What have you done today?
ScottD3 Jul 17, 2012
  1. olds_kool
    olds_kool Active Member VCDS Map User
    1,094
    15
    i bought a c1-mfd1 multi media adapter and ampire dvx200i dvd player, was expensive but im still not in rnse price territory
  2. ScottD3
    ScottD3 I want your faulty electronics Supporter Team V6 quattro Audi A8 Audi S8 saloon Team Akoya TDi
    15,164
    1,124
    nice.
    that's a nice looking unit.
  3. gedi
    gedi Member
    59
    Had some spare time today so got radiator leak fixed,MAF sensor sorted, track rod ends changed into solid ones, wheel alignment done and the car washed :racer: i call it well spent time :cool:
  4. LeeT
    LeeT Member
    429
    Few more bits done, no pics though :)
    Outer cv boots, fitted the 034 motorsport front arm kit, reconnected the clutch line(what a ball ache), stripped down ready to do the cambelt tomorrow, fitted dual miltek, measured up for new reducing link pipes and got them ordered, painted and fitted the rs4 intercooler brackets, bolted the gearbox linkages back up and probably a few other little bits ive forgotten.
  5. Todd1983
    Todd1983 Member
    147
    Lee where was it you got your DP's, wanna have another look at their exhaust
  6. LeeT
    LeeT Member
    429
    Hes a great bloke to talk to Todd
    Audi - zinram
  7. Todd1983
    Todd1983 Member
    147
    Spot on
  8. s200rey
    s200rey New Member
    15
    EGR Removal & Blanking plates fitted. 2.5 TDi V6.
    Less smoke, slightly improved MPG, possibly better pick up from 1500rpm - 2500rpm but that bit could just be in my head, lol! :think:
    Over all, well worth doing though!
  9. ScottD3
    15,164
    1,124
    It took me 2 hours to get home, normally 45mins and somewhere along the flooded streets I ripped my under tray off.
    Just spend an hour trying to put it back on.
    All done though. :)
  10. PAULF
    PAULF Active Member VCDS Map User
    712
    66
    You need one of these:-
    as it takes more than girly water to do this:-
    and only takes a couple of minutes to remove and refit!
    :thumbsup:
  11. PAULF
    712
    66
    That's her car had an oil service, and following on from here (2.5TDi Sluggish) I've adjusted the actuator stop screw and rod length to see if I can improve things.
    It starts much better now, and has a faster response. I tried logging runs, but snow and icy roads made it challenging to say the least!
  12. Tom_B
    Tom_B Member
    296
    20
    Not quite today but on Sunday Changed the Oil and the Oil filter and the air filter. Next pressing task is the worn LH CV joint. Audreytoo needs a new CTS I think and possibly a new thermostat. Otherwise seems to be going ok.
  13. Goosey
    Goosey Member
    61
    ran 2 lots of flushing oil through mine today, oil light still comes on from 1500rpm and over :(
    always thought this was a good car too lol
  14. aragorn
    18,601
    870
    The dash ignores it below 1500rpm so its likely on constantly....
    What pressure are you getting? You need to check with a guage.
  15. qcland2
    qcland2 New Member
  16. PaulJC84
    PaulJC84 Owner
    2,921
    17
    Is that an alloy undertray you bent in half?
    What happened?
  17. ScottD3
    15,164
    1,124
    This
    :thumbsup:
  18. Goosey
    Goosey Member
    61
    didn't bother checking the pressure as the top end was telling me the full story.
    got the sump off tonight anyway and it doesn't look pretty so i'll give it a clean out and see where i'm at, can get a new pump for less than £100 but not sure if thats overkill or not considering the debris in the pick up
  19. Goosey
    Goosey Member
    61
    well thats the bottom end cleaned out, engine flushed and new oil/filter.
    took it for a run and seems to be ok, i'll pick it up tomorrow but fingers crossed should be fine and lesson learnt considering i wasn't aware of the issue but everyone else on the planet is lol
  20. ScottD3
    15,164
    1,124
    This :thumbsup:
  21. Bradderz_1988
    3,985
    261
    Well today i tackled the ICM delete and coil upgrade to hitachi E type coils, new bkr6e plugs gapped at 0.032 and changed the rocker for the old style AEB one and fitted new style mk5 golf oil cap.
