What have you done today?
ScottD3 Jul 17, 2012
  1. mojocvh
    mojocvh Member
    167
    Wow that's pretty awesome!!
  2. Yeah, it says free shipping, but it's €18, must be free to Germany. Still a decent price tho.
  3. Did you phone about tyres mojo?
  4. richardm
    richardm Member
    34
    Fitted some new rear lights today, but I'm not totally sold on them yet - I like the modern taillight LED design but wanted a factory look.
    What do you guys think?
  5. Bradderz_1988
    3,985
    261
    Quite like them actually probably closest to oem you will get.
  6. They're quite nice, where did you get them?
  7. richardm
    richardm Member
    34
  8. My car is black.... Think I'd stick with standard, if the windows were blacked out and I wanted to look like a drug dealer I'd go for smoked lol
    richardm likes this.
  9. Well worth the money, lovely quality when you have the candy
  10. mojocvh
    mojocvh Member
    167
    not with this months wages I'm afraid :sob:
  11. I've just spent £339 on Meyle HD arm kit and €207 on discs, still got servicing and MOT by 12 April, can't see MOT bring a problem tho
  12. slepy
    slepy Extremely smart and handsome person. VCDS Map User
    2,116
    356
    Bought 18's on ebay :)
  13. Oranoco
    Oranoco Well-Known Member
    3,998
    408
    Not generally a fan of non standard lights but those look pretty smart.
  14. UberAvant
    UberAvant New Member
    They look really nice. Inpro sells these also. :thrashi:
  15. UberAvant
    Do you have the rear fog upgrade?
  16. S4Steve
    S4Steve Member
    30
    Plastidipped the lower valance on the S4, i've seen the silver highlights on some of the newer Audis and wanted to try it. uploadfromtaptalk1396108205848.jpg uploadfromtaptalk1396108234435.jpg
  17. richardm
    richardm Member
    34
    Are you referring to having both rear fogs working? I didn't with the old lights, but these are already wired up for it so now both work.
  18. aragorn
    18,606
    871
    Not sure i like the silver, would need to be a darker grey sort of color to look "right" i think.
    Did some scrappy hunting today, went round three of the local ones. Been ages since i've been round a scrappy but there was a few things i needed. Really wanted to get to a fourth as i knew they had a black avant and i wanted to see if it had a good bonnet but ran out of time.
    Picked up a new battery to starter harness for the wifes avant, to hopefully cure the volt drop issue. I checked last weekend and the alternators putting out a solid 14.4v, but the voltage at the battery drops down as low as 13.5v with everything turned on. Earth checked out ok, No change when adding a jump lead between the battery and engine block, so next step has to be the live. Noticed on ETKA that the TDI ones are larger, so instead of making up my own with thick cable i just picked up a TDI one from the scrappy.
    I also picked up a new front panel/lock/radiator carrier for the track car. the bonnet lock is siezed on mine, and the one i have doesnt have the electric fan, so i got one with a fan and working lock.
    I then raided a BMW E46 for its battery to bulkhead cable. Unforunately i couldnt find one with the actual battery terminal attached. Turns out these have an airbag explosive in them, and when the car gets crashed it blows the connection off, disconnecting the battery. but i found one that had been cut off fairly close to the battery for maximum length and pulled it out. So i'll use that to connect up the rear mounted battery in the track car.
    My brothers just bought a wee fabia for his mother in law, so we were out looking for bits for that too. Managed to find a set of four 15" golf alloys and got them for £60 which he was pretty happy with. Also did a quick service on the fabia, oil and filters changed and threw a set of plugs in it.
    MURRAYS444 likes this.
  19. jbh
    jbh TDi lover
    1,412
    168
    I can get complete E30 325i one if thats any use to you Kev
  20. davy j
    davy j Member
    115
    what did i do today...just picked up my new (old) car
  21. Bradderz_1988
    3,985
    261
    Fitted these
    To get this
  22. jbh
    jbh TDi lover
    1,412
    168
    Are they FL S4? What's involved in getting them to fit?
