What have you done to your A4 b6 today?
krisavant Mar 18, 2014
  1. A4sportMrT
    A4sportMrT Member
    273
    23
    Haha its a dark maroon, pictures definitely don't do the colour justice.
  2. ruffrida
    ruffrida Well-Known Member
    1,926
    313
    Pisser, does look very pink though, not to my tatse !!
  3. ruffrida
    1,926
    313
    Tell me more, done nearly everything, still only gets to 70c if it makes it to 90c fans kick in and bring it back down !
  4. TheDriver
    TheDriver Active Member
    265
    Have you changed the stat yet dude? (guessing you must have)
  5. ruffrida
    1,926
    313
    Yeh stat is fine dude. The mad thing is. It used to get warmer with an old sensor in. Goin to have to have a look at the connectors
  6. barkclark
    barkclark Active Member
    996
    205
    43
    I've heard of some people changing back to the old sensor when the new one made things worse..
  7. TheDriver
    265
    That's mad!? Don't suppose there could be any issues with the new sensor you put in? Can't offer over much help tbh, neveer really paid attention until I read some threads on here, then noticed mine hovers between 70 and 85, thought I just had a very efficient engine/cooling system LOL! New stat cured it, immediately up to 90 and stays there.
    Strange that. Thought it could only be stat or temp sensor... Would it be worth trying another sensor on it?
  8. Jimmy TDI
    Jimmy TDI Pro Tinkerer Audi A4 Audi Avant Owner Group TDi
    1,320
    262
    Did you fit a genuine CTS, as the cheap eBay ones never last long if they do work at all.
    I'll check the cts with VCDS for you mate. Sometimes they don't throw a fault code up, but if you check the measuring block for coolant temp it shows a completely different temp to the dash.
  9. sabaxter
    sabaxter Active Member
    465
    27
    Try another sensor and if no avail a new stat. Mine only went to 65 degrees and I was told this could effect economy so I changed it and ir went streight to 90
  10. ruffrida
    1,926
    313
    Nope both genuine parts, goin get another set and see wha go on!
    Don't do ebay buys when it comes to parts like that,will try 1 at a time and go from there.
    Nice1 jim!
  11. mattyb6
    mattyb6 Active Member
    977
    75
    Isn't there two cts sensors on the 1.9
    One for the temp gauge and one for ecu?
    Could be worth changing then both with a new stat
  12. TheDriver
    265
    Sure I read somewhere that the new style Green 4-pin CTS houses both ECU and temp gauge sensors...does that sound right or no?
  13. Jimmy TDI
    1,320
    262
    Only one on these, the driver is correct.
  14. quattrojames
    14,060
    583
    My AVF has two CTS, one at the back, and one down by the lower pipe into the radiator on the nearside.
  15. mattyb6
    977
    75
    Aw well I stand corrected lol
    So only the one below the tandem pump on the 1.9 awx then?
  16. ruffrida
    1,926
    313
    The is another! Mine is also a avf engine, is that a 2 pin 1?
  17. pauldazzle
    pauldazzle Well-Known Member
    1,191
    95
    My AVF has the green dual CTS below the tandem pump, The other 2 pin by the rad is for the fan switch.
  18. pauldazzle
    1,191
    95
    That's correct.
  19. ruffrida
    1,926
    313
    That's what I thought!
  20. ruffrida
    1,926
    313
    Pit me colour coded grills on,look good. [​IMG]
  21. pauldazzle
    1,191
    95
    Today I fixed my broken front armrest lid, & did 199k service with Quantum platinum, VAG filters & Forte diesel fuel system cleaner.
  22. Jimmy TDI
    1,320
    262
    New front lower arms, front ARB drop links, front ARB bushes, painted calipers, and EGR clean with new gaskets.
  23. TheDriver
    265
    Do all that yourself Jimmy?
  24. Jimmy TDI
    1,320
    262
    Yeah mine only has the one.
  25. Jimmy TDI
    1,320
    262
    I did mate, today was tinkering time.
    Well my springs didn't arrive today, but I've been told they will be here in the morning. I'll be honest I'm not holding my breath.
    I cracked on with the other parts today anyway, and did a couple of other bits that I had planned for next week.
    Front lower arms
    Front ARB bushes, and drop links
    Dismantled the B5 shocks and fitted the perches to my new shocks
    Painted the front calipers why it was sunny
    Cleaned the egr and elbow that connects to it, and replaced the seals
    Some pics of the old battered bushes
    The EGR wasn't that dirty, and tbh didn't really need cleaning, but while I had it off I gave it a quick clean anyway. I suspect it has been cleaned before because I could see scratches in there. I was going to clean the inlet too, but as there was hardly any build up I've left it for now, but I already have the gasket for when I do.
    It now feels like a new car on the twisties, the steering is much more responsive and steady through bends. I can't wait to get the new shocks and springs on, and have a four wheel alignment now.
  26. Jimmy TDI
    1,320
    262
    Double post there sorry
  27. TheDriver
    265
    My goodness, you have been busy today...well in lad!
    Bet it feels nice and solid now. :)
  28. Jimmy TDI
    1,320
    262
    Yeah mate feels like a new car, I can't wait to get the H&R's and new shocks on now. Once it's had a full four wheel alignment it should be planted.
  29. TheDriver
    265
    Yeah defo, with brand new shocks and springs and all that work you'll be bear-hugging the streets of Mancunia! You got an RS4 rear anti-roll bar yet? That's next on my list seeing as the collars are cracked already....
    Where did you get all the bits, AllGermanParts?
  30. BakPak
    BakPak No Gear
    957
    137
    43
    Replaced drivers side window regulator yesterday. It was a lot easier than I expected, £66 from GSF in Shrewsbury which wasn't too bad either.
    Unfortunately the Germans are not playing ball regarding the suspension I ordered 5 weeks ago. They keep putting back the production date. More like they are supplying their national dealers ahead of shipping to UK dealers.
    Ah well give the Audi a good clean, I might even get the purple Dyson out.
  31. Jimmy TDI
    1,320
    262
    Got the nose down last night :thumbsup:
    No ARB as of yet mate, but it's on the list.
    Shocks were from eBay, arms and links from euro car parts (Lemforder), and the springs are from Awesome GTI
    Here's a comparison of the ride heights
  32. ruffrida
    1,926
    313
    Looking well jim,you have been busy,good lad,like ya style, how long did it take you?
  33. Jimmy TDI
    1,320
    262
    Spent about 9hrs on it over Friday/Saturday mate. The suspension on these is hard work, but it was all worth it when I dropped it down off the stands.
  34. ruffrida
    1,926
    313
    Yeh looks "another" fun job lol
  35. Jimmy TDI
    1,320
    262
    It's the only car I've thought about giving up on, and sending to my mates garage when it comes to lowering.
    Although if the springs had turned up on Friday like they were supposed to, I could have done it all together so it would probably have been easier.
  36. madmike01uk
    madmike01uk Member
    430
    21
    Fitted new pagid front discs and pads after one of the pads ate itself. Don't think the old pads were very good as they are miles better already
  37. Jimmy TDI
    1,320
    262
    You can't beat Pagid, I've bought them for doing the 312mm upgrade.
  38. madmike01uk
    madmike01uk Member
    430
    21
    Mine has 312's, they are a bloody heavy disc. Brakes were always poor on my car, seem miles better now.
  39. Jimmy TDI
    1,320
    262
    I used them to upgrade to 312mm on my bora too. For the price they're good, and don't give off loads of dust.
  40. Wahlstrom
    Wahlstrom Active Member
    422
    148
    43
    Try the 345 mm S4.. Talk about heavy
