What can I get away with?
A4AvantBlackEdition Sep 19, 2017
  1. A4AvantBlackEdition
    A4AvantBlackEdition Active Member TFSI Owners Group Audi A4 Audi Avant Owner Group Black Edition
    359
    210
    43
    Pick my car up in November. Brilliant black A4 Avant Black Edition. This is a two year lease so I won't own the car and aren't massively bothered about protecting the paintwork etc. However I would like to do something when I first get the car to help with future cleaning.
    I was going to give the car a good clean and clay bar pretty much straight away but what is the easiest & lowest cost way of adding some protection to the paint? Wax for example? I'm looking for something I can do myself without costing the earth but something that will help with water beading and making future cleaning easier. I know black is a nightmare (hence why I haven't had one in the last 15 years) so want to make sure it stays looking good for longer. Any advice appreciated.
  2. Bristle Hound
    Bristle Hound Moderator Staff Member Moderator Audi S4
    7,992
    9,562
    @A4AvantBlackEdition - Can't beat Sonax BSD for the money IMHO
    Adds protection & beads like a mutha too
    BUT it can be grabby & will smear if over applied
    Check out EuroCarParts & use one of their discount codes together it at a silly price delivered
  3. A4AvantBlackEdition
    359
    210
    43
    Thanks buddy. I'll look into that.
  4. 8utters
    8utters Member TeamMisano TFSI Owners Group Team V8 Audi RS4 quattro saloon Manual
    32
    Hi there, Surely a ceramic coating, while it might be £50-80, if it lasts for 12-18 months or so, represents good value?
    Just my 2p :)
  5. A4AvantBlackEdition
    359
    210
    43
    Is that all they cost?
    Why am I here thinking to have a car ceramic costed costs £300+?
  6. 8utters
    32
    You can DIY if you've got a dry space to do it, while a pro job will cost 300+ it will last longer, however, for much less you can get most of the same performance from a consumer product.
  7. A4AvantBlackEdition
    359
    210
    43
    Ah. Got ya. Do you recommend one?
  8. 8utters
    32
    I can't, I have bought some but not had my car back from the body shop so no experience of testing it. I had a good couple of days on YouTube, got some ideas from there and from Slims. I ended up learning that I wash my microfibres wrong too!!
  9. A4AvantBlackEdition
    359
    210
    43
    Sounds complicated. I'll let someone else do it. :D
  10. 8utters
    32
    To be honest, once it's clayed, you'll want to wipe the panels down with a water/ipa mix ( not beer :p ) and then apply the coating, usually it's a wipe on, buff off job and leave to cure for around 12 hours. Genuinely l think it should be ok, will let you know about mine once it's done, but will be a week before she's back from the paintshop.
    A4AvantBlackEdition likes this.
  11. 8utters
    32
    I went with "Gtechniq Crystal Serum Light" - do youtube searches and you'll see the results, looks good to me!!!
  12. scotty76
    scotty76 Well-Known Member Team Phantom Audi S4
    3,153
    1,905
    I reckon something like Gyeon Cure would suit you. I'm using this at the moment diluted 1:1 with water. Probably last a couple of months at a time but it's spray on, wipe off. Job done. :)
  13. A4AvantBlackEdition
    359
    210
    43
    I like the sound of that.
  14. Taxboy
    Taxboy Member
    47
    19
    I was going to suggest something like Bilt Hamber Finis wax initially the small pot is about £15 and then follow up with the Sonax BSD when you wash to top up the protection
    Sent from my XT1032 using Tapatalk
  15. A4AvantBlackEdition
    359
    210
    43
    Can I put the Bilt Hamber Finis wax on and then immediately follow with the sonax bsd?
  16. Taxboy
    Taxboy Member
    47
    19
    I've never applied BSD immediately after Finis, although I would imagine it should be OK if you let the Finis cure for an hour or so. I'm sure other BSD users might be able to share their experience.
    Finis is a durable wax I can get 4 months out of it on its own. I tend to use the BSD as an extra layer of protection top up ...plus I like the water behaviour of BSD
  17. A4AvantBlackEdition
    359
    210
    43
    Thanks. I'll probably let it set for a couple of hours then add a bit.
  18. Taxboy
    Taxboy Member
    47
    19
    The only tip I can offer with regard to Finis is the same as a lot of other waxes, to apply thinly. Enjoy your new car
  19. A4AvantBlackEdition
    359
    210
    43
    This wax comes in 50ml and 250ml pots.
    How many full car applications would I get from a 50ml pot? Ia it worth just getting the bigger one?
  20. Taxboy
    Taxboy Member
    47
    19
    I can't say for certain but I've done 5 applications out of my small pot and it's around the halfway mark but that's me. Others may get more / less. I would suggest getting the small pot initially to see if you get on with it. If it's not for you the you haven't blown too much cash or alternatively you get the detailing bug and want to try others
    Sent from my SM-T800 using Tapatalk
  21. A4AvantBlackEdition
    359
    210
    43
    It’s just £12 for 50ml and £33 for 250ml. Bigger one seems much better value for money. May just go for the big one.
  22. S32B
    S32B Well-Known Member Team Ibis Audi A5 S-line owners group s tronic
    3,779
    4,488
    The Sonax is great, I used it on my black S3, just don't put too much on as a little goes a long way...as BH said it smears if you use too much! :)
    Under it though I had G3 wax and just used the Sonax after each wash.
    Just before I sold it:
  23. A4AvantBlackEdition
    359
    210
    43
    Looks great. And thanks for the advice.
  24. Rich76
    Rich76 Active Member Team Phantom TFSI Owners Group Audi A4 S-line owners group
    118
    67
    Any one got a link for the sonax bsd
  25. A4AvantBlackEdition
    359
    210
    43
    eBay has it mate.
  26. Taxboy
    Taxboy Member
    47
    19
    Or try Euro Car Parts. They normally have a discount code every other week !
  27. Taxboy
    Taxboy Member
    47
    19
    Just checked using code MID36 gets it for £7.35 currently
  28. A4AvantBlackEdition
    359
    210
    43
    Only £7.69 delivered from eBay.
  29. S32B
    3,779
    4,488
    And even if there is no code showing on the website, if you use WEEKEND30 you normally get...you guessed it 30% off :)
    Sonax bsd https://www.eurocarparts.com/ecp/p/...ior-cleaning/car-detailer/?549992160&&cc5_761
    The matte dash cleaner is also good https://www.eurocarparts.com/ecp/p/...ior-cleaning/car-detailer/?549992150&&cc5_761
    Bargain for both:
  30. A4AvantBlackEdition
    359
    210
    43
    Does that price include shipping? Both can be bought for £16.08 including shipping on eBay.
  31. S32B
    3,779
    4,488
    Yes I think it does.
  32. A4AvantBlackEdition
    359
    210
    43
    Then with the discount code that a very good price.
