What does this suction thing in fuel compartment do?
KhalifaA3 Jul 5, 2012
  1. KhalifaA3
    KhalifaA3 Member
    82
    Right... So was washing my car, and thought let me get the dirt out of the fuel thingy?! ...
    Then thought hey let me get a bit of water down there 2! To then find all the water getting sucked! By this!!
    So.... My question is... What is that? And where is the water gone that it sucked?
  2. mjr901
    mjr901 Guest
    as far as I'm aware its just a pipe that will feed any water away or fuel that's come over the edge when you've brimmed it.
    just feeds it straight to the floor.
  3. cjsuk
    cjsuk Active Member
    567
    80
    Not a clue but logic would say a drain to stop water /diesel sitting there and prob makes its way back to the floor
  4. RallyX
    RallyX Flat Out VCDS Map User
    143
    It is a soakaway for fuel and water.Occasionally gets blocked with daily grime. Stick a pipe cleaner down it to clean. When you pour water down it it should exit by the rear inner wheel arch.
  5. Rob2k68
    Rob2k68 Well-Known Member VCDS Map User
    7,083
    10,768
    Absolutely - its a drain tube.
  6. Graham89
    Graham89 Derv Perv
    310
    If you stick your head under the rear bumper and look up towards the fuel flap you'll see a thin black tube. It's that :) a drain.
