What airbag for my new wheel?
Mikemc Mar 6, 2013
  1. Mikemc
    Mikemc Scooby Slayer VCDS Map User
    1,024
    37
    Bought a flat bottom wheel with the part number 8J0 419 091 H
    What airbags will fit this wheel and my A3 55 sportback?
    Part numbers if known will help a lot!
  2. Mikemc
    1,024
    37
    Anybody?
  3. mike foster
    3,967
    Airbag part number :- 8J0 880 201 N
    Wiring harness number :- 8J0 971 589 H
  4. Mikemc
    1,024
    37
    Is the harness needed with DSG?
  5. mike foster
    3,967
    The wheel you have bought is tiptronic and multi function. Even if your existing wheel is the same but not flat bottomed the airbag is different. There is no guarantee the lengths in the wiring loom are the same as the existing.
    It's up to you but I gave the information in case you didn't know !
  6. Mikemc
    1,024
    37
    Ok mate ill get on look out for an airbag then and then look for the harness if needed
  7. Mikemc
    1,024
    37
    Will an airbag same part number but suffix J fit?
  8. mike foster
    3,967
    Yes
  9. Mikemc
    1,024
    37
    Ok I think I've sourced one cheers
  10. N8
    17,163
    718
    Okay, I've pm'd now.
  11. Mikemc
    1,024
    37
    Doin need a slip ring?
  12. mike foster
    3,967
    No, you've already got one !!
  13. Mikemc
    1,024
    37
    Ok cheers I was just searching and seen a tt slip ring just thought I'd need one cheers pal
  14. Mikemc
    1,024
    37
    Just noticed that H isn't the latest airbag loom, do I still need that one or is the newest revision okay?
  15. Mikemc
    1,024
    37
    I've just purchased 8j0 880 201 J
    Is the above harness still ok for this?
  16. mike foster
    3,967
    Yep !
    Mikemc likes this.
  17. Mikemc
    1,024
    37
    Cheers mate brilliant help
  18. Mikemc
    1,024
    37
    Is there a guide for swapping wheels? And coding the mf buttons in as I've tried a search via tapatalk and its not bringing anything up?
  19. mike foster
    3,967
  20. chris.vincent3
    chris.vincent3 Own a BMW now, HOWEVER I still own VCDS! VCDS Map User
    604
    34
    there is probably a guide somewhere on here if you do a search. just remember to tape down the slip ring to make it easier for you to align the wheel when it goes back on.
    As for coding, i assume you have VAGCOM?
  21. Mikemc
    1,024
    37
    Yea I have vcds
  22. Ash187
    7,469
    731
    tape down? You shouldn't need to touch the slip ring as you take one wheel off and just replace it with the other... Just make sure the mark in the middle lines up again to the slip ring
  23. Mikemc
    1,024
    37
    Cheers guys, my airbag is arriving today, just hope my spline tool arrives also! Is it easy enough to code?
  24. Mikemc
    1,024
    37
    Bit confused by this coding,
    Coding
    00?xxxx: Transmission
    0 = Manual Transmission
    1 = Automatic Transmission
    00x?xxx: Steering Wheel
    0 = 3-Spoke, w/o Tiptronic, w/o Multi-Function
    1 = 3-Spoke, with Tiptronic, w/o Multi-Function
    2 = 4-Spoke Multi-Function (with Radio Control)
    3 = 4-Spoke Multi-Function (with Radio/Telephone Control)
    4 = 4-Spoke Multi-Function (with Radio/Telephone/Voice Control)
    00xx?xx: Tiptronic/Heating
    +1 = Tiptronic on Steering Wheel
    00xxx?x: Cruise Control/Board Computer
    0 = no Board Computer, no Cruise Control
    1 = Board Computer, no Cruise Control
    2 = no Board Computer, Cruise Control
    4 = Board Computer, Cruise Control
    00xxxx?: Rear Wiper
    0 = w/o Rear Wiper
    1 = with Rear Wiper
    I have DSG and a 3 spoke flat bottom wheel going in with mf buttons?
  25. mike foster
    3,967
    You have to fit the wheel/airbag before you try and code. You will then see more options.
  26. Mikemc
    1,024
    37
    I see thanks a lot mate cleared it right up will be doing it later
  27. Mikemc
    1,024
    37
    Like a child at Christmas on my way home from work excited to fit my new flat bottom!
  28. Mikemc
    1,024
    37
    got an airbag fault after install, do i need to do any more coding? here is the fault,
    Saturday,16,March,2013,17:03:10:46857
    VCDS Version: Release 11.11.5 (x64)
    Address 15: Airbags Labels: 8P0-959-655-94.lbl
    Control Module Part Number: 8P0 959 655 C HW: 8P0 959 655 C
    Component and/or Version: Airbag 9.41 H12 3760
    Software Coding: 0074622
    Work Shop Code: WSC 06314 000 00000
    VCID: 428D0CF51D38D808778
    1 Fault Found:
    01587 - Igniter 2 for Airbag; Drivers Side (N250)
    002 - Lower Limit Exceeded - MIL ON
    Freeze Frame:
    Fault Status: 11100010
    Fault Priority: 1
    Fault Frequency: 1
    Mileage: 136791 km
    Time Indication: 0
    Date: 2013.03.16
    Time: 17:02:42
  29. mike foster
    3,967
  30. Mikemc
    1,024
    37
    Just read that, on the rear of the airbag there is 2 plugs green and orange, and 2 clips that go onto the airbag I'm guessing maybe earths? And a smaller one at the bottom? Could I of put the bigger metal clips on wrong way round?
  31. Mikemc
    1,024
    37
    Do I need to code in the new tt airbag no?
  32. Mikemc
    1,024
    37
  33. Mikemc
    1,024
    37
    Can someone confirm that it's wired correct?
  34. Mikemc
    1,024
    37
    Sorted now, I hadn't pushed down one if the yellow clips on one of the igniters, I thought that just locked it in place, glad it's over was annoying me seeing lights on dash
