what are the signs that you need a new turbo?
Jonesy Oct 18, 2006
  1. Jonesy
    Jonesy Member
    570
    just wondering, ive never drove another s3 so i have nothing to compare it to, but im sure mine is slower than most, ive had it remapped, changed filter element, dv, maf sensor, fitted new hose where mine was split, oil change, optimax, just doesnt seem that quick. Thinking turbo may be the problem, so how would i know if i needed a new one.
    Plus how much do they go for and how much is labour.
    Thanks dudes
  2. monkeytrousers
    monkeytrousers Member
    371
  3. Tallpaul
    Tallpaul Member
    835
    As you've just PM'ed me about it, you must have VAG-COM.
    Setup to log block 002, find a nice empty piece of private road where you can do a run from 2000rpm to the redline in 4th gear and log the g/s over this rev range.
    Take your results, plot a graph of RPM v g/s and post it on here.
  4. Defratos
    Defratos YouÂ’re Dethpicable!!
    2,232
    Ohh sounds nice, I might do that =)
  5. Jonesy
    Jonesy Member
    570
    ill give it a go, thanks
  6. madvw
    madvw Active Member
    2,489
    you can also log requested boost against actual boost too. That'll give you some idea about potential boost leaks and n75 issues.
    Usual signs of turbo failure are cold sweats, tears, and empty bank accounts...
    your best bet is to get it dyno'd. tbh, s3's really dont feel fast though...
  7. mad max
    mad max sixth gear
    338
    on a less scientific note they start to whistle sounds a bit like a police siren following you around
  8. Tallpaul
    Tallpaul Member
    835
    not if you don't have the full version ;)
    But if you do then block 115 for boost requested v actual and 118 for N75 Duty Cycle.
  9. KEF A3 20V T
    KEF A3 20V T Turbo's Rule
    199
    you could take the TIP pie off and see if there is excessive play in the shaft and if it spins faily free. if you had a mirror and torch you could check see if the turbine has been hitting the housing, and also check for oil inside the housing!
