What headlights are mine? Halogens or Xenons?
crazypainter Jan 18, 2011
  1. crazypainter
    crazypainter Member
    590
    Beginners question I am guessing but what are my lights, Halogen or Xenon? Make is Valeo.And the difference?
  2. C17LJR
    C17LJR Member VCDS Map User
    513
    look like halogen to me, but i'm starting to doubt it as theres loads of lights on ebay that look/are halogen but are listed as xenon?
  3. crazypainter
    crazypainter Member
    590
    I believe these are factory fitted. Its a bit confusing as surely its just the gas type used in the bulb? but that doesnt explain what type of headlight unit I have?
  4. quattrojames
    14,040
    567
    They look like halogen. An easy way to tell is if they flicker when you turn them on?
  5. 19scotty81
    19scotty81 Push down and across !!!!!!!!!
    107
    Look like halogens to me as well. ps- where'd you get your bonnet grille from ?????
  6. crazypainter
    crazypainter Member
    590
    Bonnet grille on there when i bought the car.....why?
  7. hades-
    hades- Yorkshire & Humber Rep. Regional Rep VCDS Map User
    9,473
    646
    halogen you have no headlight washers
  8. quattrojames
    14,040
    567
    I was going to say that, but they may have been retro fitted.
  9. LandSpeed
    LandSpeed Member
    229
    id say they are halogen as no washers in bumper
    the grill looks like a caractere grill
  10. crazypainter
    crazypainter Member
    590
    kit is votex, would caractere fit?
  11. paul20v
    paul20v Audi fanatic
    1,113
    Thats a votex grill it looks the same as mine .
  12. LandSpeed
    LandSpeed Member
    229
    i do like the look of that
  13. BahnStormer77
    BahnStormer77 BahnStormer
    2,754
    53
    Assuming that is the orginal top bumper, then that car had Halogen's out of the factory.
    OEM Xenon's have washer's (legal requirement) and when they switch on and pan up and then back down when they auto-level (another legal requirement).
    The only way to tell when they are retro fitted is to either check the headlight units for ballass or a bit easier would be to get somebody else to switch the lights on and watch them come on: if they go on fainter and then build to a full high intensity pure white beam, Halogens can be fairly white or blue, but will come on straight on and stay at the same intensity.
  14. Nutkin
    Nutkin Member
    830
    it is a ,lovely grill.
  15. CHRIS555
    CHRIS555 DOPE with added OCD
    1,956
    Defo not xenons - as above no washers and visually they look different. Also xenons self level when you turn them on (very noticable)
  16. BahnStormer77
    2,754
    53
    well... legal ones do....
  17. matttrs
    matttrs Member
    163
    you'd know if they were xenons when turning them on in a dark area, as it looks like something off batman. A4's come with projector headlights either way so look similar and upgrading is fairly easy, if youre not fussed about self leveling and washers.
  18. crazypainter
    crazypainter Member
    590
    How do they 'self level'? I have just put xenon bulbs in and chrome indicator bulbs as i cant stand that orange look from the normal bulbs,,,,,
  19. Woorlord
    Woorlord shifting to Hyperspace... . VCDS Map User
    951
    15
    Self levelling sensors at front and rear (on suspension I think) and then to a central control unit which adjust the headlight via motors.
    Xenon headlight motors have 4 wire control and the standard Halogen motors via manual 0/1/2/3 switch level control is via 3 wires to the respective headlight motors.
    Expensive to retrofit unless you just happen to have a donar vehicle lying around!
