What have you done today?
ScottD3 Jul 17, 2012
  1. aragorn
    18,539
    865
    Its an S4 rear, and no, i just stopped and quickly took those pics.
    I really need to detar the paint and give it a good polish, but every panel has something wrong with it which pisses me off looking at it that closely.
  2. Bradderz_1988
    3,958
    240
    Yeah same with mine theres something minor on every panel with the bonnet, boot plinth and front bumper being the worst as i had a little bump so just going to wait for a decent bumper to come up and maybe get a second hand bonnet painted but first things get the mechanical things sorted first then i will look at the body work it look ok from a distance and when cleaned a little lol
  3. Bradderz_1988
    3,958
    240
    Last bits for the rear end refresh tomorrow have just turned up :)
  4. aragorn
    18,539
    865
    :) Looking good!
    Got somewhere that can do the alignment?
  5. Bradderz_1988
    3,958
    240
    Got a beissbarth at work (same as what MRC use) !!
  6. Broken Byzan
    13,237
    465
    Mrc suck.... just saying. You can do mine if you like. I'll email the car over. Lol
    slepy likes this.
  7. Bradderz_1988
    3,958
    240
    Lol its not a bad bit of kit tbh so hopefully will be ok, oh and your BF cap is on its way th misses posted it today !!
    Broken Byzan likes this.
  8. Sulli79
    Sulli79 Active Member
    541
    37
    I know that feeling, mine has had a full respray in its previous life, but I think Stevie Wonder would have done a better job!
    slepy and Bradderz_1988 like this.
  9. Sulli79
    541
    37
    On your former S4, are the brackets just riveted on over the top of the underseal, or does it look like they were fitted then the car undersealed?
  10. Broken Byzan
    13,237
    465
    Fitted to shell pre seal iirc. I just bought new
    Sulli79 likes this.
  11. mojocvh
    mojocvh Member
    167
    X4 tyres fitted and balanced, drives like new again, awesome.
  12. mojocvh
    mojocvh Member
    167
    Yep, sourcing the right VW TL 521 45-Y [G052 145 A2] fluid ain't easy....
  13. Sulli79
    541
    37
    Yeah I've got new ones to fit, just wondering wether to strip the sealant off that area?
  14. aragorn
    18,539
    865
    Yeh they're undersealed over!
  15. Broken Byzan
    13,237
    465
    Washed the wifes Avant and rinsed my wheels to stop the brake dust eating them anymore.
    Fitted the new door strips I had from Scott to her car but need to remove sikaflex residue the last owner must have used to glue the failing ones. Main problem is he had them set further up the door do new ones don't cover the goop. I have been looking for a remover fir the sikaflex and found dome stuff I might try. Also fitted the lever for the rear seats Kev managed to source for me. Most productive i have been in ages.
    Just waiting to see if issam and crew fix/replace/inspect my rods now, they were deffo faulty but for some reason insisted i sent to lot to JNL to see. None of the other failures had to do this, so I must be special. Neither issam nor JP will tell me what they are expecting to find, or not find, sigh
  16. slepy
    slepy Extremely smart and handsome person. VCDS Map User
    2,113
    354
    Did you try tar remover for the sikaflex?
  17. Broken Byzan
    13,237
    465
    only stuff i have is tardis and that had no impact
  18. Petrol is good for removing tar, or WD40
  19. Oranoco
    Oranoco Well-Known Member
    3,991
    407
    Well after my aux belt failing half way to Ikea yesterday I spent today fitting a new one. What a sod to do!!
  20. Bradderz_1988
    3,958
    240
    Today i got the O/S rear end refresh all boxed off stripping it was a doddle but had a struggle yesterday with the top arm bushes had to get a flappy drum wheel in the outer bush housing as it had corroded internally and wouldnt accept the new bush had to grind off the metal flush part of the bush drill the centre bushing out and the air chisel out the bush housing. And to top it off the press at work is past its use by date and started to **** oil everywhere just as i had stripped all the o/s down. The oil that came out the diff i replaced less than 12 months ago was black so clearly its flushedsome of the **** out lol new diff seals and oil done. Only thing left is to do the Geo tomorrow.
    Also cleaned all the arms up and gave them a quick coat of plastikote metal protekt just to spruce them up a little. Think i will be in need of some shocker mounting brackets as one has a small hole in it.
  21. richardm
    richardm Member
    34
    Today I did the Passat wiper mod, as seen here - RS4 MOD: Aerowipers
    My wipers had been juddering horribly for weeks so decided to kill two birds with one stone and get some Passat b5.5 wiper arms from a breakers.
