What engine can I put in?
doddy Oct 7, 2011
  1. doddy
    doddy New Member
    Hi everyone, I have just aquired a prestine 2000 1.8T A6 with the APU engine fitted. It seems as though it has dropped a valve into the cylinder and smashed it against the plug, probably putting a hole in the piston but cannot be sure until i remove the head. From what I have read it should be a DBW, 150bhp, 9.5.1 CR and small ports not sure what all the specs are of this engine i.e cast/forged crank, vvt/non vvt. My question is are all the engine codes basically the same bare block? Which codes could I use to make the car whole again without any mods (swap out swap in)
    Could I put in a AUM or AWT without any problems for the ECU.
  2. jcb
    jcb Active Member VCDS Map User
    4,132
    13
    so long as you keep to the same engine format (058 block, with or without VVT) you will be fine.
    I have a mint recon small port head for sale in a week or so.
    3 angle valve seat cut. 30 thou skim, new supertech valve guides, have all the valvetrain also if you decide it is just a top end rebuild.
