What Can I Do To Stop This?
dkingy11 Mar 25, 2009
  1. dkingy11
    dkingy11 Member
    69
    hi, just wondering if anyone can shed some light on my problem?
    i am getting vibration (which can be felt through the whole car) when accelerating in 4th, 5th and 6th at around the 75mph mark and beyond that. As soonas i take foot off accelerator it stops but then as soon as i press again its back! :banghead:
    could it be anything to do with wheel alignment or is there more to it?:ermm:
  2. frenchy2475
    frenchy2475 Tetbury Audi Parts Man
    263
    Possible duel mass flywheel problems? If it was wheel balance issue it would do it all the time not just on accelerating.
  3. anton2015
    anton2015 Member
    178
    I just had the same and its the wheel balance, i had mine after changing a tyre and it was at 80+. But it was when i don't touch the gas, as soon as i accelerate it would stop, balancing fixed it though
  4. dkingy11
    dkingy11 Member
    69
    so would you recommend wheel alignment first? how much will that cost?
    if that doesnt sort it will have to look further into it!:shrug:
  5. anton2015
    anton2015 Member
    178
    alignment and balancing are different, but both are very easy to do, my friends at the garage done both in about 10 minutes and course for free, very easy to sort out so dont worry bout it
  6. dkingy11
    dkingy11 Member
    69
    how much would it cost to get both done, also where is best place to get it done?
    i have just been for a little test drive to try and figure out when it occurs. i suppose it does occur pretty much all of the time and only becomes really noticeable at higher speeds (if that makes sense).:think:
  7. NHN
    29,331
    1,716
    Well audi charge the earth tbh, most independents charge small amounts in comparison, its the adjustments for alignment that are the bitch cost, balancing is very cheap & do this 1st, but sounds like its one of either or both, dual mass I doubt, but try those 2 things 1st as 99% time its these.
  8. a_sagad
    a_sagad Member
    119
    I've got exactly the same issue, mine is normally 5th and 6th gears, at just above 2000rpms (70mph). It gets very annoying, but the vibrations go away if I do higher speed.
    I'm going to get the balancing and alignment done too now. :ermm:
  9. K-Dash
    K-Dash Member
    156
    yep, me too.
    Had new tyres fitted today.
    balancing irradicated the problem completely.
  10. dkingy11
    dkingy11 Member
    69
    will try and get booked in tomorrow, the sooner the better because it does become a little annoying!:mad:
    cheers for the help guys, will let you know how i get on!:o.k:
  11. anton2015
    anton2015 Member
    178
    That's exactly what my guy said at the garage, its very minimal al low speeds and at very high, so definitely balancing
  12. dkingy11
    dkingy11 Member
    69
    finally got round to getting wheels balanced!:yes:
    went to tyre spot, cost £21 for all 4 wheels. over the moon that its sorted now, made such a difference to the drive quality!
    cheers for your help guys!!:o.k:
