What Carista mods have you done?
Flowrider99 Feb 12, 2018
  1. Flowrider99
    Flowrider99 Active Member
    118
    I thought it would be useful to see what mods people have been able to do on their b8/b8.5 A5/S5 with Carista. I'll go first.....
    Start/Stop - Enabled the memory so the car starts up in the same mode as when it was last used.
    Ambient light menu - Enabled the MMI control to adjust the brightness of the footwell lighting.
    Rear DRL's - Enabled the rear lights to act as DRL's.
    I want to change the number of times the indicators signal a lane change from 3 to 5 but can't find the option to do it.
    David
  2. CharlieSAudi
    CharlieSAudi Member Team Ibis TFSI Owners Group Team V6 Audi S5 S-line owners group Supercharged DSG
    43
    14
    Good thinking with the post @Flowrider99
    Unlocked hidden menu
    Beep when locked
    Audi Drive Select
    Only had a quick look on there but still itching to do more just don’t no what yet so this post should be helpful :)
  3. Flowrider99
    118
    I forgot about the unlocking of the hidden green menu, you need to that first before you can mod the ambient lighting.
  4. CharlieSAudi
    43
    14
    Is the lighting able to be adjusted brighter than he standard setting.
  5. Flowrider99
    118
    When i enabled the option the setting was just over half way and does go brighter, in my car it actually goes to bright for night driving IMO.
  6. CharlieSAudi
    43
    14
    I tried to unlock this but it doesn’t show in my menu which is a shame.
    Managed to do the following:
    Fog lights when cornering
    Passenger side mirror tints when reversing
    Seat belt tone changed (god knows why but I did lol)
    Beep and blink when unlocking
    Think that’s all, do really like this app so helpful.
  7. Bristle Hound
    Bristle Hound Moderator Staff Member Moderator
    8,681
    11,381
    Plenty of info on the Carista app here
    http://www.audi-sport.net/xf/threads/carista-app.237050/
    I'm assuming a lot of the stuff you can change on the B8 & B8.5 A4/S4 will be available on the A5/S5's
    On my S4 I added/changed -
    Oil temp/lap timer added
    Beep on locking
    Memory function on stop/start button
    Rear lights as DRL's during the winter months
  8. mrbubba
    mrbubba Active Member
    118
    53
    How can I get the digital mph in the centre? I had it at one point and now it's not there and can't work out it. I have carista and OBDEleven on an S4
    Sent from my Pixel C using Tapatalk
  9. JG51 AUD
    JG51 AUD Well-Known Member Team Glacier TFSI Owners Group Team V6 Gold Supporter Audi S5 quattro Black Edition Supercharged
    2,676
    1,554
    Mode button on your steering wheel should change to MPH, it does on my S5 & previously on my A5.
    JG
  10. CharlieSAudi
    43
    14
    Yeah should just be on the lever, I would push the reset but and scroll through if not push again and then have another scroll through using the side buttons. Without being in the car pretty sure that’s correct.
  11. mrbubba
    118
    53
    That just scrolls through MPG and the other stuff. I had to enable lap timer, which I've checked is still enabled, but can't remember what the next step was
    Sent from my ONEPLUS A3003 using Tapatalk
  12. Lord
    Lord Active Member
    155
    55
    On the same stalk as the one for mpg and wipers. Press the button on the bottom of that stalk, not the end of it.
  13. mrbubba
    118
    53
    Aha! Spot on, thanks
  14. Meemo
    Meemo Well-Known Member
    871
    509
    93
    I have Carista (thankfully paid for unlimited for life subscription before it became monthly :) )
    Enabled all the usual stuff mentioned above, but wondered if any beta testers might know if they will introduce (if its even applicable to the S5) the setting to change the sound system from 'RHD/Leather/Gasoline' to 'RHD/Cloth/Diesel', this increases the bass on the old BOSE systems on TT's, and since getting my S5 am super disappointed in the B&O systems lack of bass.
    Details here :):
    http://www.ttforum.co.uk/forum/viewtopic.php?f=19&t=139313
    "The Sound System (J525) coding. Bit 7 00xxxx? allows setting according to the interior of the car. Mine was 00xxxx7 which is for Right-Hand-Drive/Leather/Gasoline. I changed it to 00xxxx5 which is for RHD/Cloth/Gasoline and the bass tone came booming out. It's now too much to have the bass on full. If you set 00xxxx1 which is for RHD/Cloth/Diesel then, for me the bass is too much.
    At last, my sound system is perfect. [​IMG]"
  15. Jps3290
    Jps3290 Active Member
    220
    47
    Im a beater tester for Carista but not checked it on the RS5 for some time. I'll try and remember to have a look tonight but will be after 9pm as the wife has the car today. I will get back to you.
    I know what you mean though. I have an A3 with BOSE and the bass is excellent.
    Our RS5 has the B&O system and even with Base right up its definitely no were near as good.
    Meemo likes this.
  16. Meemo
    871
    509
    93
    Thanks, if its not there, will be able to see in vag com later tonight if its even available to change on the s5. If it is maybe Carista should add it :p
    Boyfriend is bringing over his vag com tonight to see if we can find it.. EXACTLY THAT! the Bose in my old B8 A4 was soo much bassier than the S5's B&O, I know its meant to be about the clarity rather than the bass... but i care more for the bass :p
    Jps3290 likes this.
  17. Jps3290
    220
    47
    Couldn't see anything through carista.
    Quite a few new beta settings available, some which I have no idea what they will do so dare not try them but nothing music related.
    If you find that it can be done via vcds let me know how and I will see if it can be added to a beta test release.
    Sent from my SM-G930F using Tapatalk
