what fuel economy are you receiving from your car
lanceneoman Oct 24, 2012
  1. benberry
    benberry Member
    37
    Yeah, hopefully I'll be able to get up to that once I've got used to it a bit more!
  2. boomtown
    boomtown Member
    130
    Ive once got 39 mpg cruising at 65 for 150 miles !!! i just couldnt handle it any longer !
  3. Smillie13
    Smillie13 Member
    933
    45
    My 1.9TDI Avant shows 640 when full and averages around 42 - 44 mpg around town with 55 mpg on the motorway
  4. jutlis 3.0
    jutlis 3.0 Member
    211
    22 average (s4), used to average roughly 24/25 in our old 3.0q avant
  5. Mine was pitiful sunday gone i did 440 miles from £60 of diesel in my 1.9tdi se, mainly motorway driving, but a fair bit of traffic on the way back and a fair few miles diverted from m62 from bradford to harrowgate, worked it out with price i paid for fuel, to be roughly 43mpg, think its about time i gave my car a full service :-/
  6. DieselJake
    DieselJake Well-Known Member
    2,997
    777
    I get 41mpg on my 1.9 saloon around town & motorway (I drive like a granny 'round town and a ***** on the motorway)
    I'm on 19's though plus I need a service and new tyres, hoping for 45+ after that.
  7. mookie
    mookie Member
    43
    Well the full horror of how poor my MPG is has dawned on me today when I worked it out...
    490miles from fill up to fill up (from the same remaining range and point on the fuel gauge), which works out as just over 38mpg. And it's a 1.9tdi.
    Thankfully I did cotton on to this at the weekend, and then after a quick search on here realised my temp gauge should be at 90c not 70c, so replaced the thermostat ASAP and temps are now normal. So hopefuuuuuuuuully it should equate to a more normal tdi mpg :( and approx 180miles of that was one motorway trip too. I'm thinking EGR clean is next...
  8. My temp guage has also been tempremental, i thought it was the sensor at first so got ripped off by TPS £28 +VAT for the sensor which sells on ebay for £10, (i know silly me) but guage still sitting between 65-90 and never dot on 90, so i guess my next port of call is thermostat...
  9. mookie
    mookie Member
    43
    Well mine went from a solid 70c with no fluctuation to now a solid 90c within about 10mins of 30mph driving. I just hope with the next fill up tomorrow the mpg increases accordingly.
  10. quattrojames
    14,068
    585
    Don't feel bad, the ebay sensor will be a copy part. I'd pay £30 for a genuine sensor everyday of the week.
  11. marktdisport
    marktdisport Active Member
    1,195
    15
    Usually the cts playing up the temp gauge will fluctuate fastly or go off completely.. If the gauge goes from 70-90 couple of mins at a time or so its the thermostat opening and closing so there will be the fault
  12. stu_m
    stu_m Well-Known Member VCDS Map User
    1,441
    Hopefully the stat has sorted it!
    I get from 44 - 52 depending on type of driving out of my tdi have had better, average is 48 the 44 is town driving in winter!
  13. stu_m
    1,441
    Is that from stone cold?
    Mine can take up to 25 mins to reach temp first thing in a morning but that's with the missus driving and always short shifting it warms up a little quicker when I drive just not in ten mins!
  14. marktdisport
    1,195
    15
    If your car is taking 25 mins stu to warm up the stat is stuck open slightly so its stopping the water to get to temp should be hot within 5 mins really...
  15. pbarlow0032
    pbarlow0032 Member
    167
    Getting around 33 average in my 1.8t cabriolet after having it for a few weeks and a few hundred miles. Bit disappointed actually, seems a bit lower than the 1.8t I owned a few years ago.
    temp gauge on mine seems to get to 90 after 10 mins and then drop way down again for a few minutes. Does this sound like a faulty thermostat or coolant temp sensor? Any sure fire way of finding out?
  16. marktdisport
    1,195
    15
    most likely thermostat m8... But you can plug vcds in and check for stored faults if the cts is faulty it will be there if there isn't a cts fault then your thermostat is faulty
  17. stu_m
    1,441
    It gets warm within mins at the heaters but at times can take up to 25 mins to get to 90 I must point out this is the missus driving and I bet she has the heating on full which won't help when I drive its closer to 15 mins to 90
    It's had a new stat from audi not so long back when I did the cam belt as the old one was stuck slightly! It warms up quicker then it used to!
  18. moggie93
    moggie93 Member
    96
    Hi mookie. I've got similar problems. The last week or so I've never seen over 40 mpg. It took nearly 9 miles for the temp gauge to hit 70. How hard was the thermostat to change and where on the tdi is it..
    Cheers moggie.
