What can cause poor mpg ??
motfree Nov 28, 2010
  1. motfree
    motfree Member
    464
    Just wondering what is causing my car to use soooo much fuel even when I'm driving sensible ..
  2. Wozski
    Wozski Member
    523
    Alot of factors can make it worse - especially this time of year as its bloody freezing lol - also having a heavy foot, but if your driving sensibly im not sure what else to say....
  3. AudiS3-Turbo
    AudiS3-Turbo Member
    619
    27
    seems poor mpg threads is popular this time of year lol
  4. LiveWire
    LiveWire S3X
    329
    Wide tyres :cold:
  5. motfree
    motfree Member
    464
    Coolant temp ??
  6. CHRIS555
    CHRIS555 DOPE with added OCD
    1,970
    10
  7. S3KO4
    S3KO4 Member
    850
    WEIGHT
    WIDER TYRES
    DECAT
    FAULTY SENSORS, MAF, COOLANTS, COIL PACKS..
    FAULTY, THERMOSTAT
    OVERDUE SERVICE
    AIR-CON
    HEAVEY FOOT
    SHORT TRIPS
    BOOSTING and HIGH RPM
  8. motfree
    motfree Member
    464
    Brand new Maf on 2 weeks ago ..
    Maybe but it's using around £10 for 30 miles and that's not putting my foot down .. Think I'll go to a garage :) as I don't have a clue
  9. S3KO4
    S3KO4 Member
    850
    I get the same, regardless of how carefull I am.
    Just to add to the list. feel free to add your thoughts
    WEIGHT
    WIDER TYRES
    DECAT
    WORN CLUTCH causing slips. not power no go.
    FAULTY, THERMOSTAT
    OVERDUE SERVICE
    AIR-CON
    SEIZING BRAKES.
    WORN OUT BEARINGS
    HEAVEY FOOT
    SHORT TRIPS
  10. motfree
    motfree Member
    464
    Actually my coolant sign keeps coming up on my dash ? Maybe that sensor is bust .. But why would this make it use more fuel :-S ??
    m4tty likes this.
  11. Andrew@A.L.D
    3,879
    617
    Blowing exhaust before the O2 sensor leaking more air in with the ECU thinking the engine needs more fuel
    Boost leak and vacuum leak is also the same
  12. djarchive
    djarchive Member
    289
    Im getting this only on very cold morning starts though. Anybody know what this is caused by?
    Strange :S
  13. Imteyaz
    Imteyaz 6th Gear
    535
    It may be fuelling high as the coolant sensor is telling the ECU that the engine is 'cold' and as a result it is pumping a richer mixture through. I would try changing the sensor first, whilst you are at it, check your tyre pressures and also check the state of the airfilter (infact, check when it was last serviced and when it is next due for servicing).
    EDIT: Coolant sign on the dash also comes up when the expansion tank sender decides that it wants to play up - a new one is about a tenner and should sort it out, oh and its nice and white, and not a light brown colour as they tend to discolour over time so it's easier to make a visual check of how much coolant you have in there.
  14. s3dave
    s3dave TFSI Hybrid Supporter
    10,110
    736
    I got this this morning, just scraping snow of the windscreen and the dreaded 3 beeps showing coolant low, went off within 5 seconds....
  15. Hector8
    Hector8 Member
    78
    Try the simple things first like wheel allignments and tyre pressures all correct.
  16. Silverfish
    Silverfish New Member
    10
    Tracking to cure poor fuel consumption Classic fella ,also check parcel shelf straps ,could be that too
  17. Broken Byzan
    13,237
    465
    Mr fish, Hector is correct, wheel alignment can cause tyre scrubbing which needs to be overcome by engine power, using more fuel
  18. Silverfish
    10
    If you say so ,go get tracking done then and see you in a week when you still have the same problem.
  19. bengal
    bengal Member
    537
    Tracking can cause higher fuel consumption but i think it would have to be way out though as said by bryzan the engine will be working harder to overcome the resistance caused by this its the same principle as binding brakes and low tire pressures.
  20. Silverfish
    10
    Go get it plugged in ffs
  21. s3dave
    10,110
    736
    lol
  22. Broken Byzan
    13,237
    465
    I do say so as it's fact.....
    It is however unlikey that its changed that much without the driver noticing, but it can be a contributing factor if all else has been checked
