What Audi OE radios will fit A3 other than a Concert?
VAGMAN1 Mar 13, 2006
  1. VAGMAN1
    VAGMAN1 Member
    306
    the volume control is playing up and doing my head in! I want something of equal standard to a Concert - is it my only choice?
  2. AndyMac
    AndyMac Moderator Moderator
    9,832
    46
    Yes pretty much, no other HU's could equal the standard of the Concert (they're all better!)
    And make sure the replacement is from an A3/S3 as the fascia can be slightly different on Concerts from TT's
  3. VAGMAN1
    VAGMAN1 Member
    306
    so what other radios do Audi produce that will fit an A3 and do not suffer with the volume knob problems?
  4. C_Audiboy
    C_Audiboy Vroom Vroom
    822
    [ QUOTE ]
    [/ QUOTE ]
    I take it you are talking about the Concert Mk1 radio cassette???
    Why not replace it with the Concert single DIN CD player - you can pick one up on Ebay for a decent price.......
  5. madvw
    madvw Active Member
    2,489
    [ QUOTE ]
    [/ QUOTE ]
    in the post with the full explanation of the problem, it seemed to hint that the later model OEM headunits didn't suffer from the volume problem.... can't say for certain though...
  6. VAGMAN1
    VAGMAN1 Member
    306
    I read that it was the Concert 2 which has the volume knob/bad chip sorted, but does this only fit the new A3?
  7. yarmon1
    yarmon1 New Member
    It can be fixed but it is expensive...
  8. yarmon1
    yarmon1 New Member
    Concert 2 will fit but need to check sizes the following is some details I have found on ebay.
    Standard Concert with cassete is 220mm x 58 mm
    8e 0035 86 d 8E0035186J 235mm x 65mm silver strip
    8Z 0057 186GX
    8B0 035 186 Q 220mm across the top and 58mm bose system
  9. yarmon1
    yarmon1 New Member
    The following website describes the Concert Volume problem it can be fixed but will cost you £80 from OE Electronics in Swindon.
    http://www.erta.ru/review/chorus-problem_eng.shtml
    Be careful some Concert 2 models have different size front panels.
    The following site is a good source of data.
    http://www.ibiblio.org/tkan/audi/radios/
    I believe the Concert 2 radios have the problem fixed.
    If you buy from ebay check the size and if it is Bose or not.
    Hope this helps
    :blackrs4:
  10. paul_brad
    paul_brad Member
    365
    I thought the Concert 2 CD players have different wiring, if they are to fitted into older S3s? I may be wrong of course, but when I was researching this a couple of years ago, I just plumped for a nice Sony CD headunit instead.
