What does mean? (Sony Vaio RAM)
Matt Sep 16, 2008
  1. Matt
    Matt Active Member
    1,404
    I'm looking at buying a Sony Vaio VGN-FW11ZU.
    Only thing I dont understand is what it means in the description about the ram:
    4 GB DDR2-800 SDRAM (2*2048 MB), maximum 4 GB DDR2-800 SDRAM - a portion of the system memory over 3 GB might not be available to the operating system
    What does that last bit mean exactly?
  2. Kontraband
    Kontraband Active Member
    2,000
    In a 32-bit Windows OS, it uses up a gigabyte for memory addressing space, 3GB would have been a more better choice.
    Basically your not getting 4GB of RAM to use but I wouldn't worry. Your getting 4GB - about 1GB for addressing, which is whats not available to the OS in that description.
    Make sense?
  3. gradwells
    gradwells Member
    79
    Your new PC will be MS vista , I thought that vista could use all of the 4gb ?
    I upgraded a vista PC from 2gb to 4gb and there was a huge improvement .
    Regards
    Ian
  4. Kontraband
    2,000
    yeah, Vista can actually... running 64bit but its dependant on your mobo chipset. It needs to support remapping. It can still be a 32bit edition of Vista
    I guess with the spec saying what it did, that the GB is already used.. so running in 32bit
  5. Matt
    Matt Active Member
    1,404
    Yeah I dont really understand any of what you are talking about lol
  6. Kontraband
    2,000
    AHAHAHAH, well the important thing then is... you'll be fine! ;)
  7. FactionOne
    FactionOne Administrator Staff Member Administrator
    3,272
    183
    Mr Kontraband has it pretty much spot on. You've 'maxxed-out' your RAM capacity, and while you might not necessarily get all of it now, you'll not miss much - and having 2x2GB in symmetry will give better performance in terms of dual-channel operation than having 1x2GB and 1x1GB - you might've saved a couple of quid, but when pushing the machine hard it might cost you a bit of performance, even though you'd not actually have any less usable RAM.
    There's a bit more about 32-bit, 64-bit, memory addressing and memory remapping in this thread - I put a bit in post number 15 which expands a little.
    Regards,
    Rob.
  8. AlexStanley
    AlexStanley Member
    621
    They're all talking Geek, Matt :)
    Quite simply, the machine comes with 4Gb RAM but with Windows XP and 32-bit versions of Windows Vista your applications can only use 3Gb. So in theory, you could have a machine with tons and tons of memory (16Gb, for example), but only be able to use the first 3Gb regardless.
    To make use of the extra bit of memory you'll need to use a 64-bit version of Windows Vista.
    In real terms though, unless you're used to using things like Photoshop, it's not going to make an awful difference to be fair!
    Hope that helps :)
  9. NHN
    29,328
    1,708
    Shall we confuse him even more & talk about memory speeds, nah we'll leave it at that
  10. Matt
    Matt Active Member
    1,404
    I didn't go for the Vaio in the end. Spec'd up a Dell Studio 15 for less.
    Intel Core 2 Duo P8400 2.26GHz Processor
    4GB Ram
    320GB Hard Drive
    Blu-Ray Drive
    Intel Wireless Card
    Bluetooth
    2 Year In Home warranty & Norton Anti-virus pack
    Bunch O Surfers artwork
    Dont think it will be here till the start of November though.
