What are the benifits of Drive by wire?
Shy19s May 1, 2009
  1. Shy19s
    Shy19s Oil running through my veins.
    886
    Also, structurally, is there a difference between the BAM engine and the AMK engine? pistons, block, pins etc.. am i right in thinking the injectors and heads are very simular?
    The main difference is Electronic i believe but would the AMK engine stunt you from being able to get serious power?
    Also can you convert DBW to cable? would you want to etc?
    Thanks in advance
  2. Essflee
    Essflee Well-Known Member
    2,154
    67
    DBW is supposed to be more economical, more responsive and less maintenance...generally a better system to use...as for the BAM vs AMK, seem to hear different rumours so don't really know...
  3. <tuffty/>
    21,874
    4,201
  4. james0808
    james0808 Active Member
    3,548
    No way is it more responsive than a cable connected direct from the throttle pedal to the throttle butterfly with instant response.Dont see how it can be more economical but stranger things have happened.Less maintenance,how much maintenance is on a throttle cable?
    If it was a better system to use why do people buy sprint boosters?
    http://www.sprint-booster.co.uk/what_is_sprint_booster.asp
  5. Essflee
    2,154
    67
    Because the pedal is controlled by the engine management system through electrics and sensors as appose to cable the bet use is made for the amount of air comming in which gives better response and economy... I agree people use the sprint booster which helps response, this is what I was led to believe though...
  6. Dennis Moeller
    Dennis Moeller Member
    444
    Regarding DBW...I believe I have it on my AMK and I suspect it to cause this: coming off the gas when I change gears it keeps the engine revved. It takes forever (well not forever, but it's around 0.5-1 second) for the rev's to drop and it happens soooos slow. That really irritates me. Sounds as if I'm not lifting the foot from the gas pedal fast enough...like and old man :blink: When I blast it it's not a problem because the gearchange is faster and sound / speed are higher...
    But driving normally it does take at bit for the rev's to drop...sometimes it even raises the rev's a couple of hundred RPM's before dropping. Not excactly what I want from a car. You have the same issue?
    The sprint booster is not for me, I think, I don't want the ON/OFF gass pedal effect and are quite happy how I can control when I want boost.
  7. dstructiv
    dstructiv Member
    34
    lol sprint booster, another resistor in a black box, like all the maf and other +20bhp adverts on ebay. you cant make an electrical signal quicker than it is especially when an ecu is involved. :no:
  8. Dani_B19
    9,381
    403
    Whats the APY engine run?
  9. jojo
    28,998
    3,652
    ALL 8L S3's are DBW, mine has to be one of the earliest S3's about, APY engine code on a T-plate with no ESP or traction control, and it's DBW.
  10. james0808
    3,548
    Nothing like the +20 bhp ebay **** and neither does it make the electrical signal quicker,what it does as far as i can tell is alter the signal so the ecu thats involved opens the throttle plate faster and further than normal.Simples.
