What Company Makes OEM Brake Pads for the S3 ?
J.R. Jan 14, 2013
  1. J.R.
    J.R. "Started From The Bottom" VCDS Map User
    1,405
    68
    Just a quick question guys and girls .....Do ATE Make the Brake Pads for the S3 Front Brakes ?
  2. IceHanger
    IceHanger Active Member VCDS Map User
    340
    64
    they do make pads for the A3, have OE numbers and based in germany so a good chance
  3. Turbo jay
    Turbo jay Leather repair specialist
    577
    69
    Pagid do mate and there also German
  4. S3 syc
    S3 syc Active Member
    154
    29
    Pagid also squeal no matter what and I arent takin this you must use are special cera tec lube to stop it lol. Stick with ate in my experience and I sell pagid day in day out.
  5. crunchie
    crunchie Active Member
    880
    77
    I believe Audi make OE pads lol
  6. S3 syc
    154
    29
    Audi don't make any brake parts themselves bud there made by ate and stamped with Audi logo,if you buy ate pads in many cases you can actually see where the Audi logo has been covered or removed.
  7. chris.vincent3
    chris.vincent3 Own a BMW now, HOWEVER I still own VCDS! VCDS Map User
    604
    34
    When fitting anything onto a hub of a vehicle where it be discs, pads or the alloy, you apply something called "copper grease" it'll prevent corrosion and that item from seizing, as for the pads it will also eliminate the chance of vibration in the calliper, never put a hub back together without copper grease could save you the time of having to rebuild it because something is squealing.
    I've found Mintex to be pretty good with OEM equivalent.
  8. klik
    klik Member
    234
    yes and I use Ate on my S3.
  9. J.R.
    1,405
    68
    Thanks guys. I'm goner go with ATE. As it's the OEM Standard and I've found a good price for them.
  10. grr666
    grr666 Member
    171
    19
    My pagid disc and pad combo on my last car was faultless.
    I like the fact that the non service areas of the disc are painted
    so they don't go rusty 2 weeks after fitting. Even during and after
    a damn good thrashing round Castle Combe they never made a sound.
  11. Turbo jay
    577
    69
    I've also had pagid pads on 2 a3's over the last 5 years never had squeal once mate, and they are OEM spec
