What could the problem be??????
Discussion in 'A3/S3 Forum (8L Chassis)' started by imported_alecblack, Jul 7, 2005.
  1. Hi all,
    Any suggestions?
    The ride quality on my car seems to have got worse over the last 3-4 months, it seems to me like it may be a suspention problem. I am getting more vibration through the car so much so i can hear interior parts rattle which wasnt there before.
    I have checked my front tyres and they seem to be slightly more worn on the outside edge. I dont think it is the wheel bearings as i jacked the car up and there was no play on the wheel. /ubbthreads/images/graemlins/frown.gif
  2. Advert Guest Advertisement
  3. ritmark
    ritmark Member
    Aug 8, 2005
    57
    What mileage have you done ?
    Have you checked the front and rear bushes for signs of wear ? - Are the shocks ok - any signs of leaks ?
    when were the wheels last tracked and balanced ?
    Have you changed the setup of the car of modified the tyre pressures
    Are the anti roll bars ok - check that the collars are ok and the bushes again arent worn front and rear
    Have the suspension mounts checked - look for signs of wear or play
    Make sure there is no evidence of damage to the springs - check they havent cracked / split
    Audi do an MPI check - which I had done recently which will give you a full vehicle safety report and help identify many of these issues - check with the dealer on pricing
  4. Spiker,
    I have not checked the bushes at all as i wouldnt know what to check for.
    The car has 69,000 mile so i am thinking its around about that time. where things are going wrong
    How much were you charged for the MPI check?
