What have you done to your A4 b6 today?
krisavant Mar 18, 2014
  1. bradh
    bradh Active Member VCDS Map User
    558
    58
    Taking it for an mot this morning so fingers crossed it passes or it's summit little I cost to fix :/
  2. ruffrida
    ruffrida Well-Known Member
    1,926
    313
    Will check mine later dude, bu ti have removed it so no longer needed, never used it so sorry dont know if it works !!
  3. bradh
    558
    58
    Mot passed flew threw whoop whoop
    BakPak and ruffrida like this.
  4. BakPak
    BakPak No Gear
    957
    137
    43
    Sound dude, more money to spend on goodies instead!!
  5. mattyb6
    mattyb6 Active Member
    977
    75
    Here jake.
    The rear triangle but was awkward as I couldn't remove it and the rubber trim was in the way and was frightened I didn't cut it.
    ImageUploadedByTapatalk1398271321.518703.jpg ImageUploadedByTapatalk1398271337.177261.jpg ImageUploadedByTapatalk1398271349.135180.jpg
    BRILLO, DieselJake and WOLF like this.
  6. bradh
    558
    58
    Let us know I might be able to make a working one out of 2 motors :)
  7. WOLF
    WOLF Well-Known Member
    1,201
    270
  8. jdw88rm
    jdw88rm Member
    167
    MOT passed with no advisories. Kiss my face
  9. mattyb6
    977
    75
    Thanks wolf
    Appreciate it!
  10. AlexGSi2000
    AlexGSi2000 Well-Known Member VCDS Map User
    1,464
    199
    Fitted S4 300mm rear brakes to match my fronts.
    Didn't think adding the rears would make much difference - it stops on a penny now!
    Icarus83 and ruffrida like this.
  11. mattyb6
    977
    75
    I've only got 256mm or 280mm up front never mind the rear with 300mm lol
  12. chasdrury
    chasdrury Member
    361
    17
    Looks great - is that just calipers / carriers / disk and pad swap?
    Chas
  13. AlexGSi2000
    1,464
    199
    Yep.
    Only adjustment was with the brake dust guard behind - a simple hole needs to be drilled in the guard so that it mounts (the screw holes are in different positions on the S4).
    ruffrida likes this.
  14. ruffrida
    1,926
    313
    Really liking this!!
  15. chasdrury
    chasdrury Member
    361
    17
    Great - thanks!
  16. swarcup
    swarcup Well-Known Member
    1,326
    40
    VERY NICE! what model S4 B7?
  17. AlexGSi2000
    1,464
    199
    They came off a B6. I think B7 calipers will fit as-well.
    The S4 brake setup is much, much better than the standard A4 312/255mm's - can recommend it highly - easy bolt on upgrade too.
  18. BakPak
    BakPak No Gear
    957
    137
    43
    Local garage removed the egr link pipe and fitted two blanking plates. Also re-sealed the egr - inlet manifold coz it was weeping, well I assume it was but it might be the vacuum thing on top. Anyway he cleaned the egr too and it does seem to pull better but that could just be the rose tinted specs!
    Still waiting for the suspension but Damien at DPM is on the case! Hoping to get the aircon working tomorrow.
  19. A4sportMrT
    A4sportMrT Member
    273
    23
    Received my new wheels today, just need to get some rubber on them!
    ei2gfb likes this.
  20. Andy_w
    Andy_w Member
    55
    Changed the grey interior in my 1.8t for a nice black one:yum:
  21. louis_123
    louis_123 Active Member
    197
    37
    Fitted a nice touch screen dvd/cd player :) it sounds soooooooo much better.
  22. ruffrida
    1,926
    313
    Wasted half a day waiting for me hung over bruv,gave up with him and fitted me twin exit rear bumper with parking sensors,everything is awesome lol
    Welshquattro and TheDriver like this.
  23. Jimmy TDI
    Jimmy TDI Pro Tinkerer Audi A4 Audi Avant Owner Group TDi
    1,320
    262
    Cleaned it after the school run
    Welshquattro, ruffrida and ei2gfb like this.
  24. audilad9
    audilad9 Member
    257
    Fitted S4 door mirrors today. Pain in the ass dismantling the door/ window/regulator etc just to unclip and clip in the new cable :banghead:
    Thought about chopping/soldering cables but rather do it right.