  23. Bradderz_1988
    3,985
    261
    Facelift S4, Trig brackets, custom hoses and 300mm discs.
    Firstly you need wheels that will take the caliper behind mine are ET35 8J and have mm clearance (see pics in build thread stops the clutter then :thumbsup: )
  24. jbh
    jbh TDi lover
    1,412
    168
    pretty sure my 17's are ET45 8j just not fitted them to the quattro yet due to the street being like a building site and me having 3 sets of 16" audi sport wheels with good tyres
  25. Bradderz_1988
    3,985
    261
    ET45 is to high a offset you may need lower than ET38 it depends on the spokes and rim design a ET35 18" S8 avus for example will have more clearance due to the flat spokes and no dish compared to my boleros !!
    All i can say is there gunna be awesome once i sort the pedal out as think it needs bleeding some more.
  26. Broken Byzan
    13,237
    466
    45 will fit, but wont allow the brakes to work. The et 42 boleros didn't work. I also tried an et 35 LM copy i have here and that would have needed spacing
    I think I bled mine with the calipers loose so they could be moved around. Kev mentioned something about turning them upside down to release all the air and it just worked
  27. aragorn
    18,606
    871
    I think this E46 one will be ok, i'll just need to get an end for it. Work has big industrial crimpers so i can crimp the big terminals on.
  28. aragorn
    18,606
    871
    Yeh they're a right ******* to bleed. Elsawin has some instructions for bleeding them on the bench before fitting them to the car.
    I've tried various methods and never really come up with one satisfactory method that works perfectly every time. I always seem to need to go back over it a few times.
    Broken Byzan likes this.
  29. Bradderz_1988
    3,985
    261
    Right im going to try taking them off with hoses still attached and just have them hanging from the car with wind back tools in them to stop the pistons pushing out and try it that way !!
  30. jbh
    jbh TDi lover
    1,412
    168
    Would a vaccum bleeder work?
  31. Broken Byzan
    13,237
    466
    Still hit n miss even with vacuum bleeder or eazi bleed. Perseverance is the key
  32. jaffaxr
    jaffaxr Member TFSI Owners Group quattro Audi A4 Audi Avant Owner Group S-line owners group Manual
    97
    9
    not done much changed the rear calipers discs pads and wheel bearings....
    and slowly making a list of things i want to upgrade or retro fit to the old girl..
    got bored so started cleaning.. washed the carpet and seats got rid of some marks and cleaned and polished the boot shut and both drivers side doors
  33. Gunny110
    Gunny110 Member
    271
    19
    Hi all, so I went about spraying one of my wheels today, I think they tie In quite nicely with the colour of the derv. However, because they are not splits (fakes) I struggled to get a perfect line to split the black to the chrome paint. Does any one have any ideas that I can use for the other 3?
  34. Gunny110
    Gunny110 Member
    271
    19
  35. 2.8 30v
    2.8 30v Member
    149
    19
    Have you tried some fine line tape the stuff designed for painting pinstripes
  36. Gunny110
    Gunny110 Member
    271
    19
    No not tried that actually, tries with thin masking tape and that didn't work
  37. 2.8 30v
    2.8 30v Member
    149
    19
    Have you tried bleeding the brakes with the car running, I've had to do this a few times and seems to help
  38. Bradderz_1988
    3,985
    261
    Well ive just jacked the car up, got the misses to give us a few pumps of the brake pedal (she dint do to bad to be fair lol) got my brake fluid topped up and bleed the rears twice each giving them 3 cracks each time in to my fluid catcher and when i initially cracked the O/S caliper i could here the fluid spitting in to the bottle through the vac pipe went after the second opening. Finished it off took it for a quick spin and its fixed no more **** pedal :) that was just to easy lol
    It still has about half inch of travel before bite but think thats free play in the pedal or something ??
  39. aragorn
    18,606
    871
    The 43mm rear calipers do give a softer pedal than the 38mm ones, even once bled up properly.
  40. Bradderz_1988
    3,985
    261
    Ahh ok it was like that before i fitted them, personally id like it to bite as soon as i touch the pedal but i doubt on a car this old thats going to happen lol
