what else is needed when fitting a hybrid
Mpathe Apr 16, 2010
  1. Mpathe
    Mpathe 1st gear
    394
    now ive sold my corsa turbo im going to chuck the money at the s3, my plans are to fit cr hybrid turbo and some uprated conrods (from badger hopefully)
    i just want to know what else i need to buy for it while im working on it and how do i go about mapping it. thanks mike
  2. Andrew@A.L.D
    3,879
    617
    performance valves may be a good idea, i fitted some to my engine for safety.
    Depends on how much you want to spend
  3. Welly
    Welly VX220 SC Driver :)
    10,696
    129
    Bill (Badger5) will be able to map it up for you as well.
    I agree with valves, but then again, not a necessity.
    You WILL need an FMIC. You WILL need a 3" downpipe and sports/decat. You WILL need a silicone TIP (As the OEM ones collapse under high intake load).
    EDIT: Just saw you have downpipe and cat. D'oh!
  4. Mpathe
    Mpathe 1st gear
    394
    does bill "badger" have a website? and do i need bigger injectors or are the std ones ok? thanks mike
  5. Welly
    10,696
    129
    www.badger5.co.uk
    Not sure about the standard injectors as yet, waiting to see the outcome of a mapping session on another CR Stage 4 hybrid conversion.
  6. <tuffty/>
    21,356
    3,922
    I must get around to redoing the site :)
    Until Bill gets to map Speedy Steves he won't know if the hybrid will need the bigger injectors... he has 440's lined up just in case...
  7. Andrew@A.L.D
    3,879
    617
    Do you think the stage 4 will hit the magic 300+ on the 1.8?
  8. <tuffty/>
    21,356
    3,922
    If anything is going to get close it will be this turbo :)
  9. Mpathe
    Mpathe 1st gear
    394
    anybody know a rough price for mapping the s3 when the hybrid has been fitted?
  10. dela
    dela Member
    262
    think its 550 plus vat
  11. Andrew@A.L.D
    3,879
    617
    I've been quoted £450 + vat for mapping my 2.1
  12. Mpathe
    Mpathe 1st gear
    394
    who gave you that quote andrew?
    mike
  13. Andrew@A.L.D
    3,879
    617
  14. shanejess
    shanejess Guest
    i spoke with autograph at burnley, you really do need to upgrade to a bigger inlet manifold to get the best out of a hybrid otherwise you will only be getting 15/20bhp more than a stage 2 s3, a lot of money for a few ponnies.
  15. Andrew@A.L.D
    3,879
    617
    Nothing wrong with the standard inlet maybe a bigger T/B
  16. Mpathe
    Mpathe 1st gear
    394
    they either don't have any experiance with 1.8t or were trying to sell you something as afew on here have made the 300 mark without upgrading the inlet manifold
  17. shanejess
    shanejess Guest
    sorry had 2 laugh, baz at autograph knows more about the 1.8t than badger and all the rest of us put together
  18. Mpathe
    Mpathe 1st gear
    394
    so how has welly made 340bhp on the std inlet manifold?
  19. <tuffty/>
    21,356
    3,922
    Agreed... Welly is running a std mani and throttle body... its even small port despite having a large port head... he is making a reliable 340ish bhp on 22psi... thats a little more than 15/20bhp over a std K04...
    Not saying a larger inlet wouldn't have an affect... couldn't tell you what it would be but the curve would change as would torque delivery, but to say you need one to get more than 20bhp out of a K04 hybrid is simply wrong... and we can actual prove it :)
  20. aragorn
    18,438
    845
    Tuffty, you yourself are running the stock inlet and have seen 370+ out of it have you not?
  21. <tuffty/>
    21,356
    3,922
    That I have mate... :thumbsup:
    Although to be fair I might benefit from a SEM lol ;P
  22. superkarl
    superkarl MAN OF STEEL
    9,494
    2,436
    is it not possible to bore the manifold out a little? although im sure you hybrid/BT boys would have tried already
  23. <tuffty/>
    21,356
    3,922
    I opened mine up to accommodate the R32 TB I now have but got the 383bhp on a std mani, small port head and 60mm TB...
    There isn't much you can remove tbh but its the larger plenum you benefit from... cylinder 4 gets left out a bit on the std mani when shifting lots of air... SEM is the best flowing mani out there IIRC but its 800 odd quid so not currently high on my list :(
  24. badger5
    9,507
    2,003
    lol - whoever Baz is.. I dont know him.. I dont think
    You dont know me.. so how do you know what I do or dont know.. LMAO.. Irrelvant that it is..
    Anyhows....
    You dont need an inlet manifold for k04 hybrid... nothing stopping you from adding one of course, its your money... but the gains vs outlay wont be favourable. SEM is a very good inlet mani..
    Exhaust manifold is a must have before intake on a k04 hybrid.. but I am sure your mate knows this
    Good luck..
  25. Welly
    10,696
    129
    Yawn.
    I'm off for a snooze.
    Then when I wake I'll go and buy and SEM to claim my extra horses.... :lmfao:
