What do these fault codes mean ?
JeePee
Wednesday,14,September,2011,18:29:07:43475
VCDS Version: Release 10.6.4 (x64)
Address 09: Cent. Elect. Labels: 8P0-907-279-30-H.lbl
Control Module Part Number: 8P0 907 279 P HW: 8P0 907 279 P
Component and/or Version: Bordnetz-SG H54 2903
Software Coding: 13AC2F81C0141380EF00001C00800000002A4E056406400300 1800000000
Work Shop Code: WSC 06314 000 08192
Additional Info: 8P1955119F Wischer AU350 H10 0040
VCID: 4A91756C5C2F
Fault Codes have been Erased
2 Faults Found:
02895 - Supply Voltage for LED Module for DRL and Parking Light; Left
012 - Electrical Fault in Circuit
Freeze Frame:
Fault Status: 01101100
Fault Priority: 2
Fault Frequency: 1
Reset counter: 171
Mileage: 74882 km
Time Indication: 0
Date: 2011.09.13
Time: 18:28:00
Freeze Frame:
ON
Voltage: 14.00 V
OFF
ON
OFF
OFF
OFF
02897 - Supply Voltage for LED Module for DRL and Parking Light; Right
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 171
Mileage: 74882 km
Time Indication: 0
Date: 2011.09.13
Time: 18:28:00
Freeze Frame:
ON
Voltage: 14.00 V
OFF
ON
OFF
OFF
OFF
I cant figure out what it means ? Voltage too high or too low ?
This happend after a bi-xenon install over halogen. On a 2009 Audi A3 S-Line.
I cant figure out why my LEDS dont light up...
I plugged the Kufatec harness wire on the ECM on plug A pin 7 and plug D pin 10. Those are supposed to be the ' SIDELIGHTS' pins.
The LED DRL dont light up, so i guess there is no power going trought the wire...
Have you coded the bi-xenons to the car and enabled DRLs?
09-Central Elextronix
Coding -> Function 07
Byte 00 Bit 1: Xenon Headlights installed
Byte 03 Bit 4: Xenon-Shutter installed (Bi-Xenon) Can't code this one, tell me 'Error 31'
Byte 17 Bit 1: Deactivation of Additional High Beam with Bi-Xenon
Byte 21 Bit 26: (26= BI-Xenon with DLR LED) change byte 21 from 25 to 26 This is a drop down menu, i chose option 6, Bi-xenon with LED DRL
I did this.
My headlight switch inside the cabin got a 'DRL' position. Is there a way to wire it directly to some power source ?
You need to wire it in exactly as per elsawin details, that way it will work.
