What have you done today?
ScottD3 Jul 17, 2012
  1. Phil-1
    Phil-1 Well-Known Member Regional Rep
    2,001
    644
    That's cheating. I had to drive a VW transporter van
    the_cueball likes this.
  2. the_cueball
    the_cueball Active Member
    494
    218
    43
    ouch!
    sounds like a wasted day though... hate when that happens... :wall:
    Phil-1 likes this.
  3. Mr K
    Mr K Member
    335
    Yesterday I got a new windscreen fitted, stripped, greased and rebuilt the wiper rack, fitted a new thermostat, header tank and fresh coolant, and fitted some xtreme vision bulbs to dipped beam which has highlighted that one light is aiming low.
  4. Bradderz_1988
    3,946
    235
    Today i replaced the rear diff for a lower milage one as i think mine was duff and it seems to have sorted my problem will see how it pans out !!!
    i also realigned the exhaust so its more centre to the bumper and i think i nailed that too :)
    so all in all a good productive day !!
  5. Oranoco
    Oranoco Well-Known Member
    3,862
    381
    Half fitted my missus a reversing camera. I say half as Peugeot don't seem to nail anything together very well making it a pain in the arse to work on
  6. griswold
    griswold Member
    350
    Seen these ages ago but thought I'd see what they were like, quite like it though.
  7. Bradderz_1988
    3,946
    235
    totally agree i worked for peugeot and now at citroen and they are **** the french dont half make things complicated lol
  8. aragorn
    18,137
    764
    Earlier in the week i talked about centre caps for the Boleros, i fitted them the other day and took some pics, so just uploading now.
    The caps i bought were these:
    Ford Alloy Wheel Centre Caps 63mm...Set of 4 | eBay
    Fairly generic ford badged caps, but crucially the correct 63/64mm OD and 55mm mounting lugs.
    I simply sprayed them the same color as the wheels and popped them on:
    http://friesian.lr90.org/gallery2/d/3322-1/P1050806.JPG
    http://friesian.lr90.org/gallery2/d/3319-1/P1050807.JPG
    http://friesian.lr90.org/gallery2/d/3316-1/P1050808.JPG
    They dont look as good as the proper caps ofcourse, but they fill a hole and cost £10 delivered for 4 rather than £15 each for genuine ones.
    Today
    I've had a set of PFL rear lights i've been meaning to fit to the avant for yonks, but they had a scuff on them.
    I'd sanded the scuff out, but didnt have fine enough paper to sand them smooth again, so they've sat in the garage for ages.
    I'm trying to tick off items from my seemingly endless list, so i got stuck into this today, sanded them back with 1000, 1500, 2000 and 2500grit sandpaper, before polishing them with Menz 203s (using a buffing wheel in my grinder... shh!) and giving them a couple coats of sealant.
    Some pics:
    Stock lights
    http://friesian.lr90.org/gallery2/d/3313-1/P1050814.JPG
    One of each
    http://friesian.lr90.org/gallery2/d/3310-1/P1050815.JPG
    Finished
    http://friesian.lr90.org/gallery2/d/3304-1/P1050817.JPG
    http://friesian.lr90.org/gallery2/d/3301-1/P1050818.JPG
    On the lighting theme, i've also had a pair of BiXenon projectors i've been meaning to retro fit into a set of facelift headlamps. I started it ages ago (see the theme here?!) and never got round to finishing it, so i dug them out and got cracked on, using this guide as an outline:
    Fix for weak headlights in stock Valeo housings?
    I'd already taken apart the headlamp, so i lined up the new projector, and marked out the holes. As mentioned in the other article, one of the holes ends up interfering with the edge of the projector housing, so you need to cut a chunk off the housing to get the screw in. Wasnt too bad though:
    http://friesian.lr90.org/gallery2/d/3331-1/P1050809.JPG
    http://friesian.lr90.org/gallery2/d/3325-1/P1050811.JPG
    http://friesian.lr90.org/gallery2/d/3337-1/P1050812.JPG
    http://friesian.lr90.org/gallery2/d/3334-1/P1050813.JPG
    Need to strip the other headlamp and repeat!