    Before (with Bosch Aerotwins):
    Not looking too bad but it had always annoyed me that they were so visible while driving!
    As I said, I bought from a breaker yard on eBay the wiper arms from a 2004 Passat. Fitting was as easy as wrenching the old ones off the car and bolting the new ones on, using a strip of masking tape to mark where the wipers should sit when parked. I also treated them to a new pair of Bosch blades. Here they are:
    Much better! The arms sit much flatter to the screen and are much less noticeable behind the wheel. I haven't had a chance to test them yet but initial uses with the washer fluid are quiet and effective.
    Very very happy with this mod, £35 well spent!
  22. crazy88
    crazy88 Loving the anonymity
    4,939
    437
    Do you find that they miss right in the bottom corner on the passenger side? Mine do, but it's hardly in an area of concern. :)
    Nice mod for 35!
  23. richardm
    richardm Member
    34
    I haven't yet, but might do when using them properly. Looking at the pics it looks like the wiper is almost in the corner of the window - could it be you've put the driver's side arm (shorter) on the passenger side? Just a thought as I took the old arms off earlier before realising they weren't the same!
  24. crazy88
    4,939
    437
    Pretty sure I haven't. I seem to remember reading someone else saying the same thing happened for them. I'll get a pic sometime and have a compare. :)
  25. Sulli79
    541
    37
    Yeah my wiper lifts just slightly at the very end of the passengers side.[​IMG]
  26. Sulli79
    541
    37
    Also don't open your bonnet with the wipers anywhere else but parked, or you get this![​IMG]
  27. richardm
    richardm Member
    34
    I found that gently bending the end of the blade makes it press against the screen.
  28. Sulli79
    541
    37
    Yeah I did that when it was new but slowly reverted to original shape, to be honest it's so minor it doesn't affect your view out. After the wipers travel about 40mm you get full contact, so it's all good!
  29. richardm
    richardm Member
    34
    A small price to pay for not having to look at ugly wipers while you're driving I guess!
    Sulli79 likes this.
  30. Oranoco
    3,991
    407
    This is on my to do list before AITP
  31. Chriscooke
    Chriscooke Clueless!
    512
    25
    I must be tho only one who has no problem with the oem wiper arms :D
  32. Bradderz_1988
    3,958
    240
    I have no problems apart from the bosch aero wipers are toss, and i will upgrade when i see necessary although i think the RAC windscreen in my car laminate may be a little on the worn side ready for replacement lol
  33. Chriscooke
    512
    25
    From memory mine don't stick up as high as others on this thread, I'm using trico neofrom wipers from opie oils and rate them for the money and the fitment :)
  34. aragorn
    18,539
    865
    They stick up so much becuase they've fitted those retrofit aero arms that dont work properly.
  35. Oranoco
    3,991
    407
    I've got the Bosch retrofit aero blades on mine and found them to be superb. First time I've had a set of wipers last 3 years and still clear the screen as good as gold.
    Saying that, following my earlier comment I've accidentally purchased some Passat arms and am picking them up tomorrow night :)
    richardm likes this.
  36. aragorn
    18,539
    865
    I bought bosch ones years ago and the "spoiler" was the wrong way round (presumably designed for LHD), resulting them lifting from the screen.
    I tried a few others and they were all **** so went back to quality standard blades.
    Recently fitted passat arms to the avant and they're pretty good, so i'll probably get a set for shed too at some point.
  37. Got a replacement passengers side window/motor assembly. Finally got round to fitting it last night, now have a working window. Also got a newer heated mirror glass for that door too (swapped my own door mirror casing onto the new assembly). Took the wheels I got at the same time to the powder coaters. Got a fairly good deal, £30 per wheel and £5 to fit and balance my brand new tyres to the newly coated rims. When they're ready next week, I'll take the car down and swap the new rims on and leave the other set for my winter tyres to go onto.
  38. Bradderz_1988
    3,958
    240
    What colour have you had them done ?? Im a bit curious as to wether they can do all shades of grey/anthracite in powder coating as im thinking i might get the boleros done if they can do the right colour lol !!
  39. They said they can do any colour you want. Various degrees of glitter too. Mine are at Fife Powder Coating. I'm getting 'Sport Silver' a decent amount of glitter effect and a bright silver. They're big standard alloys on a black car, will post a pic of the wheels I have on the car in a few minutes, they're awful just now
