What does this dash light mean?
mary_q Nov 24, 2010
  1. mary_q
    mary_q Member
    40
    I've never had any problems with my 1999 A3 except for a screaching noise sometimes on start up which I was told it normal and a common things with A3's of this age.
    However, lately sometimes when I try and turn the ignition on the car doesn't start first time. It usually starts after 2nd attempt.
    But... today it wouldn't start for 4-5 times (10 minutes). Eventually it did start and stayed running fine no issues, however I noticed a dash light on which showed a car outline with a key image on the bottom line of it.
    Does anybody know what this light meant? I love my car and really wanna sort this problem, anyone got any ideas? I had a new high quality battery only a few months back and last service was only 5 months ago, im baffled.
    Any help much appreciated.:think:
  2. CHRIS555
    CHRIS555 DOPE with added OCD
    1,962
    9
    Electronic Immobilser - everything should be fine if the car started - if the light flashs continuosly then the vehicle can not be driven (immobilized)
    It should show up then dissappear - this confirms the car has accepted the key you have used
  3. CHRIS555
    1,962
    9
    Your key may be faulty.....
    Hope this helps mate
  4. mary_q
    mary_q Member
    40
    Thanks for the reply Chris.
    When I was driving after it started the light was still flashing for the whole journey home (about 10 mins). I was too scared to stop the car before I got back incase it wouldn't start, but when I got back I turned it off, left it off a few mins and it started first time, turned it off again left it 5 mins, started first time also. Very weird?
  5. CHRIS555
    1,962
    9
  6. mary_q
    mary_q Member
    40
    Ah that sounds exactly like my problem!
    Would I have to remove the casing around the ignition and take the ignition barrel out? Or should I squirt some WD40 on the key and insert it that way?
  7. CHRIS555
    1,962
    9
    I would squirt a little in through the straw, then place the key in the lock to help move the wd40 around a little, remove the key then squirt just a little more in. I don't think you need to remove any casing but do have a bit of cotton to soak up any overspil -it may be worth putting a bit of newspaper on the floor beneath the lock as this stuff can be slippy if it gets on the matts or carpet.
  8. mary_q
    mary_q Member
    40
    Thanks for the guidance Chris. I've just given it a go and it did start first time so fingers crossed that's done the trick.
    I'll report back in a few weeks to let you know how I fair!
    Thanks Again! :)
  9. TheSpaceCowboy
    TheSpaceCowboy Member
    520
    I found on my 96 A3 that moving the steering column up and down then locking it back in place would resolve the issue for about 4-5 months... not a permanent solution but should you find yourself in trouble might be worth a go!
  10. Duktor
    Duktor Member
    282
    also good idea to put some wd40 in your door and boot lock at the same time I did mine yesterday and they were very stiff
