What frequency am I ?
d4mo Feb 21, 2009
  1. d4mo
    d4mo Member
    100
    Guys,
    I want to get myself one of the many audi remote 'plip' flip key fobs from ebay and get it programmed to work my remote central locking ( a friend has VAG com and has offered to set this up) however I'm unsure as to which frequency fob I need to get as I dont have the original to check against for part numbers.
    Is there anyway I can find out by using the part number of the central locking pump that is located in the rear drivers side of the car?
    Damo
  2. olds_kool
    olds_kool Active Member VCDS Map User
    1,089
    if part number starts 4D0 it will work with b5's, dont buy if it starts with 4Z0
  3. Blue_Thunder
    Blue_Thunder Well-Known Member
    1,767
    31
    Don't know if it's that simple. My 98 B5 S4 key starts with HLO.
  4. stub
    stub the matrix is comin
    143
    i would of thought the best thing would be to ask audi themselfs. i'm sure they'd tell you it:kissmyrings:
  5. olds_kool
    1,089
    key fob 2 button part number 4D0 837 231
    3 button part number 4D0 837 231A (will work with 'G' pump but boot release button wont do anything)
    http://cgi.ebay.co.uk/Audi-2-button...3286.c0.m14&_trkparms=66:4|65:1|39:1|240:1318
    better off using an auto locksmith, not dealer, dealers wont give you 4 digit skc so you cant add any more keys yourself with vag com also if transponder wont recode (common with ebay keys) they cant replace it so they'll charge for not being able to programe it
    HL0 part number is for an a3 but will work as a3, a4, a6 and a8's all used the same c/l pumps
  6. Siena
    Siena Active Member
    2,626
    If you need operating frequency, PM me your VIN, and I'll run it through.
