What clutch do I need??
Dogtown22 Mar 5, 2013
  1. Dogtown22
    Dogtown22 Member
    251
    After reading some very bad stories on line I've decided I'm going to order a clutch myself and have the local garage fit it.
    I will be ordering a Sachs clutch kit (no flywheel) off of ebay.
    Can someone post a link for the correcet one I need??
    02 1.8T sport.many thanks guys.
  2. Dogtown22
    Dogtown22 Member
    251
  3. RobMorris
    RobMorris Member
    539
    10
    I cant confirm if thats the right one.
    But check if your garage will indeed fit a part you have supplied.
    My local wont do it as they cant guarantee the part is correct so cant guarantee the work..
  4. Andie0
    Andie0 Member
    490
    13
    Are you standard power?
  5. Dogtown22
    Dogtown22 Member
    251
    No mate, remapped to about 200bhp
  6. Andie0
    Andie0 Member
    490
    13
    Oem should handle that then no problem! Didnt no if you was more bhp because i recall from previous post you said about your remap so was wondering if maybe you needed uprated clutch!
  7. Audi Doodah
    Audi Doodah Active Member
    377
    35
    [TABLE="width: 100%"]
    [TR="class: TableRow2"]
    [TD="class: verysmall"][/TD]
    [TD]SACHS[/TD]
    [TD]3000 951 705 [/TD]
    [TD][TABLE]
    [TR]
    [TD="class: img_preview, align: right"][​IMG]
    [​IMG] BIG
    [/TD]
    [/TR]
    [/TABLE]
    [/TD]
    [TD]Clutch Kit
    XTend[/TD]
    [TD]
    • Engine Code : AVF
    • to Ch.No. : 8E-5-040 000
    • Labour : 4,60 Hrs.
    • Diameter [mm]: 240
    • Number of Teeth: 23
    • Only install together
    • Only available as KIT
    • torsion damper clutch disc
    [/TD]
    [/TR]
    [/TABLE]
    [TD]SACHS[/TD]
    [TD]3000 951 705
    [/TD]
    [TD][TABLE]
    [TR]
    [​IMG] BIG
    [/TD]
    [/TR]
    [/TABLE]
    [/TD]
    [TD]Clutch Kit
    XTend[/TD]
    [TD]
    • Engine Code : AVF
    [/TD]
    [/TR]
    [/TABLE]
    Taken directly from Sachs' web catalog
    WebCat 3
    No AVF flywheel though. Also parts numbers for Lemforder suspension parts
