What a night !!! no-one to blame but myself
ginna104 Aug 5, 2009
  1. ginna104
    ginna104 Member
    32
    tonight i thought it would be good to have a ride to leeds bradford airport to wait for the girlfriend to land back from crawley so, i decide to pull onto a bit of ruff pot holed road to watch a few planes land and kill half hour !! as i pulled on my phone rang i picked it up and THUMP i'd gone down a massive pot hole and hit the sump !! being alloy it cracked and spewed all the oil out !!! just got recovered home now so well pee'd off !!! has any one got a alloy sump pan for a 2.8 v6 ack eng code audi a4 quattro ????
    cheers !!
  2. dieselfitter251
    dieselfitter251 Blow ma own trumpet?
    1,120
    pita. Sorry mate, that sh!t just happens. Glad no heavy damaged was incurred!
  3. jcb
    jcb Active Member VCDS Map User
    4,132
    13
    weldable?
  4. Geeman
    Geeman Low Life
    1,318
    I had my alloy sump on an old BMW E30 325i welded...
  5. docurley
    4,061
    If not too bad chemical metal may help you out for a while, I had to do it on my 1.8T after hitting a speed hump lasted over 2 months without a leak and only replaced when I had the oil pump replaced.
  6. ginna104
    ginna104 Member
    32
    ordered one from audi only 65 quid inc vat !!
  7. PhilR
    PhilR One Ate Tea
    332
    Not sure what its like on the v6 but getting the sump off on a 1.8t is a real joy
  8. Broken Byzan
    13,235
    464
    Same on the V6 TBH. Engine lift and/or Subframe drop
  9. s4marsh
    s4marsh Member
    360
    are you kidding? i've never looked on my s4 yet. why does nearly everything involve removing the engine
  10. aragorn
    17,889
    689
    Have you looked at how crammed the engine bay is? :p
  11. PhilR
    PhilR One Ate Tea
    332
    This thread has reminded me that i really need to look at making a sump guard, im now running 35 profiles on the font and the suspension is the lowest its ever been, if i smashed the sump id be sick as a chip
  12. Siena
    Siena Active Member
    2,626
    I would imagine the busted part on the V6 is the lower part - easier to replace than that of the 1,8T, which is all one piece.
    On the V6, the lower part replacement can be done without lowering the subframe / raising the engine.
  13. aragorn
    17,889
    689
    I know my V8, and i think also Craigs S4, both have a two piece sump, with a cast alloy housing on the bottom of the block, then a pressed steel "pan" underneath.
    I would assume the 30v's are the same?
    If thats the case then changing the pressed steel pan shouldnt be too bad?
  14. Siena
    Siena Active Member
    2,626
    The ACK lower pan is also cast aluminium, and is easy to replace.
    Worth noting, there are 2 types - with and without provision for fitting the oil quality sensor.
  15. s4marsh
    s4marsh Member
    360
    its proper chocka my engine bay yes, even changing a bulb is a job for stick insect arms
  16. ginna104
    ginna104 Member
    32
    as said its a 2 piece sump and it's the lower pan thats cracked, just put the car onto ramps the undid the 4 bolts on the antiroll bar then about 15 sump bolts and off it came, sealed the new one and put it back on, £73.00 i shouldn't have needed to spend though !!! but now iv'e learnt my lesson no off roading LOL
  17. Siena
    Siena Active Member
    2,626
    And no using your phone whilst on the move, I'd say you got off lightly.
    Out of interest, how low is your car?
  18. ginna104
    ginna104 Member
    32
    hi mate ye no phone's iv'e been told by the missus !!! lol as far as i no mate its standard height but the crater was massive !!!
