what can you use to clean a maf sensor?
4rings Apr 8, 2011
  1. 4rings
    4rings Member
    94
    hi would brake cleaner be ok to clean a maf sensor??
  2. DavidW
    DavidW Member
    211
    Not sure on the brake cleaner, think IPA (isopropyl alcohol) is recommended.
  3. Gavin G
    Gavin G Active Member Audi A4 S-line owners group TDi saloon
    184
    31
    Carb Cleaner ftw
  4. 4rings
    4rings Member
    94
    ok well i have brake cleaner surely its all near enuff the same stuff.
    brake cleaner evapourated e.t.c??
  5. A3Tom
    A3Tom Smell my finger.
    3,504
    14
    I'd use intake cleaner just in case. I did mine with intake cleaner and no issues to report.
  6. A3 T
    A3 T Lord Of The Rings
    1,077
    15
  7. Jonesy
    Jonesy Member
    570
    I used instake cleaner on the small sensor attached to the inlet manifold next to the throttle body, no problems so far and its nice and clean!
  8. DJ_Troopa
    DJ_Troopa K1 Driver
    1,743
    15
    Contact Cleaner from Maplins. I done mine 2 months ago. Jumped from 199 g/s to 208 g/s.
  9. markthenewt
    markthenewt Member
    250
    Just brought some of that Isopropyl from Maplins to clean my MAF, is there a how to anywhere? Thanks.
  10. A3 T
    1,077
    15
  11. markthenewt
    markthenewt Member
    250
    Yeah just looking at it now, cheers :) Is it worth diconnecting the battery after I have done this to reset the Ecu?
  12. Jonesy
    Jonesy Member
    570
    just done mine with contact cleaner from maplins. Didnt have the correct torx security tool so used some grips on the raised screw head took forever but saved me buying more tool bits ill use only once. Cleaned up the MAF housing as well as inside of that was pretty dirty, car seems to run smoother and the 'missfire' i thought i had has gone.
  13. markthenewt
    markthenewt Member
    250
    Nice! I attempted to do mine but had the same problem with the security torx, went to buy one from Euro car parts and they don't sell them :(
    Oh well will have to wait till the weekend now to do it and while I'm at it I shall clean my trottle body too.
  14. Stanley
    Stanley Member
    201
    Pressure washer :whistle2:
  15. steve bain
    steve bain Member
    642
    get yourself to wilkos or any other place that does cheap diy tools. buy a multi toolkit for about a fiver...they nearly always include torx bits and a screwdriver these days....
  16. markthenewt
    markthenewt Member
    250
    I brought a security torx set today froma cheapo diy shop... It's meant to be a t25 torx to undo the maf sensor screws but the damn holes on the torx I brought are not round (too small to go over the round bit in the torx screw) enough so still can't get mine off, im thinking it must be a proper Audi torx I need?
    Or i have a **** security torx set.
    Gutted :(
  17. markthenewt
    markthenewt Member
    250
    Brought another security torx set today and that dont fit either!!!
    Is it it a special Audi anti tamper or what cause the t25's i'm buying just don't fit...