  19. marktdisport
    1,195
    15
    yes m8 if the heaters are set full it will take some heat out the engine so yes will take longer to warm up..... Best bet is to try it with heaters fully off and time it to 90 and make sure it stays at 90 if it does this you have no probs
  20. stu_m
    1,441
    Once its at 90 it stays there all the time I often just have the heating at about 20 and it warms up steadily usually takes about 15 mins to get there never less then that though
  21. marktdisport
    1,195
    15
    that sounds normal to me bud
  22. mookie
    mookie Member
    43
    I found a couple of good threads about it and followed their advice, plus this is a very good guide for the 1.9tdi:
    ElsaWeb - Removing, installing and checking thermostat
    It's just behind the alternator as you look at the engine from the front, just follow the big pipe from the radiator bottom corner upwards to the engine block. My problem was I couldn't get the rad pipe off the plastic housing and so it was a bit of a fiddley chore with the pipework all still connected... but only really involved two bolts and some swearing (and I disconnected the big boost pipe in the way).
    BTW after resetting my mpg average with the last 70miles on the range, covering about 30miles has yielded an average mpg in the middle 40s, which must be a good sign.
  23. pbarlow0032
    pbarlow0032 Member
    167
    So, my 1.8t on my morning drive to work takes about 8 miles/15 minutes to get to 90, then drops again and just about reaches 90 by the time I get to work (another 2 miles/5 minutes).
    how much is a new thermostat, and is there a guide to changing it anywhere? Is there anyone with VCDS near Durham, I had a look on the vCDS forum but couldn't see anyone nearby? I guess I could take it to a garage? Would rather avoid expense, only just bought the car but the seller's not interested.
  24. Mollygoogle
    Mollygoogle Member
    262
    10
    1.9 130 with a DTUK Tuning Box, drive it like I stole it sits nicely at 50-51mpg, recently had 682 miles from a tank
  25. Harribo66
    Harribo66 Member
    163
    i get around 44-45 mpg on a normal day. 7 mile comute to work.
    on saturday i got 59.6 mpg on a 200 mile run and used between half and a quarter tank.i
    have a 1.9 tdi 130
  26. adamss24
    adamss24 Well-Known Member
    4,584
    408
    B6 avant 1.9Tdi with remap, Bv43 turbo, 18" wheels, EGR delete, will do 600 miles/960Km on a tank full/44Mpg on the DIS. Occasional high speed blast on motorway and commuting in London.
    B6 V6 tdi quattro sport will do 500 miles/38Mpg on a tank with a thermostat stuck open at speeds over 100mph. Needs a service and is running on 17" alloy wheels...
  27. Smillie13
    Smillie13 Member
    933
    45
    My best so far !!
  28. the_cueball
    the_cueball Active Member
    496
    218
    43
    lowest for a tank was 13.5
    best has been 22.8
    average since owned is 17.9
    and running costs are £3.94 / mile
  29. Smillie13
    Smillie13 Member
    933
    45
    Is that an app ?
  30. the_cueball
    496
    218
    43
    its called road trip
  31. Smillie13
    Smillie13 Member
    933
    45
  32. peposhi
    peposhi Member
    44
    1.9tdi 130bhp Avant, automatic
    530-550 with a tank of diesel for the last 3 months...
    This month I'm playing around with the cruise control, a lot. Looks like I may get 650 - ish or even more. 340 from a half tank so far...
  33. Smillie13
    Smillie13 Member
    933
    45
    I always use my cruise control it makes so much difference. :)
  34. BahnStormer77
    BahnStormer77 BahnStormer
    2,782
    61
    Cruise control might make you more disciplined in terms of not booting it everywhere but it will be worse that genuinely disciplined driving on the pedals.
  35. simon.m
    simon.m Active Member
    2,747
    just looked into mine being the 100bph tdi used 25l got just over 200miles but that is just school runs so 36mpg ish just 25l in again when for a short run 20miles max speed 60 but mostly 40mph 330miles brings it in at 60mpg and to be fair the cars dis is nears as spot on
  36. peposhi
    peposhi Member
    44
    I actually think the cruise control was invented and meant to be for people with heavy right foot... like me :)
  37. Smillie13
    Smillie13 Member
    933
    45
    Peposhi your post made me laugh out loud lol :salute:
  38. BahnStormer77
    2,782
    61
    It's good for saving your license, especially when there's temporary speed restrictions. Like setting an in-car speed limit at 95mph.
  39. da4
    da4 New Member
    20
    This is what i'm getting [​IMG]
  40. AndyF
    AndyF Member
    My 2.0 Avant does 25 mpg, with a bit of motorway driving I got it up to 28. Reading posts in this thread I'd get the same from a 3.0 Quattro!