    Happy with bling result :icon_thumright:
    On a sadder note the battery has finaly died :( Did alright at 10 years I suppose ;)
    Away to price and find a new battery tomorrow, hopefully a Bosch as per original.
  25. Tobester
    Tobester Member
    49
    21
    Andy_w, deano1978 and Icarus83 like this.
  26. Andy_w
    Andy_w Member
    55
  27. ei2gfb
    ei2gfb Member
    101
  28. Jimmy TDI
    1,320
    262
    Andy_w and ei2gfb like this.
  29. Icarus83
    Icarus83 Active Member
    241
    71
    Did you experience quite spongy brakes when you first fitted them (both front and rear)? Wahlstrom reported the same and had to bleed his several times.
    Waiting to get mine back from the garage then will have a go at bleeding them again once they have had a chance to bed in!
  30. Jimmy TDI
    1,320
    262
    You need to bleed these cars with a pressure bleed system such as the Gunsons Eezibleed, or VCDS in the correct order to do it properly. Using the old school method just mashes the seals in the master cylinder.
  31. Tobester
    Tobester Member
    49
    21
    (Now I've got the missus seal of approval!) Here's some photo's of my custom stainless steel exhaust being made specifically for the car and fitted last week. Pictures of the 11 year old original to start with:
    001.jpg Ignore the box at the very top right of the picture.
    002.jpg What remains of the old flexi hose, it was like paper!
    003.jpg It was blowing from the junction of this Y section.
    004.jpg Looking up past the new front flexi towards the cat (still standard . . . for now)
    022.jpg Looking towards the back, notice no middle box :)
    024.jpg A closer view of the new Y section
    011.jpg I've tried to keep the tail as standard as possible
    012.jpg A close up of the new n/s pipe. The silencers are half the size and weight of the originals.
    And yes, it sounds amazing! A low burble at idle developing into a full roar when your right foot gets heavy, and it's tuneful too.
    I had it done at www.pipetech1.co.uk just outside Scarborough. Len is a top bloke who will do anything to help and ensure you're happy with the result. He does all his own pipe bending, welding and silencer construction on site and will design and build the system to match the car. He's reasonably priced too. My system was comparable to a similar Powerflow one and the same as a Magnex (excl. fitting) one but of course it included free fitting and the knowledge that I have a bespoke system.
    He will happily make any exhaust for any vehicle, but while I was there he had a constant stream of happy VW, Skoda and Nissan owners popping in a for a chat and a cup of tea and just to watch him work. He'd recently done a full exhaust on an S4 and so is pretty familiar with B6's.
    Andy_w likes this.
  32. Had it detailed yesterday :)
  33. Dobermansteve
    Dobermansteve Member Audi S3
    99
    34
    Cracked my windscreen today! Not happy - another item on the list!
  34. Tobester
    Tobester Member
    49
    21
    Andy_w and A4sportMrT like this.
  35. audilad9
    audilad9 Member
    257
    Fitted a nice new Bosch S5 battery after original Moll died at ten years old.
    Had thought performance was down recently, cured now.
    Eurocarparts "click and collect" via ebay produced a very good deal.
    Cleaned out scuttle area and grommets thoroughly whilst in there too.
    Currrently painting up my S4 calipers for fitting at weekend.
    Tinted the front foglights with fly eyes too :)
  36. Wahlstrom
    Wahlstrom Active Member
    399
    144
    43
  37. bradh
    558
    58
    ImageUploadedByTapatalk1399151118.140944.jpg ImageUploadedByTapatalk1399151124.796071.jpg ImageUploadedByTapatalk1399151132.451149.jpg ImageUploadedByTapatalk1399151136.954754.jpg
    Made the bro in law clean my car using angel wax and auto bright stuff clean pics tomora :)
  38. Andy_w
    Andy_w Member
    55
    I took inspiration from barkclark and carbon wrapped my grille surrounds last night. A big improvement,
    barkclark likes this.
  39. barkclark
    barkclark Active Member
    909
    148
    43
    Looks great!!
  40. Andy_w
    Andy_w Member
    55
    Thank you sir, have you done your Audi rings matt black?
    Oh and do you have a link to your bulb supplier?
    I really fancy ice white bulbs.
