What have you done to your A4 b6 today?
krisavant Mar 18, 2014
  1. louis_123
    louis_123 Active Member
    197
    37
    Nah I didn't do the heated seats cause I haven't got the panel and I don't see the point really.
  2. Cobra88
    Cobra88 Active Member VCDS Map User Audi A4 Audi Avant Owner Group TDi
    553
    70
    Fitted my repair wire to extinguish my washer warning after turning on full DIS.
    there was no pin 1 in my connector so glad I bought repair wire now :)
    Painted my grill surrounds black.
    DieselJake, Icarus83 and ruffrida like this.
  3. louis_123
    197
    37
    Looks good :)
  4. andy.l
    andy.l Member
    224
    20
    Fitted my new bonnet at last, brand spanker grille also. Clay barred it so far but hopefully get some wax on there over weekend, looks much better with the fresh grille now.
  5. KO_81
    KO_81 New Member
    10
    Cleaned out my EGR valve and then blanked it off.
  6. Welshquattro
    Welshquattro Active Member Team Mauritius quattro Audi A4 Audi Avant Owner Group
    759
    136
    43
    Post some pics when ur done m8
  7. Cobra88
    553
    70
    Replaced the passenger front wondow mechanism
    Ah what fun
    Also fitted a new boot release motor.
    If anyone needs a new Avant Boot catch just shout as i can sell you a brand new genuine one cheap
    (Was the release motor not catch) doh!
    Might get the aircon regassed next week as its cold but not as icey as my 8L was.
    Now off to Bawdsey with the Mrs to watch the Sunset
  8. bradh
    bradh Active Member VCDS Map User
    558
    58
    DieselJake, louis_123 and mattyb6 like this.
  9. lowlife89
    lowlife89 Member
    184
    19
    Looks awesome, what paint did you use?
    Do you have the part number? mine's not working anymore :(
  10. WOLF
    WOLF Well-Known Member
    1,201
    270
    Gave mine a full detailing today..........long overdue!
  11. Cobra88
    553
    70
    Hi Lowlife89
    I used some PJ1 crankcase paint i had on the shelf with some hibuild primer after stripping the grills and keying them with 400 wet&dry paper .
    Rick
  12. Cobra88
    553
    70
    Ordered my twin exit Sport Avant rear valance from Audi
    8E9807521A7DL £92.90 :)
    and the foil sticker
    8E9807800A £23.44
  13. AlexGSi2000
    AlexGSi2000 Well-Known Member VCDS Map User
    1,464
    199
    Refurbished my wheels the other day as they were starting to look a little tired;
    Welshquattro likes this.
  14. Welshquattro
    759
    136
    43
    How long did it take and what paint did you use? Washed the car last week and now can see how bad my wheels are so might have a go!
  15. easy going Si
    easy going Si Member
    101
    fitted x-tool with Iobd2 but alas no oil temp, volt or oil pressure but VDO come to the rescue bottom set of gauges need plumbing in
  16. ruffrida
    ruffrida Well-Known Member
    1,926
    313
    Is that not 2 sets of gauges for everything? Bit of an over kill is it not !!
  17. Cobra88
    553
    70
    Bought a set of Genuine S4 Avus rims :)
  18. ruffrida
    1,926
    313
    Check you out, no stopping ya now is the Rick, hahaha, good on ya
  19. AlexGSi2000
    1,464
    199
    Took the whole day - the key is to take your time and use good quality products. The finish is determined by the prep work, it can be a little tedious but you get out what you put in.
    1 - Clean and degrease the wheel thoroughly - remove any old wheel weights & sticky pads.etc
    2 - Use Araldite liquid metal to fill any kerbing to the outside of the rim (I use my finger for this to get a smoother finish)
    3 - Wait a few hours for the liquid metal to cure, then sand to the shape / curve of the wheel using 600-grit.
    4 - Key the rest of the wheel using 600-grit and then 1200-grit on the outside surfaces (this will take the time - make sure you get every part of the wheel otherwise you have the risk of the new paint flaking)
    5 - Clean the wheel - if the finish is good, you can paint onto the keyed surface (no need to prime if the wheel is in decent condition)
    6 - Mask the wheel using thin tape for the inside of the tyre that sits close to the rim, then wider tape to protect the sidewalls.
    7 - Spray the wheel - 3x light dustings - allow the paint to cure for 30/45 mins
    8 - Lacquer the wheel - 3x medium coats to give a glossy smooth finish.
    Allow the wheel to cure for at least 2 hours before fitting to the car - try not to drive the car for 24hrs otherwise you run the risk of brake dust bonding to the fresh lacquer.
    I get my paint from my local autopaints and use ProXL lacquer (nothing comes close to it in rattle can form) - I have done about 20 sets now.
    Alternatively - you can pay me £40 per wheel! :happy:
  20. ruffrida
    1,926
    313
    Dropped me fog light grills of at the sprayers to have them color coded !!
  21. Welshquattro
    759
    136
    43
    Thanks Alex,will stop on way home and pick up some Araldite liquid metal and pop in my local paint supplier.Have Friday off so have three days if needed.lol
  22. TwedA4
    TwedA4 Member
    111
    done my rear brake pads last night. took me a while but it's the first time i've touched brakes on something that doesn't have pedals lol.
    stops much better and no squeals too :D
  23. swarcup
    swarcup Well-Known Member
    1,326
    40
    Tuning box fitted
  24. Ralphthemouth
    Ralphthemouth Active Member
    147
    30
    Fitted a set of nightbreakers, cleaned the MAF and fixed my intermittent left indicator. A metal connection in the headlight housing has been shorting and gradually burnt away leaving an empty hole where it should touch the bulb carrier. Can spares be brought or is it a new headlight?
  25. john777w
    john777w Active Member
    647
    85
    Cleaned out the EGR Mucky.com
  26. Cobra88
    553
    70
    Yeeha
    My S4 Rims just turned up
    Off to get a mate to tyre swap from my RS4's
    Will have my RS4 rims for sale later :)
    opened first box and saw this
  27. deano1978
    deano1978 different gear
    713
    81
    Interesting.get some piks
  28. ruffrida
    1,926
    313
    Used it as an avant. And took some wood to me old man,wish it looked this low all the time lol. Thank god his industrial hoover was working. It was mingin inside,but ya got to look after ya olds,so all good lol
    WOLF, louis_123, sumo and 1 other person like this.
  29. IanFM
    IanFM Active Member quattro Audi A5 TDi
    452
    81
    Fitted my new steering wheel
    Cobra88 and BakPak like this.
  30. IanFM
    452
    81
    I hope its going to be worth it!
  31. Cobra88
    553
    70
    Have put my 9 spoke RS4 wheels up for sale in the classifieds :)
  32. ruffrida
    1,926
    313
    You giving it a pair of black eyes??
    A separate "how to" thread would be cool!! Thats if you are lol
  33. WOLF
    1,201
    270
    The Bad Ass avant gets lowered ruff:yes:
  34. Mike.M
    Mike.M Well-Known Member
    2,477
    169
    Car went into paint and spent the afternoon fully detailing the inside and out of the wife's Mk5 Golf
  35. Cabbyfan
    Cabbyfan Active Member
    840
    34
    Fitted new pads on my rears. What should have taken 30 min took a bit longer cos I managed to cross thread one side of guide pin bolts.... Re tapped and sorted though thankfully.
  36. ruffrida
    1,926
    313
    Hahhaha nice 1 wolf,i wish it wa tha low,fingers crossed for when me springs go on lol.
    Got me trip stalk on its way and the wire, goin give her some forte turbo cleaner aswel,peace of mind at 170k +.
  37. bradh
    558
    58
    Another one for a how to build please
    ruffrida likes this.
  38. Dobermansteve
    Dobermansteve Member Audi S3
    99
    34
    Treated the car to a nice service, new tfsi coilpacks, snubnose mount, forge recirc valve and a new check valve it's running sweet again!
  39. lowlife89
    lowlife89 Member
    184
    19
    Dobermansteve: yours is a 1.8T I reckon? how much did you pay for the tfsi coilpacks and can you make a comparison?
  40. Cobra88
    553
    70
    My Westfalia detachable towbar kit arrived in the post :)
    So I can take Ducati to trackdays after selling my Van last year :(
