What diesels have the turbo problems?
APL TDi Jun 1, 2009
  1. APL TDi
    APL TDi Member
    289
    Hi
    I am in the process of replacing my 04 A3 2.0TDi. I have only had it six months but want a newer car.
    My question is what A3's have turbo problems? Is the 170 completly fine? Is it only the pre facelift 140's which have the problems?
    If I got a 56 plate 140 quattro, will the turbo need doing at 60-80K?
    Any andvice would be much apriciated.
  2. boggysv
    boggysv Member
    573
    You sir, are asking for the holy grail of cars/turbos/any mechanical item. I'd pay good money for anything with a zero probability of failure.
  3. Boydie
    Boydie S3 8V DSG VCDS Map User
    3,460
    598
    There are no common turbo faults with the 2.0tdi's - its just unfortunate if your turbo does have an issue in your car!
    If you get a well maintained TDI Audi, you should not have an issue!
    I change my oil every 10k and filters, the car has been remapped for over 40k miles and no issue as yet with my turbo! (touching wood as you read!)
  4. APL TDi
    APL TDi Member
    289
    lol
    Ok fair enough.
    All I am saying is it seems to be a bit TOO comon for turbo failure on 140's. It is the same with all the cars with the 140 tdi engine in, but I never hear any complaints about the 170.
  5. Matt
    Matt Active Member
    1,404
    Never heard of one going on the 170 but that doesn't mean it wont!
  6. kaz219
    kaz219 Active Member VCDS Map User
    1,808
    I've read loads about TDI turbos blowing (esp on the bkd engine).
    generally, it tends to be the bkd engines or the 1.9PD engines - they're not common but do blow - As boydie said, its down to how the car was mantained.
    30secs to let oil go through before driving off, 30 secs to cool down before turning off and driving the last few miles of your journey with low revs, regularly serviced will ensure a good healthy turbo.
    I looked after mine but it still went (out the blue as te car was running fine).
    But remapping does reduce the life of a turbo...
  7. APL TDi
    APL TDi Member
    289
    Furry ****
    Thanks for the feedback.
    I should not be worried about buying another 140 then......
  8. Boydie
    3,460
    598
    Well.....2003-late 04 had flywheel issues and porus heads so check that out!
  9. APL TDi
    APL TDi Member
    289
    lol, I know
    Mine seems to be fine. Does judder a little on tick over tho......
  10. dunk
    dunk Member
    770
    the only problem with my 2.0tdi turbo was that the turbo wasnt big enough....had to swap it for something much bigger:)
  11. NHN
    29,422
    1,740
    What did they set you back Dunk, cause know Simon@amd does a 2k upgrade, also only issue I know of the 140's is the head issue that several have reported, but turbo wise not heard that much tbh.
  12. dunk
    dunk Member
    770
    turbodynamics stage 2 turbo, decat custom exhaust and custom remap - about 240hp cost £180 turbo fitting, £500 turbo, £420 remap by derv doctor, £600 decat full turbo back SS exhaust
    probably dont need full exhaust, but decat will help turbo spin up a lot and low resistance back box is said to help.
