What have you done to your A4 b6 today?
krisavant Mar 18, 2014
  1. BakPak
    BakPak No Gear
    957
    137
    43
    They definitely look better black, especially the one on the back. What colour is your audi? Just noticed yours is blue. Black badge on a blue boot will look tidy.
  2. pauldazzle
    pauldazzle Well-Known Member
    1,191
    95
    Moro Pearl Blue.
  3. pauldazzle
    1,191
    95
    Anyone know how to get the badges off for spraying? i.e do they lever off or are they stuck on?
  4. ei2gfb
    ei2gfb Member
    101
    changed injector seals and pintels lets hope no more wheeping and gunk
  5. bradh
    bradh Active Member VCDS Map User
    567
    58
    spent 2 hours trying to get my rear wash wipe motor working got it working for it to stop again so now on the look for another motor pt no: 8e9 955 711 dont suppose any one has removed theres for the smooth look and has one kicking about ??
  6. ruffrida
    ruffrida Well-Known Member
    1,926
    313
    Four bolts ya done!
  7. Mike.M
    Mike.M Well-Known Member
    2,510
    170
    Started the b5 perch fit......got to the point of the strut all removed then tried to undo the top nut and failed miserably......had to put everything back together and need an appropriate 18mm socket/deep spanner as my method failed.
    Did also manage to clean the calipers and copper grease the pads......and just finished washing and waxing him too
  8. DieselJake
    DieselJake Well-Known Member
    2,830
    699
    Bigger brakes finally fitted.
  9. MooLard
    MooLard Member
    229
    Same happened to me a week ago, plus on round two of doing the task I snapped not one but two Allen keys!!
  10. TheDriver
    TheDriver Active Member
    265
    what brakes are you running Jakey?
  11. DieselJake
    2,830
    699
    320mm front, 288mm rear, mtec discs, mintex pads.
  12. deano1978
    deano1978 different gear
    713
    81
    Which carriers u use?
    Wish id gone bigger on back rear is silly small
    R they the drilled n groved?
  13. adamss24
    adamss24 Well-Known Member
    4,584
    407
    320mm brakes will be enough for 300Bhp and i think they are overkill on cars under 1700Kg... I had the same on my project- stock rear discs and pads and 320mm fronts and i could stop on a dime... heavy 1750Kg estate with 4 wd and 303 Bhp...
  14. DieselJake
    2,830
    699
    Little overkill but to be fair they're from a car with similar stats.
    2.0T special edition carriers, could of swapped for S4 but couldn't justify the huge price difference between carriers and discs for an extra 20mm.
    Drilled and groved.
  15. adamss24
    4,584
    407
    s4 upright is different and the mounting lugs are spaced differently than on normal a4, carrier and caliper is almost the same, some difference in the cast iron mounting between a4 and a6 but nowt else... The discs are 25mm larger though...
  16. BakPak
    BakPak No Gear
    957
    137
    43
    Fed up with electric shocks. It's worked so far, apparently it could improve radio reception?!
    DieselJake likes this.
  17. mattyb6
    mattyb6 Active Member
    977
    75
    Removed my rear audi rings as a test, so far I'm still happy lol
    Might black them and put them back on
    Also prepping my new front GmbH bumper for paint
  18. bradh
    567
    58
    did they come off easy as i need to get mine off to i can remove the little bits of crud/moss that keeps building up are they just stuck on??
  19. BakPak
    BakPak No Gear
    957
    137
    43
    Apply hair dryer heat temperature for about 1 minute then using a plastic spreader tease your way through the double sided.
  20. mattyb6
    977
    75
    Boil the kettle mate, leave for a minute or two.
    Them pour over the badge about 200ml
    Use a credit card or similar then push behind.
    Then keep pouring a little water then push the card more about half an inch at a time.
    The boiling hot water is fine after a minute or two.
    You will need g3 or a heavy compound to remove excess glue from the paint also a scraper
  21. BakPak
    BakPak No Gear
    957
    137
    43
    Acetone or nail varnish remover fetches off the residual adhesive.
  22. TheDriver
    265
    Or tardis.
    krisavant likes this.
  23. ei2gfb
    ei2gfb Member
    101
    cleaned polished and waxed car today, alloys are top of list for tomorrow, sorry about pic quality taken on phone
    Icarus83 likes this.
  24. S4_dan
    S4_dan Fire up the Quattro! VCDS Map User
    2,734
    165
    Today I achieved my first ever 50mpg average on a trip to York!
    barkclark likes this.
  25. Springer*
    Springer* Member
    170
    17
    Claybar & full Colour Magic polish of the A4 Cabriolet.
    Never done the clay bar thing before and could not believe the amount of dirt it removed from the paint. Afterwards the polish went on a treat and the paint is now like silk.
    Would've taken some pics but by the time I was finished it was pretty dark.
    Dead chuffed :D
    J:)
  26. audilad9
    audilad9 Member
    257
    So what is required to fit the S4 caliper carrier to the A4 upright on the front ? Thanks.
  27. adamss24
    4,584
    407
    Caliper will bolt up fine, however you will have to use the 320mm disc as the 345mm s4 disc would not fit. The mounting lugs are spaced further apart on s4 uprights hence why they accomodate the larger disc. Everything else is almost the same, difference is that some calipers have a flat face and some are more dished... You need to compare them side by side...
  28. audilad9
    audilad9 Member
    257
    Ah ok, thankyou Adams24, I was hoping to fit the 345 mm disc as I thought others had fitted it before.
    Am I right in you saying that the mounting lugs on the S4 strut are further away from the hub in turn mounting the caliper further out ensuring more space for big disc ?
    So everyone running B6 S4 calipers are using the 320mm discs ?
    Still my brakes are standard diameter at 288mm so 320 will be somewhat better.
    Whilst I'm at it, I assume new flexi hoses are required, would the S4 ones fit ? Thanks :)
  29. Ash92
    Ash92 Active Member
    396
    29
    Converted my single din to double din and fitted Sony Xav 64bt
  30. AudiLeon
    AudiLeon Well-Known Member VCDS Map User
    2,249
    192
    Replaced my other wing.
  31. swarcup
    swarcup Well-Known Member
    1,326
    40
    How long to get to this stage ! And anything to look out for. I am going to do both wings soon
  32. ruffrida
    1,926
    313
    Stage 1&2 polish kit. She is all shines again lol.
  33. AudiLeon
    2,249
    192
    The entire job with a brew is an hour bud.
    Nothing to look out for really.
    Jack the car up. There are about 6 screws in the archliner it's self.
    Pull off the fog light cover and there is a bolt in there holding the bumper on. Undo that 6mm allen key.
    Remove the arch liner. 2 screws hold a cover up against the gap to the front of the door. Remove that.
    You'll then see 2 bolts holding the wing. Undo them.
    Open the door. You'll see 1 at the top holding the wing on. Remove that. 1 at the bottom holding the sill trim. Lift up the plastic channel along the top of the sill trim and remove 4 bolts along.
    Under the sill trim outside, you'll see bolts. Remove the length to the end of the door. You can then pull the sill trim away enough. Remove the 3 screws that hold on the plastic holder. Then there's 2 bolts holding on the wing.
    To the front of the wing. There are 3 nuts holding the front bumper to the wing. Remove these.
    Pull the lower plastics of the bumper away from the wing and the bumper will move forward. You'll then see a black bolt holding the wing on.
    Then there are 4 bolts under the bonnet. Remove these and it'll lift off.
    When you refit, loosely fit all bolts so you can shift it around. If it's like my wing. You'll need to tighten the top and bottom bolts nearest the door and pull the wing out by hand to meet the line perfectly.
    audilad9 and swarcup like this.
  34. swarcup
    1,326
    40
    Cheers bud, I suppose I should get them painted and then fit them do you think. Just looking did you put the front into service position
  35. AudiLeon
    2,249
    192
    I just bought mine pre painted. Seemed good enough.
    Nah, not into service position. When you remove the three nuts holding the bumper to the wing and the 6mm allen key bolt in the fog light cover hole. The bumper will just pull forward enough.
  36. audilad9
    audilad9 Member
    257
    Doing this shortly, do you have a link for the wings you used ?
    Did the paint match good ?
  37. AudiLeon
    2,249
    192
    audilad9 likes this.
  38. mattyb6
    977
    75
    Carbon wrapped my outside b pillars the other day, looks good. I'm doing the triangle bits on the rear doors today.
    Pics later
  39. A4sportMrT
    A4sportMrT Member
    273
    23
    Bought some new wheels today, just need tyres which will probably cost more than the wheels
  40. DieselJake
    2,830
    699
    Pictures! :yum:
