What are the signs of a weak actuator?
feville Feb 27, 2010
  1. feville
    feville Frank
    Hi guys just want to confirm that my actuator is on its way out...
    Car boost hits 12psi then rises to 14psi even though its been mapped and should be holding 18psi ish
    Is the norm for the boost to peak to say 21psi then drop and hold 18psi?
  2. sportstractor
    sportstractor Chugger
    2,709
    get it on vagcom the look at command boost vs actual (block 115)
    there is usually a spike, its the time it takes the ecu/boost controller to gain control of boost i think
    you want to elimate boost leaks etc first
  3. feville
    feville Frank
    I'd need to register my Vagcom to do that wouldnt i as i'm currently using the freeware version?
  4. feville
    feville Frank
    Anyone had any experience in one going on them?
  5. feville
    feville Frank
    Anyone? I'm running an AGU so cant measure command boost vs actual (block 115) :think:
