What have you done to your A4 b6 today?
krisavant Mar 18, 2014
  1. Greeny233
    Greeny233 It's all about the V8. Team V8 Team Silver Audi S4 Audi Avant Owner Group
    1,094
    385
    Today I ordered a new set of wheels for the Avant. I'm tired of trying to keep the old LM reps clean and tidy.
    I kerbed both passenger side wheels the other day and I've had to remove all the lacquer from the front wheel and try to polish it up but it's not worked to well.
    I'm sticking with the staggered fitment but I'm going with Momo Sentry wheels in mat black, 8.5x19 fronts and 9.5x19 rears. The rears look particularly good with a nice concave dish.
    Oh and finally got round to fitting my engine covers
    boytrigg likes this.
  2. ruffrida
    ruffrida Well-Known Member
    1,926
    313
    Nice.
    Greeny233 likes this.
  3. A4sportMrT
    A4sportMrT Member
    273
    23
    I want those engine covers! Are they engine specific?
  4. quattrojames
    14,050
    576
    TwedA4 and A4sportMrT like this.
  5. ruffrida
    1,926
    313
    And pretty rare!
  6. quattrojames
    14,050
    576
    The covers? Between about £10-30 at the dealers...
  7. ruffrida
    1,926
    313
    Are the?? Thought these bad boys were becoming rare, defo having a look into them then, makes the engine bay look so much tidier!!
  8. A4sportMrT
    A4sportMrT Member
    273
    23
  9. Greeny233
    1,094
    385
    I think they are for an S4 hence a little bit of trimming for the top water hose to fit.
    Both covers from TPS were £16.60 each plus vat.
  10. deano1978
    deano1978 different gear
    713
    81
    I got a full set off a 3.0 a4, £40
    So worth checking for breakers,and ebay.
  11. BakPak
    BakPak No Gear
    957
    137
    43
    New suspension and fixed a puncture.
  12. K33n6n
    K33n6n New Member
    I had to change this as she decided to give me no power!!! The feeling when you go to pull away and that ESP light says no! [​IMG]
  13. Greeny233
    1,094
    385
    Had the old girl Terracleaned this morning at Bowling Bank Garage in Wrexham. I can't begin to tell you the difference it has made. As soon as I started the car after it was noticeable smoother, quieter and as soon as I pulled off I could tell there was more oomph! I'll let you know how the fuel economy is after a few more miles but I suspect there will be an improvement. At £100 it is well worth it.
    The guys at Bowling Bank are top guys and ran through ever step of the process and explained how it works. If you are in the Wrexham area then I would whole heartedly recommend them (and the boss has a lovely RS4).
    mattyb6 likes this.
  14. andy.l
    andy.l Member
    224
    20
    Started to prep and paint my replacement painted sideskirts to loose the elephant grey bits
  15. rob0904
    rob0904 Member
    205
    13
    Not me but the misses managed to dented the rear quarter. So my job is to see if i can fix it without costing the earth. Is there any way to get at the inside of the rear quarter, right behind the tail light.
    Any help would be great.
    Rob
  16. bradh
    bradh Active Member VCDS Map User
    563
    58
    Yep but it means removing most if the boot trim to do so can be a but of a pain to remove
  17. ruffrida
    1,926
    313
    Put a new thermostat in, temp reading bang on 90 now, and i swear it runs loads better!!
    TheDriver likes this.
  18. barkclark
    barkclark Active Member
    909
    148
    43
    I definitely need to fit my thermostat! Heard too many good story's not to!
  19. ruffrida
    1,926
    313
    Get it done, just watch the rubber seal when you put it back in, mine took 2 attempts unfortunalty as theseal had popped of very slightly, so as soon as it got warm enough it fired a small stream of bloody water out
  20. mattyb6
    mattyb6 Active Member
    977
    75
    I need a thermostat too,
    New led bulbs in today, and may start to adjust front coil overs up and fit a new top mount.
  21. TheDriver
    TheDriver Active Member
    264
    So another thermostat did the trick hey? Good stuff!
  22. ruffrida
    1,926
    313
    yeh, the other one / original 1 i put in was not moving at all, when i got it out it was seized. but all is good now, nice 1 The Driver, this seems to be a common problem with the B6!
  23. andy.l
    andy.l Member
    224
    20
    Removed the cracked elephant grey side skirt from O/S and refitted the freshly painted replacement, discovered that most of the retaining torx screws were rusted and the plastic grommets were past their best resulting in them spinning in the shell, new fittings ordered. Also bought some Seat Exeo front mudguards.
  24. ruffrida
    1,926
    313
    Are the exeo larger than A4's then??
  25. andy.l
    andy.l Member
    224
    20
    Pass, read in a few places that they fit the B6, bought front and rears now so will get some pics up when I've fitted them.
  26. Greeny233
    1,094
    385
    Well today i had the cam belt, pulleys, water pump and a front wheel bearing replaced also took delivery of some Sony replacement speakers but got the wrong adapters sent out by the supplier so waiting for replacements.
  27. Greeny233
    1,094
    385
    New Sony speakers fitted, the wiring adapters supplied with the speaker adapters by Autoleads (SAK-1107) had the wrong plug connector on the end so i just cut off the plastic and used the male ends to push into the cars existing speaker plug.
    The sound quality is far better. The old original speakers look in good condition, no rips or tears so if anyone needs a set of OE replacement speakers then i have some.
  28. deano1978
    713
    81
    Which head unit u running.
    What size speakers did u get.
  29. MooLard
    MooLard Member
    229
    Fitted my new air con rad and thrust sensor today, second time lucky, here's hoping the pipe seals are still good.
  30. Greeny233
    1,094
    385
    Deano - I am using the cheap and Chinese Xtrons direct fit unit for the A4, it has bluetooth, iPod connectivity, satnav and sd card slots and works ok for the money, it has a built in amplifiers 4 x 45w.
    I bought 2 of these packages off eBay
    AUDI A4 (00-08) - Front SONY Car Speakers + Speaker Adaptors - SAK-1107 | eBay
    Both front and rear doors use the same speakers and adapters.
  31. deano1978
    713
    81
    Looks good,like ur little ipone mod ;-)
  32. Greeny233
    1,094
    385
    Today i ordered a complete S4 front brake set up off Adamss24. Going to clean up the callipers and give 'em a lick of paint and maybe fit some of those nice S4 anti-rattle clips. They should look amazing behind the 3SDM wheels.
    Maybe i won't be buying these clips, they are £137 from the states :wtf:
    barkclark likes this.
  33. bradh
    563
    58
    how much for clips!!!!!
  34. Greeny233
    1,094
    385
    Thats what i said!
    $89.95 per clip and $51 for shipping! There is an Audi part number for them (8E0615269). So i'll see if TPS can supply them and see how much they want.
  35. TwedA4
    TwedA4 Member
    111
    been fitting a new HU and speakers over the last few days. fronts are wired up with new speaker cable and working with my alpine radio. rear drivers speaker is fitted and RCA's run down the side for a amp, just need to do the passenger rear and run power to the back. :D
  36. bradh
    563
    58
    Just a small thing but finally fixed why my drivers side rear light was sticking out last owner bodged a bolt that was 2 inch long with a nut on it and just pushed it into the nut on the light unit but thanks to super ron off hear breaking his a4 I fitted new proper bolt and hey presto it's fits nice and snugly now :)
  37. ruffrida
    1,926
    313
    Fitted a new set of brake pad / caliper retaining clips,peace at last lol
  38. Icarus83
    Icarus83 Active Member
    241
    71
    If you go to a main dealer they are about £43 each I think (but can't remember if that inc or ex VAT), I managed to buy one on eBay for £20 but need a second one obviously......so will buy one when funds allow! I'll take a PIC of the OEM box mine came in so you have the correct part number.
    Also the same rattle clips were used on the newer S3 and a couple of other models so it'd be worth seeing if there is any massive difference in price and spraying/sticking S4 decals on if they are significantly cheaper!?
  39. Greeny233
    1,094
    385
    Thanks Icarus, the part number would be great!
  40. haytch75
    haytch75 Member
    176
    17
    Mr Muscle'd my turbo. Noticeable results again. About 2 years since I last did it.
