What have you done today?
jojo Nov 17, 2013
  1. IanPG
    IanPG Well-Known Member Team Nogaro Blue Silver Supporter Audi S3
    1,399
    555
    Just down next to the head on the heater hose side.
    Separated the two wires from the coilpack loom and now it just sits there.
  2. Stuart B
    Stuart B Well-Known Member
    2,073
    376
    Why have you both put this back? I know it holds the boost for a tiny second between first and second - but what is your reasoning? Especially Ian with his massive blower.
  3. Pasteurised
    Pasteurised Active Member
    263
    It just makes sense, Audi wouldn't have fitted it for no reason, and if you log boost you can see it spike when you come off the throttle without the N249 fitted.
    I feel the car is much smoother with it fitted.
  4. Stuart B
    2,073
    376
    It acts like a cut off device in an accident in cable operated throttle.
  5. hydro s3
    hydro s3 S3 amk Team Ming Blue Audi S3
    466
    89
    So i take it use both think that the N249 delete is a bad idea then?
    I was thinking of getting it done so thats why im asking.
  6. Pasteurised
    263
    It allows the ECU to open the DV almost instantly as you come off the throttle. In my experience it makes the car smoother between gears, and overall nicer to drive.
    Personally I wouldn't recommend it, but Im no expert.
  7. IanPG
    1,399
    555
    I put the solenoid back into it's plug because i get annoyed with errors when i scan (i can't get my TunerPro to install properly... something about .dll's or something so I can't delete it via software) - i still have the actual system deleted :)
    Stuart B likes this.
  8. <tuffty/>
    21,967
    4,243
    Its done mostly to eliminate pipes and tidy up the engine bay... you don't lose anything as such from doing it but it subjectively has an effect on part throttle driving...
    Should note that the N249 is mostly there as a 'protection' system to allow the ECU to cut boost quickly if it needs to... it has other ways to do this of course so its not like its the end of the world...
    There is no real reason to do the N249 delete if its not causing an issue (leaks etc) but if you want to clean up the engine bay then its not something you will miss either...
    ...just make sure the valve itself is still electrically plugged in :)
    andrew_wright likes this.
  9. <tuffty/>
    21,967
    4,243
    Been off work this week on leave and experimenting with my drip rig... finished up editing most of the pics tonight..
    tomjol, S3 Hilife, S3JACKSON and 3 others like this.
  10. superkarl
    superkarl MAN OF STEEL
    9,623
    2,488
    Do one with beer
    tomjol, S3JACKSON and IanPG like this.
  11. Alex C
    Alex C Well-Known Member VCDS Map User Audi S3
    3,306
    375
    he'll be trying to catch the Higg's Boson next!
  12. andrew_wright
    andrew_wright Member
    40
    14
    Very nice. Strange to see something like this in a thread like this...but I like it.
    Sent from my Nexus 6 using Tapatalk
  13. <tuffty/>
    21,967
    4,243
    Its what I did 'today' :)
    I stick anything car related in my build thread :D
  14. Stuart B
    2,073
    376
    Finally caught the elusive barbel, straight after fireworks. And err pissed in the river...
    I've spent 40 mins trying to get a photo small enough to upload... So I give up...
    Screenshot, email with resize, save with es explorers. Blah. Blah blah... With too big or the file extension doesn't match the content. I'm going back to my Heineken now.
    S3JACKSON likes this.
  15. Stuart B
    2,073
    376
    #winner
    it actually looks smaller than it is remember I am 14 stone and 5' 9 1/2"
  16. tcg
    tcg Active Member
    593
    230
    43
    I bet the one 'that got away' was bigger :yes:
  17. Stuart B
    2,073
    376
    grrrr... I don't do "fisherman stories" but that is a Barbel and they are still currently rarer than Audi 8L S3's - they usually take 5 days to bait a swim and grow the confidence to take the pellets. only once have I caught one on the Avon in less than 4/5 days but I am no expert and only fish once a year a bit like doing a poo or playing golf. (clearly I don't fish 24 hours a day for 4 days - I still have a bit of a life - I am on page 86 in Dan Browns Origin) :)
    I will upload the pike, bream and chub later on from this holiday, and see if I can find the big barbel from a couple of year ago.
  18. superkarl
    9,623
    2,488
    Your idea of a barbell is much different to mine.
    That’s all I’ve done today.
  19. Stuart B
    2,073
    376
    #bream
    #chub
    #pike
    #gianthaystacks
    #brianjacks
    I feel like we have all learnt today :)
    oh and year before last... #barbel
  20. <tuffty/>
    21,967
    4,243
    Oh dear
  21. s3mad_dude
    s3mad_dude Noggies ruuuule!
