the USA and even into Europe and Scandinavia.
    So to answer, up to and exceeding 1000ho is 'realistic'
    All it takes is ££££££££££££££££££
    And large testicles
    StaceyS3 likes this.
  12. daz-20vt
    daz-20vt Well-Known Member
    2,836
    584
    My car has 92k. It needed new stem seal guides as they were very badly worn. Lots of blue smoke. Decided to do rods while the head refurb was being done. The guy doing the work insisted in new rings regardless of condition but on inspection said they were very worn. My bores were glazed also. If your going to do this do itonce while its apart and save the time and hassle of doing it again.
  13. Broken Byzan
    13,237
    466
    you'd need everything to be as good as it can be with a gt30 71 minimum to make 400 AWHP, and tbh that would probably be in the realm of max this unit can produce. You'd need a ported head, cams, valve gear, probably an increase of capacity, huge downpipes and intake with WMI just to support the turbo in making the power. It should take you about 3 yrs to save it up at your current rate
  14. s3cya
    s3cya 1st Gear
    103
    Thank you very much everyone I want it to be a subtle monster:) tufty thanks for the info I am hopefully getting a low mileage s3 as I'm getting some funds from inheritance, so I am ideally looking for 70k or less, I will pm you when I have the car and when I will want big stuff doing?:)
