what do i ask for..
ALPINE Jul 8, 2008
  1. ALPINE
    3,093
    needing new ones. ill do both sides. what do i ask for and are they a bitch to change? ill do these whith the strut off as i have just orderd some coilies.
    many thanks.
    (maybe doc would help me if i gave him some beer tokens?) :beerchug:
  2. brendan
    brendan 98 A4 1.8SE
    137
    track rod end / tie rod end.
    should be fairly straightforward as long as you are able to undo the bolts
  3. ALPINE
    3,093
    thought so..... cheers for the confermation.
  4. aragorn
    18,579
    868
    The kit i linked to in the other thread comes with them, but yer they are called track rod ends or tie rod ends
  5. ALPINE
    3,093
    sweet mate... thanks very much
  6. brendan
    brendan 98 A4 1.8SE
    137
    could you not have posted this in your other thread? why did you start a new one? i didn't even know there was another thread, then i find someone already answered the question! :-/
  7. ALPINE
    3,093
    lol soz.. didnt even think about it!
  8. GSB1
    GSB1 Member
    283
    Don't forget you'll need an alignment afterwards, but if you're fitting coilovers too that's good timing to get it done.
  9. ALPINE
    3,093
    yep plan is to get it all done at same time. never have alignment done b4, where would i go and how much roughly?
  10. NHN
    29,568
    1,779
    well def not audi as they overcharge & dont use there heads just follow the book, so if you have a even the most minutely slight buckle from some knock they dont know how to compensate with adjustments, they just have settings & thats it so if you end up driving round in circles they say "well its set as per audi says so its correct" lol, lolFind a reputable tyre place not kwik fit with a decent system thats regularly calibrated, then test drive for any pulling to the side then go back for adjustments.
    I would say £50 approx is fair, nowhere near the reported £200 from one audi dealership, but if you are doing suspension arent you getting it fitted or DIY cause fitters should have the system to do for you.
    Yes its a tie rod bush.
  11. GSB1
    GSB1 Member
    283
    Yes the dealer may well be in the region of £180-£200 but some have a set price, so at their hourly rates, it works out well (for a dealer).
    Ideally find a specialist that has the correct Beisbarth machines such a specialist alignment service or VAG specialist such as AutoPS. I'd still expect to pay £80-£100.
    Just an additional note, you may find the replacement tie rod end is not identical to the one you remove, when I had mine changed it appeared the part had been revised.
  12. ALPINE
    3,093
    cheers for letting me know that. :)
  13. aragorn
    18,579
    868
    You do realise that none of the geometry is acutally adjustable on a B5 bar the tracking/toe settings and the left to right camber distribution. The camber on individual sides isnt adjustable, the overall balance is only adjustable if you unbolt the subframe and move it side to side.
    That means that unless the subframe has been removed or you suspect the camber to be uneven then the only thing thats acutally worth paying money for is the tracking/toe adjustments.
    A full alignment check may highlight things that are out of spec, but they're not actually adjustable so it would just mean replacing the suspect part.
  14. ALPINE
    3,093
    im getting the tracking and cambers set to my requirments. thanks to my good freind steve at chessington motors!! :)
    :sign_plug:
  15. aragorn
    18,579
    868
    and how exactly do you intend to set the camber when its not adjustable?