    ScottD3 likes this.
  9. Gunny110
    Gunny110 Member
    271
    19
    I'm after some wheel spacers if anyone has any, also fitted a new stereo today :)
  10. Mr K
    Mr K Member
    335
    Adjusted the physical location of the lights, fitted new track rod ends, and two front top arms (the others where down a few months back).
    Booked for its mot on Wednesday, they will do the final beam adjustment for me, although it looks to be pretty good. They ae also fitting a new cv joint and boot for me, and I now need to get them to do the tracking.
    A bit worried that the airbag module is taking a while to do its thing in the cold. It can take upto a minute or two before the light goes out when the cabins cold. Is it an MOT failure if the light takes too long to go off?
    The cars transformed with the new suspension arms, fast wipers,and thermostat. Hopefully the lights will be much better too now the diivers side light isn't aiming 10ft short.
  11. Tom_B
    Tom_B Member
    296
    20
    the garage that did my last mot told me that they have data for all vehicles on how the warning lights behave and how soon they go off after the engine starts bacause his all changed last yesr. I dont know how true that is though.
    Replaceing the airbag module is time consuming but not difficult. There are various guides if you google it.
  12. aragorn
    18,137
    764
    Get the car hot before you go?
  13. Mr K
    Mr K Member
    335
    I do intend on fixing it, are they model / varient / year specific? Do they need coding to the car?
    Wasn't sure how hard to find a second hand one would be. Unless they are available cheaply new?
    I plan to make sure its warm when I drop it off, if they leave it outside for most of the day before getting to it (I need to drop it off an hour before the garage open), then its outta my control. Maybe I need to take it for a half hour drive before I drop it off to make sure its warm through.
  14. aragorn
    18,137
    764
    Hmm, i'd be booking a slot during the day and taking it there for the slot.
    I never leave my car with them, i take it along at the time the test is booked for and wait for them to complete the test.
  15. Rallyman
    Rallyman LPG Abuser & have VAGCOM Bronze Supporter
    213
    Friday night 7pm - 10pm : front off old alternator (now with new brushes) back in. Left front off
    Saturday: took my 5yr old to London - no work
    Sunday 11am start old leaky rad out big fight with lower pipe, remove airbox to turbo hose due to holes fight with all the rusty pipe clamps - graft in new pipes after a trip to halfords. Relocate solenoid valve. Check turbo end float not bad for 192, 600 miles
    Replace water pump pas belt
    Fit radiator minus 1x clip new one made from lock wire
    Refit aircon rad bumper lights wheels
    Take for test run at 9.40 -all ok with now hoses jumping off
    Dinner and beer 10.15
    Phew!
  16. Gunny110
    Gunny110 Member
    271
    19
    This evening I carbon fibre wrapped my centre console plastics as they where looking rather tatty, I will be doing the door trims over the weekend :) rather happy with the results
  17. ScottD3
    ScottD3 I want your faulty electronics Supporter Team V6 quattro Audi A8 Audi S8 Team Akoya TDi saloon
    15,161
    1,121
    Saturday I replaced my incandescent side lights with some T8ups supplied Cree LED side lights. Incandescent bulb[​IMG]Cree LED[​IMG]Incandescent bulb[​IMG]Cree LED[​IMG]Side lights only at night[​IMG]
  18. Gunny110
    Gunny110 Member
    271
    19
    Hit bored today and had some wrap left so I did this ImageUploadedByTapatalk1386955956.087411.jpg ImageUploadedByTapatalk1386955962.903273.jpg what do you think?
    PAULF likes this.
  19. ScottD3
    15,161
    1,121
    You're loving the wrapping lol.Today I changed a bulb. oooooooooooo what a life I live in this fast pass world of car enthusiasts, I need to sit down before I do to much and have a break down.