    See coil harness upgrade thread for more pics.
  22. PAULF
    712
    66
  23. Foxmeister
    Foxmeister Fired Up!
    1,785
    I hope that isnt Star Trek your watching ^^^
  24. ScottD3
    15,164
    1,124
    Yeah and your point? :jump:
    I'm slowly making my way through the complete TNG series, I've done Voyager. :thumbsup:
    I also had a play with my awning but it was to windy to set it up fully.
  25. aragorn
    18,601
    870
    Set about changing the turbo on the avant at the weekend.
    Some pics:
    https://www.dropbox.com/s/pm4ki3fb7fppk2w/IMG_20121207_160234.jpg
    https://www.dropbox.com/s/gr1kwwym0xp1usv/IMG_20121207_160255.jpg
    Test fitting FMIC:
    https://www.dropbox.com/s/l26hev86dmc2l81/IMG_20121208_143419.jpg
    Test fitting big TIP and 3" MAF:
    https://www.dropbox.com/s/02egb5ynvgqnokt/IMG_20121208_144048.jpg
    TIP pipework needs some tweaking still and i need some hoses to finish off the intercooler so i'm hoping those arrive this week and i can get it finished off.
  26. ScottD3
    15,164
    1,124
    Shiny new turbo. Nice.
    Like the FMIC, would it work with a TDI? :p
  27. Foxmeister
    1,785
    I had hope for you Scott, thought you may be a "cool" kid, such disappointment! :puke2:
  28. NineNails
    NineNails Proud sponsor of the snack food industry
    593
    Oi! Nowt wrong with trek. Don't get me on one :superman:
  29. ScottD3
    15,164
    1,124
    You don't like it cause the only fat guy in the whole of start trek was Scottish. :ninja:
  30. ScottD3
    15,164
    1,124
  31. PAULF
    712
    66
    Just had the boiler quit on me just before I start a series of 5 late shifts! :sadlike:
    Suspect the ignitors are worn, so need a while to remove, 'adjust' and refit.
    On the plus side, the wood burner is still going.
    Also found out two of the four washer heaters are gone - one on each car.
  32. ScottD3
    15,164
    1,124
    I don't have any.
    I even cleaned mine and refitted.
    made no difference.
  33. Reyes
    Reyes Member
    105
    How are you playing DVD's on the NAV plus?
  34. ScottD3
    15,164
    1,124
    Via the AV inputs in the TV unit.
    Plug in a DVD player with composite outputs.
  35. Looney540
    Looney540 Member
    37
    Bought my cambelt kit, aux belt, water pump, thermostat, oil and filter today in a nice big bag that makes me happy.
    Should of cost me £400... Mine for £160. Gotta love discount!!
  36. PAULF
    712
    66
    Hurrah!
    Just home, off now until 26th :yahoo:
    (.....and my 05:00 start on the 26th now is much later - I was wondering how many Plods (or should that be Plebs :ninja: ) would pull me on the way in)
    Both cars nearly look clean after all the rain
    Spent 10 mins getting drenched at the bottom of the drive hunting for letter remnants that I may or may not have - my postbox finally gave up the ghost and blew away :uhm:
  37. PAULF
    712
    66
    That's me out with the Mr Muscle - AGAIN!
    Unfortunately Mrs PaulF has been complaining for a while, and I just hoped it would sort itself.
    Unfortunately, she did a Google search.
    It turns out Mr Muscle foaming cleaner cleans ovens almost as well as turbos!
    Oh, well, at least Christmas dinner will be done in a shiny oven.
  38. Foxmeister
    1,785
    Went and bought a new mota(Ford shaped unfortunately)....well, actually done it on 20th, this is just me getting on the comp since being home. And a private plate for it aswell!
  39. holophyte
    holophyte New Member
    22
    What have i done today? 23/12/2012?
    Went Mcdonalds! Does that count for anything lol
  40. ScottD3
    15,164
    1,124
    You are dead to me!!
