what clutch for s3?
daz-20vt Sep 6, 2012
  1. daz-20vt
    daz-20vt Well-Known Member
    2,835
    583
    hi guys. pretty sime. i need a new clutch but i have no idea what the difference oif any there is. i want to get it for as cheap as pos obviously but they seem to range from 100 pound and much higher. so whats the difference? would a cheaper one be ok? ive just forked out nearly 1k on the car so defo want some good advice on this lol. thanks. daz
  2. colicabcadam
    colicabcadam Guest
    standard clutch on my old car dealt with 4k launches easily, my car was mapped too, i think the standard clutch on these is pretty good - depends on how much power you plan to chase
  3. daz-20vt
    2,835
    583
    well tbh i think the car will stay stage 1 or 2 for a good while. so an oem clutch should be fine you think? what about these cheaper oem spec clutchs? any info on these? thanks for your reply!! daz
  4. Scoot123
    Scoot123 New Member
    25
    Mine is stage 1 mapped,standered clutch fine till you hit 6000 revs then starts to slip.
  5. colicabcadam
    colicabcadam Guest
    standard clutch should not slip at all on a 270 bhp s3, yours must be on the way out !
  6. Scoot123
    Scoot123 New Member
    25
    You could be right .
  7. <tuffty/>
    21,359
    3,926
    OEM clutch won't last very long doing too many launches tbh... clutches are quite subjective but any 'launching' on any clutch will kill it far sooner no matter what you end up with...
    If you are normally easy on the clutch then a std one should be fine... Westy has had decent results with a clutch kit from Awesome so check his build thread out for details... another option is a std clutch cover and DMF using a Sachs 4 puck paddle plate... I have this setup and its been fine... light in traffic but copes with launches well and certainly copes with the onset of 300+ ftlbs of torque from my GT30...
  8. daz-20vt
    2,835
    583
    to be honest guys i rarely launch the car and when i drive it i dont kill the clutch at all. im thinking a standard item should be fine. so i guess a clutch kit from ebay will do then. ill make sure its upto oem levels before i buy. thanks all!! daz
  9. <tuffty/>
    21,359
    3,926
    Get an LuK kit from GSF... mine was about £100 for the clutch, £24 for the slave (you need to replace this really) and optionally £240 ish for an LuK DMF...
  10. dusty
    dusty Active Member Team Nogaro Blue Audi S3
    267
    46
    I have the awesome gti s.m.f. Conversion and heavy duty clutch been in the car for 6 months the pedal is no heavier than the o.e. clutch and good value for the money
  11. thegoal007
    thegoal007 Another S3 owner....
    805
    26
    i hope others will take note here. If you plan to drive normally then a standard clutch is more than adequate. Plan on having spirited drives frequently then pay for a better clutch, it may cost a little bit more, but I think the fairly hefty labour cost is not something you do not want to go through twice in a short space of time.
  12. daz-20vt
    2,835
    583
    cars back in having a standard clutch put in. the one you suggested tuffty i believe. thanks for all the help guys. cant wait to get it back so i can actually drive the bloody thing!! daz