  20. Gunny110
    Gunny110 Member
    271
    19
    Love it!! Lol, ohhhh what an effort Scotty, do t over do it :p
  21. Blue_Thunder
    Blue_Thunder Well-Known Member
    1,771
    31
    Yesterday's task was to have off with the old and on with the new (if you don't count the previous 4-5 years I had them fitted to the last car).[​IMG]Car looks much better now with a few cosmetic mods.
  22. Tom_B
    Tom_B Member
    296
    20
    To be fair Scott it's a right bloody gaff just to change a couple of side light bulbs on the A4 - I did mine a couple of months ago and for 8 quids worth of bulbs I think it's the best bangs for buck upgrade.
  23. ScottD3
    15,161
    1,121
    Its not a easy job really.
    This is the second time I've replaced side light bulbs in Audrey since I've owned her.
    I don't really want to do it again if it can be helped.
    These bulbs are worth it though. so much better than the old ones.
  24. aragorn
    18,137
    764
    Whats the difficulty fitting sidelights?
    Drivers side is a wee bit fiddly due to the airbox, but its perfectly doable. I did mine in about 5 mins while the car was getting MOT'd and the guy noticed one was duff and suggested i might want to fix it before he finished :p
  25. Bradderz_1988
    3,946
    235
    Agree they just pull out and push in 5 min job unless you have the ba9s bulbs in the xenons and the holders have shrunk round the bulb and the glass part of the bulbs snaps off lol
  26. ScottD3
    15,161
    1,121
    I put a 8P knob on to a 8L
    Broken Byzan likes this.
  27. Bradderz_1988
    3,946
    235
    My 3"-3.25" reducer turned up today along with the 3" stainless coupler and 3" 180' degree hose but thats wrong so have got on to the seller to try and resolve the issue as it has 76mm stamped on the part but its only 70mm id !!
    Offered up the reducer and its a tight fit but will do the job !!
  28. Mr K
    Mr K Member
    335
    Ordered my Polytek to do my rear rear diff mount.
  29. Phil-1
    2,001
    644
    Just found out to my expense
    If you put the wipers in service mode, lift them of the windscreen then move the car, they reset hit the edge of the bonnet and remove 3cm of paint 😡😡😡
  30. Beliskna
    Beliskna New Member
    12
    Gutted mate... I did that and cracked my windshield :'(
  31. Phil-1
    2,001
    644
    Thanks. It did make a loud bang. Won't do that again.
  32. ijgreer
    ijgreer Member
    142
    19
    Oh no, sorry to hear that! I'll bear that in mind as well!
  33. Gunny110
    Gunny110 Member
    271
    19
    Today I decided to get a quote for my clutch, water pump and cambelt 600!! Quid :0
  34. Bradderz_1988
    3,946
    235
    If thats fitted thats not a bad price, if its parts DIY !!!!
  35. Gunny110
    Gunny110 Member
    271
    19
    That with fitting. She only cost me 700 to buy lol
  36. Goosey
    Goosey Member
    61
    how odd, mine does the same thing when it hits 3 degrees or less and has done since i've owned it, no fault codes or anything so i just live with it, always off by the time i get going on a morning anyway.
    Probably a bit late to answer but the criteria has changed for the MOT, just has to be working and not on during the test. The "procedure" for the ABS light also went out the window
  37. Bradderz_1988
    3,946
    235
    Went to get 4 wheel alignment done at kwik fit bolton but they wanted £85 to adjust the o/s front toe, front camber and o/s rear toe going to see if the garage that did the father in laws lexus rx300 for £30 as they have a 4 wheel alignment that apparently is a hunter !!! If not il just go back to them or ask my boss at work to order a hunter lol !!
  38. jbh
    jbh TDi lover
    1,398
    162
    I went out and upgraded to a avant 110 TDi quattro...
    the private plate has still to be removed and its should be a p reg
  39. Sulli79
    Sulli79 Active Member
    541
    37
    I picked up my car from the mot centre, one new tyre and she was a goodun, cluster seems to be ok now so no oil warnings
  40. the_cueball
    494
    218
    43
    got the news from MRC that my RS6 with 864Nm of torque and 540HP is ready for collection.....
    :D
    crazy88 likes this.
