What a difference a Cone makes
g60leigh Jun 28, 2008
  1. g60leigh
    g60leigh Well-Known Member
    1,674
    207
    Well umm'd and ahh'd a bit about fitting a cone filter as I had heard about them killing the MAF (I have now found this is only if they are over oiled) and heat soak from the engine.
    I have had a look at the K&N 57i kit's and like the quality so I have bought and installed one.
    WOW can really hear the induction and re-circ dump valve flutter/hiss
    I am really impressed with the feel it gives the engine and the noise!!!
    as far as the heat soak is concerned I think I have that covered.
    I have ordered a heat shield/blanket for the turbo I have used the original heat shield and tie wrapped it off the rail and made my self a barrier out of a sheet of alluminium and some silicone hose
    what do you think?
  2. olds_kool
    olds_kool Active Member VCDS Map User
    1,089
    13
    nice job, ignored warnings aswell fitted one ages ago with no problems so far
    sound is awesome
  3. Randomjim
    Randomjim Active Member
    2,752
    That aluminium heat shield looks really well made, i'm after something similar.
  4. Z82
    Z82 Member
    454
    Looks the danglies :)
  5. g60leigh
    1,674
    207
    I have done this as a guide, so excuse my cr@p diagram, the dimensions are what I have used but you may have to tweak them as you go, it also needs curving as you install it.
    The image is not to scale!
    let me know if it helps.
  6. Oranoco
    Oranoco Well-Known Member
    3,924
    393
    They're only fifty quid as well. Sod it might throw one in mine next week.
    How does the MAF fit in and what was it like to fit?
  7. g60leigh
    1,674
    207
    only took 5 minutes to fit the cone. the maf unscrews from the airbox, you then clamp it directly to the intake pipe, there is a bracket in the kit to hold tha MAF in place and the cone filter fastens to the other end.
  8. jcb
    jcb Active Member VCDS Map User
    4,132
    13
    nice sheild. now get that ram pipe fitted from behind your fog light for some really cool air
  9. ALPINE
    3,093
    that looks really good. i mite have a go at making 1 like that.
    Good job! :)
  10. g60leigh
    1,674
    207
    Had a look at that but cannot see anyway to secure it. Has anyone else ran one from there
  11. ALPINE
    3,093
    yep...
    you need to relocate your horn.. (i attached it were the old air box bolted to the wing) then simply ran a induction pipe from the vent to the filter. pipes approx 6" round and it just sits there. dont move rattle or anything.
    hope this helps.
  12. Broken Byzan
    13,237
    465
    "g" nice pointy arrows,lol
  13. ALPINE
    3,093
    taking the piss?? lol
    behave mark! lol :)
  14. floyd 1.8 turbo
    floyd 1.8 turbo Mirror, Signal, Outmanoeuvre
    632
    I'm glad you've posted this cos i bought the same from Demon Tweeks last week..Really looking forward to fitting it and finally having some noise coming from the silent engine!
  15. floyd 1.8 turbo
    632
    At last, the filter is fitted... love it. Gives off a great sound...not as much of a roar as i expected but a nice turbo noise and a bit a whistle too. All good!
  16. Oranoco
    3,924
    393
    I'm oing to nab the airbox from one of the breakers and see if I can't fashion something up that looks a little better than my current heat shield and zip tie effort. lol
  17. g60leigh
    1,674
    207
    I have made up a heat shield which so far seems to work quite well. if it helps I can post you a cardboard template?
    I have put the dimensions on this post, if your really stuck I can see if I can get some more alluminim and make one up
  18. ALPINE
    3,093
    i am attemting this today...... got me self a chunk of air craft ali. needs a good polish but ill sort that at a later date.
    ill get some pics up later.
  19. g60leigh
    1,674
    207
    let me know if my dodgy picture has made it any easier
  20. ALPINE
    3,093
    right.... its all on and yes it works a treat! modified my sheild slightly to diagram but that diagram deffo made it alot easyer to construct.
    heres some pics..
    1 manky piece of ali out the father in laws shed....
    1 printed out diagram from mr G60
    Piece of ali after a bit of cutting..
    birds eye view of cutting so far..(and 1 beer gut in the way)
    other side of the ali covered in paint, what a lovley job to remove it all!!
    all edges curved off and made safe to touch...
    brushed ali effect after some elbow grease..
    on the car, drilled 1 hole, threaded it, and attached it with a butterfly bolt so it is easly removed again. other nut on rear on bulk head.
    from another angle...
    i found this easy to do, (altho time consuming) many thanks to g60leigh for the diagram!
    what we think of my attemt then?
  21. g60leigh
    1,674
    207
    looks good mate.
  22. ALPINE
    3,093
    tell ya what people.... all you that have an after market air filter that is not protected from a heat sheild, make 1 of these!!! the noticable difference is amazing!! since i have fitted this, my fuel economy has gone up, my performance is there all the time, there is no hessitation what so ever through the rev range. since fitting this tiny peice of ali to my car it feels so much different. i have been away to visit family this weekend so have done alot of miles, and sat in alot of traffic!
    best mod i have done with out a doubt!
  23. docurley
    4,070
    85
  24. aragorn
    18,315
    809
    I'd be interested in seeing some vagcom readings of the Intake Temp with and without the shield fitted. Do you have Vagcom and a lead?
    I've always been skeptical about the whole idea of a heatshield and "CAI" kits as when your driving along its not as though the engine bay is sealed off, theres air flowing through it at road speed, and its only really while stationary that you tend to get heatsoak. Even then i'd be more worried about heatsoaking the intercooler than the air flowing into the turbo as thats where most of the cooling happens anyway...
    If you could pull some readings with and without it that would be excellent.
  25. quattrojim
    quattrojim New Member
    27
    I also made myself a heat shield over the weekend thanks to the very handy diagram, tweaked it slightly but here is my attempt:
    only slight problem is when i put my foot down now it makes a loud sucking noise but isn't very responsive, any ideas? should i just ditch it and go back to airbox?
  26. ALPINE
    3,093
    not enough air i would say mate. i had the same problem. simply re-locate the horns and run an induction pipe. worked a treat for me!
    Edit: also that little sensor thing that sits on top of the air box (with a little heat sink on it) that needs to be keeped cool so i have been told as it will effect your performance. sorry im not clued up enough on the reson why i just know it should be keeped cool.
  27. aragorn
    18,315
    809
    the metal thing is the ignition amplifier, it emits quite a bit of heat hence requiring cooled.
    I cant imagine its "not enough air" as its not as though the heatshield is completely sealed and the original inlet duct is still fitted which can supply enough air for tuned engines just fine.
  28. ALPINE
    3,093
    pass mate... just going by past experience. since i added that induction pipe mate it compleatly sorted the problem i had, the same 1 quattrojim is speaking about.
    :meeting:
  29. quattrojim
    27
    ok thanks for the advice, will try run a pipe up to it for some more cold air and see if that helps.
  30. docurley
    4,070
    85
    Alpinehead do you still have the intake pipe from the grill, if so can I have it if you don't want it?
