What do you think this could be?
APL TDi Feb 2, 2009
  1. APL TDi
    APL TDi Member
    289
    Hi all
    I have a 2004 A3 TDi 140. Had a new turbo put on it last week. Everything seemed fine for the first week, but then it developed a stuttering under hard acceleration.
    It is fine up to 3,000 rpm but then it stutters and coughs and loses and gains power.
    I ahve posted a simlar question in the A3 8P section, but was hoping for some diesel expert advice.
    A!:uhm:
  2. APL TDi
    APL TDi Member
    289
    The car seemed fine this morning, no hesitation and accelerated hard through the rev range.........
    I am now very confused:huh:
  3. evomaster3000
    evomaster3000 Member
    449
    MAF problem? turbo's take a while to spool up and drop power so it probabily wouldn't be the actuator or vacuum supply to it.
    could be a leaking egr? or bad egr vacuum supply/fault dumping the boost irratically.
  4. fjtwelve
    fjtwelve Moderator Moderator
    770
    10
    Agree MAF is a definite suspect. Next time you have the problem unplug the MAF and see if it gets worse. If it doesn't then the MAF is probably knackered. Unfortunately MAFs fail gradually sometimes, drives you mad. Stuttering is possibly due to fuel starvation or flooding, turbos and valves don't respond fast enough to cause a stutter. Maybe you cleared a blockage in the fuel lines, could be the fuel pump and its ecu playing up. VAGCOM check is a good place to start. Find an independent specialist. Where are you?
  5. APL TDi
    APL TDi Member
    289
    Cheers guys.
    I am taking it back to the dealer this evening and they are puttting it into audi tomorrow so they should be able to do a diag check.
    As said its fine now, so hopefully it was just something bedding in or snagging in the fuel or boost system.
    Audi are going to have a look at the turbo to make sure nothing is loose causing a boost leak, hopefully it will be fine (touch wood)
    :salute:
  6. spud28
    spud28 New Member
    well done, Have you fired it up yet?
    I should have done my head gasket myself but instead I thought I would get a replacement engine from a breakers. The problem is instead of a replacement AFN they've sent a AHU and won't give me a full refund as they say it's the same engine with a different exhaust gasket and turbo and all I need to do is swap my ones over.
    I have had differing opinions as to whether or not this is the case. Could you enlighten me? or direct me towards someone who could help, please.
    :sos:
    Cheers, Spud28
  7. etronic
    etronic TDI
    69
    I don't know how this post refers to the topic :think:but i can tell you that these two engines are completely different
    AFN is a 110BHP witn VTG turbo and AHU has only 90BHP and turbo with no variable nozzle geomerty. Also AFN got DMF while AHU not.