    622
    80
    I repaired my door blade (again). I bought a new one about five years ago. Fitted it. Perfect. Then, last year it started flapping about. So I removed it and glued the nylon inserts into the blade with Epoxy resin. Lasted for about a year and started flapping about again the other day when I closed the door. I popped to Audi to get a new one and the price in 5 years has jumped up from £140 to £262! I nearly fell on the floor! I figured I'll try another repair attempt, so this time I put in a few small countersunk brass woodscrews to help secure the nylon insert into the door blade. It's worked an absolute treat!! I also took the opportunity to clean the dirt and grime out between the metal door and plastic door blade. Let's hope my repair lasts 5 more years! Oh, and then a window cleaner put a leaflet through the door to advertise his services and he started talking to me about the S3. It turns out he'd like to buy it if I sell it! I don't think I'll ever sell it! I love it too much!
  22. Stuart B
    2,073
    376
    my iffy door blade is held on with some curtain fittings and "no more nails"
  23. <tuffty/>
    21,967
    4,243
    Today I snapped a couple of pics of a forum favourite...
  24. jojo
    29,001
    3,657
    Welly Cooler, the original!
  25. <tuffty/>
    21,967
    4,243
    Apart from s3 kev who did it actual first and me who tried it after because of Kev cooler and didn't like how the pipes would stick out so went and designed the Ah Fabs v1 and v2... ;)
    voorhees likes this.
  26. Strato
    Strato Member
    33
    Removed my brake callipers off my 955 Turbo custom made the front disks and got them fitted on my S3. Pads still havnt fully embedded with the disks.
    jojo, andrew_wright and S3JACKSON like this.
  27. Stuart B
    2,073
    376
    changed brake light switch as the old one "adjusted" for the MOT failed again on the first drive since the MOT yesterday, joined up the boost gauge as the previous pipe had melted during the hot MOT emissions passing and joined up the N75 to start getting some logs after driving 10 miles or so with a different map. I am still scared the intercooler hoses will pop off so I will wear my old trousers and keep the tools scattered about. just about to get in and noticed a flat tyre - so got that "sort of" repaired the only leak as a tiny bubble from the valve - seems unlikely to be the fault. so ready to go out and see if it blows up, catches fire, breaks down etc.
    andrew_wright, hydro s3 and S3JACKSON like this.
  28. Dohcwp
    Dohcwp Setting the Standard Team Silver Audi A3
    183
    68
    serviced the gearbox again, didnt take any pics this time as its the same exact same procedure from a year ago, i know it doesnt require servicing in such sort intervals but audi auto's have a history of failing so i'll rather spend a thousand a year on gasket filter and oil for my assurance than wait until something goes horribly wrong and i need to get another transmission again.
    not a fun job to be honest
    also the clocks hit the 200k mark, it's only the clocks thats got that mileage unfortunately, add another 150k on top of that for a true estimate.
    also found this on youtube (not sure if it was posted on here already)
  29. <tuffty/>
    21,967
    4,243
    Today I tested the new drop controller I have been building...
    Started with bags of bits....
    Using the circuit diagram on http://www.dropcontroller.com I used veroboard to mount the components... the guides on the website use perf board or a breadboard which I didn't fancy using..
    Got the power and valve trigger components in place
    Added the Arduino Nano control board...
    Flashed the Nano with the control program
    ...and then hooked it up to the windows control software to test it out...
    Just waiting on the Bluetooth module so that I can use the Android app on it...
    Should hopefully help improve my drop pics :)
    S3 Hilife likes this.
  30. Stuart B
    2,073
    376
    arh water and electrics - next you will make your own 10Kw shower controller
  31. <tuffty/>
    21,967
    4,243
    I very much doubt it :)
  32. Stuart B
    2,073
    376
    you have to love the Arduino and little c routines, I was trying to encourage my son to look at this - but no...just another slightly see through box on the dvd shelf. I got one to try and reprogram those little led message fans with swear words.
    <tuffty/> likes this.
  33. Tj 0785
    Tj 0785 Well-Known Member VCDS Map User Bronze Supporter Audi S3
    1,684
    356
    Did not know about the heated door locks
  34. Joewhyte97
    Joewhyte97 Member
    49
    17
    Decided i want to vinyl wrap some parts on my car. So as i have never done it before i thought i would just do some small interior parts for practice and well its not bad for a first go.[​IMG]
    andrew_wright, S3JACKSON, tcg and 2 others like this.
  35. tcg
    tcg Active Member
    593
    230
    43
    Good job mate... :respekt: ...better crack on with the rest of the trim now you know you're capable.
  36. Joewhyte97
    Joewhyte97 Member
    49
    17
    Thanks man i really want to do the black bit around the gear stick and the door blades and the black bit on the back bumper and the wing mirrors but just one step at a time
  37. Stuart B
    2,073
    376
    mapped out the AMK cold morning limp turbo mode - now I just some more cold mornings to see if it worked.
  38. S3JACKSON
    S3JACKSON Active Member
    102
    49
    After fitting a auto dip mirror,arm rest and chrome mirrors it was time for the last option to be fitted to my car...........................
  39. andrew_wright
    40
    14
    I'll post this here to as I'm only joined to two car web site's. (Other is SCN)
    Contact him if you're interested...remember the BBC can't be trusted. [​IMG]
  40. Stuart B
    2,073
    376
    lol you're nicked son... that's 80 on a motorway
