What cause my AIR BAG light on the dash? Will this part solve the problem? Please see
KemiksiZ Dec 10, 2012
  1. KemiksiZ
    KemiksiZ Active Member
    570
    142
    43
  2. Strangely Brown
    Strangely Brown Member
    58
    Have you recently done any work on the car like removed seats?
  3. gen.heinz guderian
    gen.heinz guderian Well-Known Member
    1,346
    125
    check wiring under seats as well
  4. Boon
    Boon Active Member
    441
    59
    You need it scanned with VCDS first...
  5. KemiksiZ
    570
    142
    43
    No i did not, VCDS means VAGcom??
  6. MrLapou
    MrLapou Well-Known Member
    1,233
    121
    Save your self some money and buy a genuine VCDS dongle + downloaded software from RossTech
  7. Ash187
    7,443
    704
    did you disconnect the glovebox and then turn on the ignition?
    Also i have a F rev steering controller for sale if you need.
  8. KemiksiZ
    570
    142
    43
    '' did you disconnect the glovebox and then turn on the ignition?''
    What the Fck? :)) What is the relationship between the glovebox & my airbag light? :)
  9. Ash187
    7,443
    704
    Well the glovebox has a connector on the back of it which connects to the passenger side airbag, so if you leave it disconnected and switch on the ignition the light will come up on the dash and not disappear until you reset it with VCDS
    also remember that there may not actually be a fault in the car... just that you left a connector disconnected and like an idiot turned on the ignition :)
  10. KemiksiZ
    570
    142
    43
    Actually I never mess with the glovebox :) I'll check the wires there today and see if something wrong.
