What gearbox and Possible Problem!
aadams1x Oct 9, 2008
  1. aadams1x
    aadams1x Member
    69
    Hi. Looking for some advice, I know this sounds crazy but I do not know if I have a DSG Box. I have just bought an Audi A3 2.0 FSI 53 plate. The Gearbox is silver in colour and I do have the flappy paddles on the wheel. Is this the DSG box or just a standard auto?
    Also the Box appears to be quite Jerky, particularly when changing down on a hill for example and when first starting out.... Is this a common problem or just a quirk I need to get used to?!
    Thanks,
    Andrew
  2. h5djr
    9,423
    1,747
    If you look in the sticker in the Service Book or under the cover in the luggage area it will tell you a gearbox code. On line 5 there will a 3 digit on the left-hand side which will be the Engine code. On the right-hand side on the same line will be a further 3 digit code and this will be the gearbox code.
    Note these numbers and let me know and I will be able to check exactly which type of gearbox is fitted.
  3. aadams1x
    aadams1x Member
    69
    Thanks, I have sent you a PM but it is GJZ
  4. aadams1x
    aadams1x Member
    69
    Thanks for the information, the search has shown up to be a normal auto box, I was not aware the normal auto box could come wioth the flappy paddles but was not sure.... Anyone got any experiences on the box not being very smooth and a bit jerky, it is due a service in Dec, could a gearbox oild change sort this? Thanks
  5. aadams1x
    aadams1x Member
    69
    anyone?
  6. Ash B
    Ash B Well-Known Member
    5,831
    84
    Sorry mate cant help you there not quite good with dsg myself lol
    Only had my first audi in july manual still learning about them
    Some one probably come along soon and help you though
  7. aadams1x
    aadams1x Member
    69
    Hi, just wondering if anyone else can shed light, does having a flappy paddle gearbox mean it is s-tronic / DSG or does the standard auto box come with the paddles? Thanks :)
  8. kaz219
    kaz219 Active Member VCDS Map User
    1,808
    I got the DSG
    I have the flappy paddles on the steering wheel.
    The gearstick where you can change gears up and down from there.
    And P R N D S.
    I had a jetta and that was DSG but didn't have the flappy paddles..it said dsg on the gearstick
    Dont know how that works out but you have the DSG which is also a S-tronic as well... as far as im aware, there is no difference between the dsg and s-tronic (and R-tronic).
    HTH
    PS. http://cars.about.com/od/thingsyouneedtoknow/a/ag_howDSGworks.htm
    As for jerky, it shouldnt be doing that. Check when the oil in the gearbox was last changed.
    Thats where i learnt it from
  9. khalil
    khalil Member
    774
    sorry to go off topic a little, but when is the gearbox oil change due for a manual 2.0tdi?
  10. synthdood
    synthdood Member
    288
    If you have a 2.0FSI engine it will be an old fashioned tiptronic gearbox, If you have the 2.0T it will be the DSG. Unfortunately the 2.0FSI was never produced with DSG.
  11. aadams1x
    aadams1x Member
    69
    Thankyou... I have an answer and will look into replacing the gearbox oil to improved the changes... Thanks again
  12. Monsoon
    Monsoon Member
    102
    Andrew. It will be a standard auto box, not DSG.
    See my recent post: http://audi-sport.net/vb/showthread.php?t=63212
    I have the same age and type of car + gearbox as you. Same problem too! Let me know if changing gearbox oil helps for you.
